On May 4, 8:10 pm, dpierce.cartchunk....@gmail.com wrote:> On May 3, 9:16 am, rajesh <getrajes...@gmail.com> wrote: > > > Its also about how you store data. > > > here is an simplified analogy. > > Yes, simplified to the point of being factually wrong. > > > say you need 44.1k samples per second to hear properly. > > If the disk is corrupted with scrathes and 1 samples in his > > region are lost your sound is distorted or lost for that period > > of time. > > Wrong. First, you have a pretty robust error correction > scheme built in to the disk. The encoding and decoding > is such that significant amounts of data can be lost > but can be EXACTLY reconstructed on playback with NO > loss. And if the disk is severely scratched to the point where > the error correction algorith fails, interpolation takes place. > > One can see thousands of uncorrected errors in the raw > data coming of the disk, and once the error correction > has been applied, the result might be a SMALL handful > (like, oh, 4?) uncorrectable but interpolated errors > > > Now if there are 196k samples even if (196/44.1) > > samples are lost there is no difference to what you > > hear. > > False. Since you're cramming more data into the same > area, and the physical faults take up the same area > regardless of the data density, more bits, according to > YOUR theory, will be lost on the higher density disk > than on the lower density disk. > > That means MORE data is missing, that means the > error correction algorith is subject to higher rates of > non-correctable errors, and so on. Your theory is > bogus if for no other reason than it simply ignores the > facts. > > But, in EITHER case, unless the disk is SERIOUSLY > damaged, the data loss in either case is repaired. > > > DVD's come wih high density of data due to this > > they are highly vulnerable to scratches this can > > be avoided with better waveform matching achieved > > by high sampling rate. > > Sorry, this is nothing but technobabble nonsense.Thanks ! Your facts are proving my point. Repeating samples is the most simplest form of error correcting codes. All your error correcting codes and interpolation techniques become 196/44.1 folds more robust on 196 kHz signal compared 44.1 kHz signal. You just have to accept this point of view although it may not justify for going 196 kHz. " remembering and quoting facts is no big deal, you have to learn to analyze them"
What's the use of a 192 kHz sample rate?
Started by ●May 3, 2008
Reply by ●May 5, 20082008-05-05
On May 5, 12:47 pm, rajesh <getrajes...@gmail.com> wrote:> On May 4, 8:10 pm, dpierce.cartchunk....@gmail.com wrote: > > > > > On May 3, 9:16 am, rajesh <getrajes...@gmail.com> wrote: > > > > Its also about how you store data. > > > > here is an simplified analogy. > > > Yes, simplified to the point of being factually wrong. > > > > say you need 44.1k samples per second to hear properly. > > > If the disk is corrupted with scrathes and 1 samples in his > > > region are lost your sound is distorted or lost for that period > > > of time. > > > Wrong. First, you have a pretty robust error correction > > scheme built in to the disk. The encoding and decoding > > is such that significant amounts of data can be lost > > but can be EXACTLY reconstructed on playback with NO > > loss. And if the disk is severely scratched to the point where > > the error correction algorith fails, interpolation takes place. > > > One can see thousands of uncorrected errors in the raw > > data coming of the disk, and once the error correction > > has been applied, the result might be a SMALL handful > > (like, oh, 4?) uncorrectable but interpolated errors > > > > Now if there are 196k samples even if (196/44.1) > > > samples are lost there is no difference to what you > > > hear. > > > False. Since you're cramming more data into the same > > area, and the physical faults take up the same area > > regardless of the data density, more bits, according to > > YOUR theory, will be lost on the higher density disk > > than on the lower density disk. > > > That means MORE data is missing, that means the > > error correction algorith is subject to higher rates of > > non-correctable errors, and so on. Your theory is > > bogus if for no other reason than it simply ignores the > > facts. > > > But, in EITHER case, unless the disk is SERIOUSLY > > damaged, the data loss in either case is repaired. > > > > DVD's come wih high density of data due to this > > > they are highly vulnerable to scratches this can > > > be avoided with better waveform matching achieved > > > by high sampling rate. > > > Sorry, this is nothing but technobabble nonsense. > > Thanks ! Your facts are proving my point. > Repeating samples is the most simplest form of error correcting codes. > All your error correcting codes and interpolation techniques become > 196/44.1 folds > more robust on 196 kHz signal compared 44.1 kHz signal. > > You just have to accept this point of view although it may not justify > for going 196 kHz. > > " remembering and quoting facts is no big deal, you have to learn to > analyze them"Try writing 44.1 khz signal on that high density disc(greed to store more music)....small scratch and and the disc is busted.
