Hi, guys I've got a question on photographic correlation for doing inspection by cross correlation. I can find sub-image inside the original image, however, I don't have an idea if the images have been taken at far different distances, so the resolution of the big image and sub-image are different. Can anybody tell me theoratically on this? thank you very much. Sangthong
different resolution on photographic correlation
Started by ●April 20, 2008
Reply by ●April 21, 20082008-04-21
On Apr 20, 1:23�pm, "sangthong" <sangthong2...@yahoo.com> wrote:> Hi, guys > > I've got a question on photographic correlation for doing inspection by > cross correlation. I can find sub-image inside the original image, however, > I don't have an idea if the images have been taken at far different > distances, so the resolution of the big image and sub-image are different. > Can anybody tell me theoratically on this? thank you very much. > > SangthongHello Sangthong, Are the subjects being photographed flat (2-dimensional)? If so simple scaling/translation/rotation will at least allow you to compare the images - apart from lens distortions. One hopes that barrel/pincushion distortion has already been compensated for. If the subjects are three dimensional, then the photos taken from different distances will have different perspectives unless the lenses are object space telecentric - i.e. provide orthographic projections. do you know how the pictures were captured? Clay
Hi Sangthong, This is the primary limitation of using cross-correlation in image analysis. The target pattern you are looking for can be scaled and maybe even rotated in the image being examined. Brute force would simply cross-correlate with different scalings and rotations of the target. Of course, this would require a huge computation time. The amazing thing is that the eye/brain can do this task very quickly. It is humbling to see that Nature can process a signal so well, and my DSP does it so poorly. Regards, Steve
Reply by ●April 22, 20082008-04-22
>Hi Sangthong, >This is the primary limitation of using cross-correlation in image >analysis. The target pattern you are looking for can be scaled andmaybe>even rotated in the image being examined. Brute force would simply >cross-correlate with different scalings and rotations of the target. Of >course, this would require a huge computation time. > >The amazing thing is that the eye/brain can do this task very quickly.It>is humbling to see that Nature can process a signal so well, and my DSP >does it so poorly. >Regards, >Steve > > >Thank you very much Clay and Steve, Steve, I've read through the brute fource you recommend, I still don't get it in term of correlating with certain prominent data point, how would this help with the scaling? Thank you very much
Reply by ●April 23, 20082008-04-23
>Steve, I've read through the brute fource you recommend, I still don'tget>it in term of correlating with certain prominent data point, how wouldthis>help with the scaling? Thank you very much >Hi Sangthong, I wouldn't quite say that I recommend it. This brute force method rapidly becomes overwhelming in computational requirements. I'm not sure what you are referring to, but my guess is that it is some algorithms to select the most likely convolutions to perform, based on key features of the data. This sounds like an interesting method, but I'm just guessing, I've never directly worked in this area. Good luck! Steve
On Apr 23, 11:52�am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote:> >Steve, I've read through the brute fource you recommend, I still don't > get > >it in term of correlating with certain prominent data point, how would > this > >help with the scaling? Thank you very much > > Hi Sangthong, > I wouldn't quite say that I recommend it. �This brute force method rapidly > becomes overwhelming in computational requirements. I'm not sure what you > are referring to, but my guess is that it is some algorithms to select the > most likely convolutions to perform, based on key features of the data. > This sounds like an interesting method, but I'm just guessing, I've never > directly worked in this area. �Good luck! > SteveSteve and Sangthong, A real neat application of image recongnition involves holographic optical elements. Basically the diffraction of light results in the near field and far field spatial distributions being related through fourier transforms. One can use a lens to record a fourier transform hologram and there are even "lensless" fourier transform methods for making holograms. And a holdgram can be made as a multple exposure where each exposure represents a different "look" at the object (i.e., rotation, scaling, and even perspective). Just use a unique direction for the reference light when each image is recorded. Then this holographic optical element is used to analyze the DUT. The HOE will recoinstruct the reference light associated with the matching image. This has even been used by the FBI for quick fingerprint identification. The issues they ran into were related to the poor quality of many of the older reference fingerprints on file. Clay
Reply by ●April 24, 20082008-04-24
>Steve and Sangthong, > >A real neat application of image recongnition involves holographic >optical elements. Basically the diffraction of light results in the >near field and far field spatial distributions being related through >fourier transforms. One can use a lens to record a fourier transform >hologram and there are even "lensless" fourier transform methods for >making holograms. And a holdgram can be made as a multple exposure >where each exposure represents a different "look" at the object (i.e., >rotation, scaling, and even perspective). Just use a unique direction >for the reference light when each image is recorded. Then this >holographic optical element is used to analyze the DUT. The HOE will >recoinstruct the reference light associated with the matching image. >This has even been used by the FBI for quick fingerprint >identification. The issues they ran into were related to the poor >quality of many of the older reference fingerprints on file. > >Clay >Hi Clay, Interesting! I've seen people try to market optical devices for image cross-correlation before, but the results have always been disappointing. The fast processing they hope to achieve always seems to loose out to problems such as readout bandwidth, resolution, and the like. But it sounds like what you are describing is a step above what I have seen before. Thanks for telling us about it. Steve>
