Dear All, I'm not sure if this is the right place for this, so if not sorry. I have 2 matrixes (2x7) and i want to do convolution on them. When I do the foureir transformation and then multiply them and finally do the inverse fft I get a matrix of complex numbers. How do I turn these numbers/matrix into a correlation coeff or something close to it. Also is fft-ing the best way to do this? I've include a little code to illistrate my exaple. Cheers, Paul > zy y [1,] 10 0.00 [2,] 20 0.00 [3,] 30 0.25 [4,] 40 0.50 [5,] 50 0.25 [6,] 60 0.00 [7,] 70 0.00> zxx [1,] 10 0 [2,] 20 0 [3,] 30 0 [4,] 40 100 [5,] 50 0 [6,] 60 0 [7,] 70 0> fft(fft(zx) * fft(zy), inverse=TRUE)x [1,] 147350+0i 70700+0i [2,] 166600+0i 84840+0i [3,] 176400+0i 98735+0i [4,] 176400+0i 14385+0i [5,] 166600+0i 28280+0i [6,] 147350+0i 42420+0i [7,] 118300+0i 56560+0i
Convolution
Started by ●May 6, 2008
Reply by ●May 7, 20082008-05-07
On May 7, 5:56 am, PB0711 <hpben...@gmail.com> wrote:> Dear All, > > I'm not sure if this is the right place for this, so if not sorry. > > I have 2 matrixes (2x7) and i want to do convolution on them. When I > do the foureir transformation and then multiply them and finally do > the inverse fft I get a matrix of complex numbers. How do I turn these > numbers/matrix into a correlation coeff or something close to it. > > Also is fft-ing the best way to do this? > > I've include a little code to illistrate my exaple. > > Cheers, > > Paul > > > zy > y > [1,] 10 0.00 > [2,] 20 0.00 > [3,] 30 0.25 > [4,] 40 0.50 > [5,] 50 0.25 > [6,] 60 0.00 > [7,] 70 0.00> zx > > x > [1,] 10 0 > [2,] 20 0 > [3,] 30 0 > [4,] 40 100 > [5,] 50 0 > [6,] 60 0 > [7,] 70 0> fft(fft(zx) * fft(zy), inverse=TRUE) > > x > [1,] 147350+0i 70700+0i > [2,] 166600+0i 84840+0i > [3,] 176400+0i 98735+0i > [4,] 176400+0i 14385+0i > [5,] 166600+0i 28280+0i > [6,] 147350+0i 42420+0i > [7,] 118300+0i 56560+0iDo u want to do a 2-d convolution or just 1-d. If 2-d is the case then you can use conv2 and if you wanto to use fft then you can use fft2.
I would like to do a 2D convolution. I tried the fft2 and conv2 function but it didn't work. I'm working in 'R', I think I forgot to say where my code was comming from, opps :| Is that a matlab command? Cheers, Paul> Do u want to do a 2-d convolution or just 1-d. > > If 2-d is the case then you can use conv2 and if you > wanto to use fft then you can use fft2.- Hide quoted text - >
