I wonder if there is a convenient fast transform available to compute the frequency spectrum with bins distributed in a logarithmic or near- logarithmic frequency scale. Here is the application background. In sound/acoustic/vibration signal processing, it is common to use a so called fractional octave analysis. Usually the cctave resolution is 1/1, 1/3, 1/6, 1/12, 1/24 or 1/48. a 1/3 octave filter bank means each octave will have 3 filters, which are all distributed evenly in the log frequency scale. The existing technology to compute such a octave spectrum are: 1. Use multi-stages of decimation filters. In each stage of decimation, IIR or FIR bandpass filters are applied. The output of each filter is a 'bin" 2. Use multi-stages of decimation filters, in each stage of decimation, FFT is used, after the FFT, filter banks are sythesized using the FFT. 3. Use DFT, where frequencies can be well controlled but the speed of computation is a big problem it would be nice if somebody comes up a fast transform so that the output of spectrum already takes the form of "log-distributed frequency". it does not need to be exactly in log. The frequency of each bins can be like this: 1Hz, 1Hz, ...1Hz, 2Hz, 2Hz, ...2Hz, 4Hz, 4Hz,.....4Hz, ......64Hz, 64Hz, ...64Hz Any idea? James www.go-ci.com
DFT/FFT in log frequency scale...?
Started by ●May 17, 2008
Reply by ●May 17, 20082008-05-17
>I wonder if there is a convenient fast transform available to compute >the frequency spectrum with bins distributed in a logarithmic or near- >logarithmic frequency scale. > >Here is the application background. In sound/acoustic/vibration signal >processing, it is common to use a so called fractional octave >analysis. Usually the cctave resolution is 1/1, 1/3, 1/6, 1/12, 1/24 >or 1/48. a 1/3 octave filter bank means each octave will have 3 >filters, which are all distributed evenly in the log frequency scale. >The existing technology to compute such a octave spectrum are: > >1. Use multi-stages of decimation filters. In each stage of >decimation, IIR or FIR bandpass filters are applied. The output of >each filter is a 'bin" >2. Use multi-stages of decimation filters, in each stage of >decimation, FFT is used, after the FFT, filter banks are sythesized >using the FFT. >3. Use DFT, where frequencies can be well controlled but the speed of >computation is a big problem > >it would be nice if somebody comes up a fast transform so that the >output of spectrum already takes the form of "log-distributed >frequency". it does not need to be exactly in log. The frequency of >each bins can be like this: > >1Hz, 1Hz, ...1Hz, 2Hz, 2Hz, ...2Hz, 4Hz, 4Hz,.....4Hz, ......64Hz, >64Hz, ...64Hz > >Any idea? > >James >www.go-ci.com >Hi, lookup constant-q spectrum or constant-q transform. ida.first.fhg.de/publications/drafts/Bla_constQ.pdf maybe that could be of help. gr. Bjoern
