This problem comes from my simulation of Single Carrier Frequency Domain Equalization(SC-FDE) system. Suppose the symbol rate is Ts, for reason of pulse shaping filtering I perform fractional space sampling with sample rate Ts/2. A FFT block length is 512 and the pilot(used for channel estimation) length is 64. Channel estimation is done as follows: (1) use length 64*2(sampling rate Ts/2) pilot data to estimation channel frequency response H; (2) IFFT transforms H to time response h; (3) padding h with zeros to length 256*2 h1; (4) FFT get length 256*2 frequency response H1. The problem comes: Since H is band-limited to (1+alpha)/Ts (alpha is roll-off factor of shaping filter), the coefficients of H1 are zeros between (1+alpha)/Ts and 2/Ts. But after padding zeros and FFT the resulting H1 has nonzero coefficients between (1+alpha)/Ts and 2/Ts. In fact it fluctuate in the region. If we do symbol rate sampling the result is good because H are generally nonzero, and my simulation shows that no error occurs. While aforementioned channel estimation method brings error even in the absent of noise. Anyone can point out which step is wrong?
Frequency domain interpolation Question
Started by ●May 24, 2008
Reply by ●May 24, 20082008-05-24
"buaawh" <eewuhao@gmail.com> writes:> This problem comes from my simulation of Single Carrier Frequency Domain > Equalization(SC-FDE) system. > > Suppose the symbol rate is Ts, for reason of pulse shaping filtering I > perform fractional space sampling with sample rate Ts/2. A FFT block length > is 512 and the pilot(used for channel estimation) length is 64. Channel > estimation is done as follows: > > (1) use length 64*2(sampling rate Ts/2) pilot data to estimation channel > frequency response H; > (2) IFFT transforms H to time response h; > (3) padding h with zeros to length 256*2 h1; > (4) FFT get length 256*2 frequency response H1. > > The problem comes: Since H is band-limited to (1+alpha)/Ts (alpha is > roll-off factor of shaping filter), the coefficients of H1 are zeros > between (1+alpha)/Ts and 2/Ts. But after padding zeros and FFT the > resulting H1 has nonzero coefficients between (1+alpha)/Ts and 2/Ts. In > fact it fluctuate in the region. > > If we do symbol rate sampling the result is good because H are generally > nonzero, and my simulation shows that no error occurs. While aforementioned > channel estimation method brings error even in the absent of noise. > > Anyone can point out which step is wrong?Perhaps pondering these questions may lead you to your answer: 1. Do you already have timing and carrier offset at the point you perform the H FFT? 2. Are you using raised-cosine filtering? If so, then your H spectrum is not the channel response but the channel response cascaded with the transmitter's root cosine raised filter. You would have to remove the RRC response to obtain the actual channel response. 3. Just hacking off the input data at 64*2 samples is going to convolve your actual channel response with a sinc-like function. 4. Why are you sampling at Ts? You state up front the sample rate (period) is Ts/2. -- % Randy Yates % "My Shangri-la has gone away, fading like %% Fuquay-Varina, NC % the Beatles on 'Hey Jude'" %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Shangri-La', *A New World Record*, ELO http://www.digitalsignallabs.com
>"buaawh" <eewuhao@gmail.com> writes: > >> This problem comes from my simulation of Single Carrier FrequencyDomain>> Equalization(SC-FDE) system. >> >> Suppose the symbol rate is Ts, for reason of pulse shaping filtering I >> perform fractional space sampling with sample rate Ts/2. A FFT blocklength>> is 512 and the pilot(used for channel estimation) length is 64.Channel>> estimation is done as follows: >> >> (1) use length 64*2(sampling rate Ts/2) pilot data to estimationchannel>> frequency response H; >> (2) IFFT transforms H to time response h; >> (3) padding h with zeros to length 256*2 h1; >> (4) FFT get length 256*2 frequency response H1. >> >> The problem comes: Since H is band-limited to (1+alpha)/Ts (alpha is >> roll-off factor of shaping filter), the coefficients of H1 are zeros >> between (1+alpha)/Ts and 2/Ts. But after padding zeros and FFT the >> resulting H1 has nonzero coefficients between (1+alpha)/Ts and 2/Ts.In>> fact it fluctuate in the region. >> >> If we do symbol rate sampling the result is good because H aregenerally>> nonzero, and my simulation shows that no error occurs. Whileaforementioned>> channel estimation method brings error even in the absent of noise. >> >> Anyone can point out which step is wrong? > >Perhaps pondering these questions may lead you to your answer: > >1. Do you already have timing and carrier offset at the point you >perform the H FFT? > >2. Are you using raised-cosine filtering? If so, then your H spectrum is >not the channel response but the channel response cascaded with the >transmitter's root cosine raised filter. You would have to remove the >RRC response to obtain the actual channel response. > >3. Just hacking off the input data at 64*2 samples is going to convolve >your actual channel response with a sinc-like function. > >4. Why are you sampling at Ts? You state up front the sample rate >(period) is Ts/2. >-- >% Randy Yates % "My Shangri-la has gone away, fadinglike>%% Fuquay-Varina, NC % the Beatles on 'Hey Jude'" >%%% 919-577-9882 % >%%%% <yates@ieee.org> % 'Shangri-La', *A New World Record*,ELO>http://www.digitalsignallabs.com >Thanks for your hints on the question, following which I found my mistake: the impulse response is channel response cascaded with RRC pulse shaping filter, resulting a precursor and after ifft the precursor coefficients circularly shift to the last several points. So directly pad zero is wrong. shifting h=[h1, h2] to h'=[h2,h1] and padding zeros on the boundary solve it.
Reply by ●May 27, 20082008-05-27
Randy Yates wrote: ...> 4. Why are you sampling at Ts? You state up front the sample rate > (period) is Ts/2.I just jumped in here, so please excuse any apparent gaffe. Isn't Ts the sampling interval by definition? Or isn't it a sampling interval at all? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