On May 5, 12:47 pm, rajesh <getrajes...@gmail.com> wrote:> On May 4, 8:10 pm, dpierce.cartchunk....@gmail.com wrote: > > > > > On May 3, 9:16 am, rajesh <getrajes...@gmail.com> wrote: > > > > Its also about how you store data. > > > > here is an simplified analogy. > > > Yes, simplified to the point of being factually wrong. > > > > say you need 44.1k samples per second to hear properly. > > > If the disk is corrupted with scrathes and 1 samples in his > > > region are lost your sound is distorted or lost for that period > > > of time. > > > Wrong. First, you have a pretty robust error correction > > scheme built in to the disk. The encoding and decoding > > is such that significant amounts of data can be lost > > but can be EXACTLY reconstructed on playback with NO > > loss. And if the disk is severely scratched to the point where > > the error correction algorith fails, interpolation takes place. > > > One can see thousands of uncorrected errors in the raw > > data coming of the disk, and once the error correction > > has been applied, the result might be a SMALL handful > > (like, oh, 4?) uncorrectable but interpolated errors > > > > Now if there are 196k samples even if (196/44.1) > > > samples are lost there is no difference to what you > > > hear. > > > False. Since you're cramming more data into the same > > area, and the physical faults take up the same area > > regardless of the data density, more bits, according to > > YOUR theory, will be lost on the higher density disk > > than on the lower density disk. > > > That means MORE data is missing, that means the > > error correction algorith is subject to higher rates of > > non-correctable errors, and so on. Your theory is > > bogus if for no other reason than it simply ignores the > > facts. > > > But, in EITHER case, unless the disk is SERIOUSLY > > damaged, the data loss in either case is repaired. > > > > DVD's come wih high density of data due to this > > > they are highly vulnerable to scratches this can > > > be avoided with better waveform matching achieved > > > by high sampling rate. > > > Sorry, this is nothing but technobabble nonsense. > > Thanks ! Your facts are proving my point. > Repeating samples is the most simplest form of error correcting codes. > All your error correcting codes and interpolation techniques become > 196/44.1 folds > more robust on 196 kHz signal compared 44.1 kHz signal. > > You just have to accept this point of view although it may not justify > for going 196 kHz. > > " remembering and quoting facts is no big deal, you have to learn to > analyze them"Remember the shannon's theorem which places a trade off between error correcting codes and bandwidth.
"Green Xenon [Radium]" <glucegen1@excite.com> wrote in message news:481becfe$0$5141$4c368faf@roadrunner.com...> Why does DVD-Audio use 192 kHz sample rate? What's the advantage over > 44.1 kHz? Humans can't hear the full range of a 192 kHz sample rate?This is the same guy who wanted a 3GHz sample rate in an earlier post!!!!> On average, what is the minimum sample rate for a guy in his early to > mid 20s who likes treble?44.1 ks/s.> I agree there are a small percentage of humans who can hear above 20 > kHz. However, DVD-audio uses a sample-rate of 192 kHz which allows a > maximum frequency of 96 kHz. There is no known case of any human being > able to hear sounds nearly as high as 96 kHz. I can agree with 48 kHz > sample rate and even 96 kHz sample-rate [maybe], but 192 kHz is juststupid.> > So whats the justification fur using 192 kHz? If you ask me, its just a > total waste of bandwidth and energy. Any proof to the contrary?The advertising sounds better.> Please correct me if I'm wrong but AFAIK, its a waste of time, money, > energy to move to 192 kHz.So why did you want 3GHz for audio then!!!!!!!!!!!!!! Please explain your sudden change of heart. (and yes I know he's just a troll) MrT.
"rickman" <gnuarm@gmail.com> wrote in message news:0edc0747-6d9c-4cc7-9ec5-509523553e2e@b64g2000hsa.googlegroups.com...> If it really is a waste of time and money to use 192 kHz ADC and DAC, > why do you think they would do it? Don't you think the people > designing DVD equipment understand the economics of consumer > products? > > Try to think about it and see if you can come up with a couple of > reasons yourself. I'll be interested in hearing what you think.Because it costs them no more and the advertising sounds better to the uninformed. What did you come up with? MrT.
