Hi guys Now I`m studying the Equalizer I`m coding the linear and dfe EQ but there is no different I don`t know what is wrong can you correct this code or give me some idea %%%%DFE(Training+Direct) vs. Linear%%%% clear all; N=1000; % length of the information sequence K=5; actual_isi=[0.2, -0.15, 1.0, 0.21, 0.03]; sigma=0.01; delta=0.08; %0.08 delta2=0.00008; %0.00008 Num_of_realizations=2000; mse_av=zeros(1,N-2*K); mse_avl=mse_av; for j=1:Num_of_realizations, % Compute the average over a number of realizations. % the information sequence p=0.5; info=binornd(1,p,1,1000); infol=info; % the channel output y=filter(actual_isi,1,info); for i=1:2:N, [noise(i) noise(i+1)]=gngauss(sigma); end; y=y+noise; yl=y; param = 0; c0(5) = param; %Precursor Filter Weight Initialization c1(5) = param; c2(5) = param; c3(5) = param; c4(5) = param; d1(5) = param; %Postcursor Filter Weight Initialization d2(5) = param; d3(5) = param; %Linear Weight cl0(5) = param; cl1(5) = param; cl2(5) = param; cl3(5) = param; cl4(5) = param; end; % Now the equalization part follows. %DFE_Training for k=5:N-2*K, %5:N-2*K e(k) = info(k) - [c4(k) c3(k) c2(k) c1(k) c0(k) -d1(k) -d2(k) -d3(k)] * [y(k+4); y(k+3); y(k+2); y(k+1); y(k); info(k-1); info(k-2); info(k-3)]; xes(k) = [c4(k) c3(k) c2(k) c1(k) c0(k) -d1(k) -d2(k) -d3(k)] * [y(k+4); y(k+3); y(k+2); y(k+1); y(k); info(k-1); info(k-2); info(k-3)]; if xes(k) > 0.5 xes2(k) = 1; elseif xes(k) < 0.5 xes2(k) = 0; end c4(k+1) = c4(k) + delta * e(k) * y(k+4); c3(k+1) = c3(k) + delta * e(k) * y(k+3); c2(k+1) = c2(k) + delta * e(k) * y(k+2); c1(k+1) = c1(k) + delta * e(k) * y(k+1); c0(k+1) = c0(k) + delta * e(k) * y(k); d1(k+1) = d1(k) + delta2 * e(k) * info(k-1); d2(k+1) = d2(k) + delta2 * e(k) * info(k-2); d3(k+1) = d3(k) + delta2 * e(k) * info(k-3); %mse(k)=e(k)^2; if k>=500 mu1 = 0.000001; %0.000001 mu2 = 0.00002; %0.00002 e(k) = xes2(k) - [c4(k) c3(k) c2(k) c1(k) c0(k) -d1(k) -d2(k) -d3(k)] * [y(k+4); y(k+3); y(k+2); y(k+1); y(k); xes2(k-1); xes2(k-2); xes2(k-3)]; xes(k+1) = [c4(k) c3(k) c2(k) c1(k) c0(k) -d1(k) -d2(k) -d3(k)] * [y(k+4); y(k+3); y(k+2); y(k+1); y(k); xes2(k-1); xes2(k-2); xes2(k-3)]; if xes(k+1) > 0.5 xes2(k+1) = 1; elseif xes(k+1) < 0.5 xes2(k+1) = 0; end; c4(k+1) = c4(k) + mu1 * e(k) * y(k+4); c3(k+1) = c3(k) + mu1 * e(k) * y(k+3); c2(k+1) = c2(k) + mu1 * e(k) * y(k+2); c1(k+1) = c1(k) + mu1 * e(k) * y(k+1); c0(k+1) = c0(k) + mu1 * e(k) * y(k); d1(k+1) = d1(k) + mu2 * e(k) * xes(k-1); d2(k+1) = d2(k) + mu2 * e(k) * xes(k-2); d3(k+1) = d3(k) + mu2 * e(k) * xes(k-3); %mse(k)=e(k)^2; end; mse(k)=e(k)^2; end; for i = 1:N-2*K error2(i) = (info(i) - xes(i))^2; end; %%%Direct %%%Linear for k=5:N-2*K el(k) = infol(k) - [cl4(k) cl3(k) cl2(k) cl1(k) cl0(k)] * [yl(k+4); yl(k+3); yl(k+2); yl(k+1); yl(k);]; xesl(k) = [cl4(k) cl3(k) cl2(k) cl1(k) cl0(k)] * [yl(k+4); yl(k+3); yl(k+2); yl(k+1); yl(k);]; if xesl(k) > 0.5 xes2l(k) = 1; elseif xesl(k) < 0.5 xes2l(k) = 0; end cl4(k+1) = cl4(k) + delta * el(k) * yl(k+4); cl3(k+1) = cl3(k) + delta * el(k) * yl(k+3); cl2(k+1) = cl2(k) + delta * el(k) * yl(k+2); cl1(k+1) = cl1(k) + delta * el(k) * yl(k+1); cl0(k+1) = cl0(k) + delta * el(k) * yl(k); msel(k)=el(k)^2; end; for i = 1:N-2*K errorl(i) = (infol(i) - xesl(i))^2; end; mse_av=mse_av+mse; mse_avl=mse_avl+msel; mse_av=mse_av/Num_of_realizations; mse_avl=mse_avl/Num_of_realizations;% mean-squared error versus iterations % Plotting commands follow. figure semilogy((abs(error2)),'b');title('DFE Error curve') ; grid on; hold on; figure semilogy((abs(errorl)),'r');title('Linear Error curve') ; grid on; hold on; figure semilogy((abs(mse_av)),'b'); grid on; hold on; semilogy((abs(mse_avl)),'r') ; title('Error curve') ; xlabel('Samples') ylabel('Error value') legend('DFE','Linear'); %'error2','errorl2','DFE','Linear' grid on; hold on;
Linar & DFE Equalizer
Started by ●May 22, 2008
Reply by ●May 22, 20082008-05-22
Just looking at it quickly, your channel's frequency response is fairly flat. Try using a channel with a null at some frequency and see if the results are still very similar.
Reply by ●May 23, 20082008-05-23
>Just looking at it quickly, your channel's frequency response is fairly >flat. Try using a channel with a null at some frequency and see if the >results are still very similar. >%%%%% HI... I have not looked at ur code as it will take time. If you are studying equaliser for first time, try to implement both LE and DFE for channel B of proakis i.e. channel=[0.407 0.815 0.407]; NOw try to implement two cases: 1. When u know channel at RX 2. When u dont knw First try to do for Uncoded case and get the results given in Proakis's book. And then apply coding. For DFE u should get some strange results (i.e. other than what u generally expect) Hope this helps. Feel free to ask any doubt regarding this topic anytime. Chintan
