Hello everyone, I read somewhere that if we want to resolve two frequencies using the fourier transform, one signal must have evolved an extra 2 pi relative to the other. I am trying to picturise this, but am having trouble understanding this relationship. Can someone explain why this is so? Cheers, Anja
question about sampling
Started by ●May 3, 2008
Reply by ●May 3, 20082008-05-03
On May 3, 8:16 am, Anja <anja.e...@googlemail.com> wrote:> Hello everyone, > > I read somewhere that if we want to resolve two frequencies using the > fourier transform, one signal must have evolved an extra 2 pi relative > to the other. I am trying to picturise this, but am having trouble > understanding this relationship. Can someone explain why this is so? > > Cheers, > AnjaI think what you are describing is the frequency resolution of a sampled waveform. It actually has nothing to do with the Fourier transform. It is a fundamental property of a sampled signal of finite length. A time sampled signal can be considered as a sum of signals each of which are integer multiples of the frequency of the sine wave with a wavelength equal to the time duration of the sample size. If Fs is the sample rate and N is the total number of samples, then N/Fs is the time duration of the sample set. The fundamental frequency of this sample set is Fs/N. It can be considered to be composed of sine waves with frequencies , 0*Fs/N, 1*Fs/N, 2*Fs/N,... up to (N/2)*(Fs/N) or Fs/2. In reality the sampled signal could have been produced from an analog signal with different frequencies, but there is no way to tell the difference in the sampled domain. When converted back into an analog signal, the result will be the same if filtered by the "perfect" analog filter. This frequency spacing of Fs/N is, I think, what you are talking about when you say, "evolved an extra 2 pi relative", no? The point is that this is a property of a finite, sampled signal, not the Fourier transform. If you are in a class on digital signal processing, you need to review your early chapters to figure out why you missed this. If you are learning it on your own, then you are a better man than I am. Even *after* taking a class in DSP, it took me years to actually grasp what a lot of this is about. (I'll tell you a secret, I *still* don't really understand the Z transform, but don't tell anyone, it's our little secret!)
On May 3, 5:16 am, Anja <anja.e...@googlemail.com> wrote:> I read somewhere that if we want to resolve two frequencies using the > fourier transform, one signal must have evolved an extra 2 pi relative > to the other. I am trying to picturise this, but am having trouble > understanding this relationship. Can someone explain why this is so?If you transform a finite length signal into the frequency domain, two sinusoids which are periodic but of different frequencies will be orthogonal and thus completely separable in the frequency domain. To be both periodic and different requires a different integer multiple of full cycles, or of 2 pi of phase, within the window. You can note that the two periodic sinusoids are orthogonal by seeing that if you multiply them together, the positive and negative contributions cancel each other out. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
