hi all, I"m working on a simulation of comparing OFDM with different modulation schemes (QPSK,QAM) etc'... My question is about the conversion from Es/No to Eb/No I'm not sure if I need to take the cyclic prefix under consideration for instance: Es/No=Eb/No+10log10(log2M * Nc) + 10log10(CodeRate) + ... .. 10log10(Tinf/(Tinf+Tcp)) is the last part correct? where Tinf - is the information period Tcp - is the added Cyclic prefix period Ttot = Tcp+Tinf - thanks
Es/No and Eb/No in OFDM system
Started by ●May 11, 2008
Reply by ●May 12, 20082008-05-12
On May 11, 4:27 pm, "partypooper" <sshango...@hotmail.com> wrote:> hi all, > > I"m working on a simulation of comparing OFDM with different modulation > schemes (QPSK,QAM) etc'... > My question is about the conversion from Es/No to Eb/No > I'm not sure if I need to take the cyclic prefix under consideration > for instance: > > Es/No=Eb/No+10log10(log2M * Nc) + 10log10(CodeRate) + ... > .. 10log10(Tinf/(Tinf+Tcp)) > > is the last part correct? > > where > Tinf - is the information period > Tcp - is the added Cyclic prefix period > Ttot = Tcp+Tinf > > - thanksI didn't check your equation, but I think it is appropriate to include the cyclic prefix as overhead in your Eb/No calculation. When I see Eb/ No, I think "energy per information bit over noise power spectral density". This would suggest that the energy spent on the cyclic prefix doesn't count, much how you must account for the code rate in your calculation. Jason
