RTDX problem
Started by Hamid April 16, 2004
Hi all
I'm running a massive test harness on a DSK6416 , I send data from
Matlab via RTDX to the target and get the data back for analyzing in
Matlab via RTDX.
After a while CCs crashes and caused RTDX input channel failure in
Matlab .
Error message in CCS is as following
"Unexpected Fatal Error Encountered
Which may have been caused by a stack overflow
Out of memory condition, or access violation"
Any body has any suggestion or comment?
Regards , H.Sepehr
Hamid wrote:
> Hi all > > I'm running a massive test harness on a DSK6416 , I send data from > Matlab via RTDX to the target and get the data back for analyzing in > Matlab via RTDX. > > After a while CCs crashes and caused RTDX input channel failure in > Matlab . > Error message in CCS is as following > > "Unexpected Fatal Error Encountered > Which may have been caused by a stack overflow > Out of memory condition, or access violation" > > Any body has any suggestion or comment? > > Regards , H.Sepehr
Sounds like your massive test harness has done it's job and found the kind of bug that comes up when you load a system heavily. Unfortunately it sounds like the problem is in Code Composter and not your DSP code -- do you know if it's CC that's crashing, or is it the DSP? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 16 Apr 2004 06:39:41 -0700, hsepehr@yahoo.com (Hamid) wrote in
comp.dsp:
First realize that usenet groups are not chat rooms. It can take hours or sometimes days for your message to get to servers all over the world and replies to come back. It is bad manners to post the same question three times in less than one hour. Second, this is a known problem with some versions of Code Composer Studio. Go to TI's web site and see if there is an update or later version. These crashes are much reduced or eliminated completely with newer versions. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://www.eskimo.com/~scs/C-faq/top.html comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.contrib.andrew.cmu.edu/~ajo/docs/FAQ-acllc.html
Hi Jack
I'm sorry if I have sent 2 repeated message , but If you notice , I
didn't mention the error in the first message and that's why I sent
the second message.
Regarding my problem , I do use the latest version of CCS.
thnaks , Hamid
