"anando" <meet_anando@yahoo.com> wrote in message news:v5CdndW3OpOF94zVnZ2dnUVZ_v2pnZ2d@giganews.com...> >> >>For an IFFT of length N, if the number of non-zero coefficients >>K is much less than log N, then one could just compute a naive >>inverse DFT pruned to just calculating for K bins. >> >>If you actually want something different from the entire >>and precise IFFT result vector, then you could note that >>this complete IFFT looks very similar to a modulated >>and upsampled result for some narrow baseband signal. >>You might be able to translate your non-zero bins to >>baseband, un-zero-pad, and perform a much shorter IFFT. >>But this is unlikely to be more efficient unless you don't >>need, or have some other (analog?) solution for, upsampling >>interpolation and modulation later in your desired process. >> > > Thanks a ton to all of you who have replied. This idea is one that appeals > to me a lot and I might try it. > > So if I understand you correctly, I could > * heterodyne the signal such that my zero frequency lies at > f_0 = 0.5*(f_1 + f_2) - then > * I could take an IFFT of a much much smaller vector. > > Of course the time samples will be much coarser than the original IFFT - > but I guess I can always interpolate ? > > Please correct me if I am mistaken. What did you mean by un-zero pad ? > > Cheers, > Anando.After decimating you don't need to interpolate any more than you did before. Consider this: An AM signal. The carrier is of no real interest. The interesting part is all in the waveform envelope. So, the decimation still gets you a good representation of the envelope. Fred
efficient inverse fft of a band-pass function
Started by ●April 23, 2008
Reply by ●April 25, 20082008-04-25
On 25 Apr., 07:27, "anando" <meet_ana...@yahoo.com> wrote:> >>Thanks for your reply. I do realize that R_b(f) can be written as a > >>product of R(f) and a boxcar function in the frequency space. As > >mentioned > >>before, I know the inverse FT of R(f) [as r(t) is known] and also the > >>boxcar function [some combination of sinc functions - let us call it > >s(t) > >>]. > > >>So I guess my query is how would I write down the inverse FT of R_b(f) > >>using r(t) and s(t) in a computationally efficient manner. > > >>Again, many thanks for your help. > > >>Cheers, > >>Anando. > > >Hi Anando, > >I agree with what the others have said, but I'm not sure they answered > >what you were asking. �When you say "write down...", do you mean how to > >digitally calculate the result, or how to write down the equation? �As > an > >equation, the Inverse FT of R_b(f) is equal to the convolution of r(t) > and > >s(t). As a previous post pointed out, if this is for digital signals you > >need to worry about circular convolution. �Here's some links: > > >http://www.dspguide.com/ch9/2.htm > >http://www.dspguide.com/ch9/3.htm > > >Steve > > Hi Steve > > Thanks for your mail. > > I was hoping to calculate the result I guess. > > Just to clarify my question, in a slightly abstract form, my query is, > would it be possible to recreate the inverse FT of a band-pass signal from > the inverse FT of the full signal ? I'd be very grateful if you have > pointers for that.Sure. Let's say that y[n] is the desired bandpass signal, and x[n] is the full band signal. You want to calculate y[n], given x[n]. That's easy: y[n] = IDFT[ rect[k] DFT[x[n] ] where rect[k] is the suitably chosen rectangular bandpass. Regards, Andor
On Apr 23, 11:11 am, "anando" <meet_ana...@yahoo.com> wrote:> Hi > > > > > > >Another way to express your band-limited signal is R_b(f) = R(f) H(f) > >Where H(f)= 1 f_1<= |f| <=f_2 > > = 0 otherwise > > >There are some variations between the versions of the Fourier transform, > >but there is properties that relates multiplication in Fourier space to > >convolution in time. In your case (FFT), it goes by two names: > >"circular convolution" property and "cyclic convolution" property. > > >Circular convolution has some subtleties of which you need to be aware. > >It's not the convolution your mother taught you. So if you are not > >familiar with it do some web searches. > > >Cheers, > >J. Elms > > Thanks for your reply. I do realize that R_b(f) can be written as a > product of R(f) and a boxcar function in the frequency space. As mentioned > before, I know the inverse FT of R(f) [as r(t) is known] and also the > boxcar function [some combination of sinc functions - let us call it s(t) > ]. > > So I guess my query is how would I write down the inverse FT of R_b(f) > using r(t) and s(t) in a computationally efficient manner.Given that s(t) has infinite support, the most computationally efficient manner might well be to just (re)do a finite length FFT/boxcar/IFFT (or pruned FFT/IDFT), or to accept some form of approximation to your desired boxcar filtered r(t), using something such as FIR or IIR time domain filters, over a circular buffer if needed, for instance. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Reply by ●April 28, 20082008-04-28
>On Apr 23, 11:11 am, "anando" <meet_ana...@yahoo.com> wrote:>> Thanks for your reply. I do realize that R_b(f) can be written as a >> product of R(f) and a boxcar function in the frequency space. Asmentioned>> before, I know the inverse FT of R(f) [as r(t) is known] and also the >> boxcar function [some combination of sinc functions - let us call its(t)>> ]. >> >> So I guess my query is how would I write down the inverse FT of R_b(f) >> using r(t) and s(t) in a computationally efficient manner. > >Given that s(t) has infinite support, the most computationally >efficient manner might well be to just (re)do a finite length >FFT/boxcar/IFFT (or pruned FFT/IDFT), or to accept some form >of approximation to your desired boxcar filtered r(t), using >something such as FIR or IIR time domain filters, over a >circular buffer if needed, for instance. > > >IMHO. YMMV. >-- >rhn A.T nicholson d.0.t C-o-M >Hi Many thanks for your suggestions. Any links to time-domain FIR/IIR filtering will be greatly appreciated (second part in your reply). Also, could wavelets be used for my problem ? For example, could I wavelet transform r(t) to give me the boxcar filtered r(t) ? Cheers, Anando.
