Hi, I have been refactoring some old SMS code that uses a non-GPL'ed (and probably much slower) fft function from a book called "Numerical Recipes in C." One of the first things I am doing is changing this to use fftw3f... I started by focusing on the resynthesis, which uses the inverse-fft method for synthesizing a bank of sinewaves. But I have run into a brick wall: I thought all would have to do is pack an array of (float) [real0,imag0, real1, imag1, ..., realN, imagN] into a complex array of: [ [0][real,imag], [1][real,imag], ... [N][real,imag] ] //sorry, this is bad notation, but hopefully you get the point but when I run the c2r fft on this, I get junk. Well, it isn't junk, because there are periodic distortions, but I can't figure out what they mean. There is also a big magnitude problem going on, my waveform's magnitude is 300x that of the realft transform! Lastly, there is a strange hole in my waveform... or two actually, and they are consistent. So, hopefully someone with experience can see what I am doing wrong, or suggest ways to further debug this. Here are some plots of the output waveforms from each of the inverse fft algorithms. - horribly distorted fftw on top, realft on bottom: http://www.teafordragons.com/rte/img/sms/fftComparison.png - same as above, but only 256 samples: http://www.teafordragons.com/rte/img/sms/fftComparison-zoomed.png - just the messed up fftw waveform, showing the periodic 'gaps': http://www.teafordragons.com/rte/img/sms/fftw-waveform-zoomed.png - Hide quoted text - The version of "Numerical Recipes in C" used is now obsolete and is online at http://www.nrbook.com/a/bookcpdf.php Chapters 12.2 and 12.3 contain the important code that I am trying to replace, which to me looks identical to the fftw explanations, sadly. The following is a summary of the important parts of the code and I can supply anything else that is necessary: ------------------------------------------------------------------ /* make fftw plan and buffer for Inverse real FFT (complex->real)*/ int initInverseFFTW( SYNTH_PARAMS *pSynthParams) { int sizeFFT = pSynthParams->sizeHop ; pSynthParams->pCfftIn = fftwf_malloc(sizeof(fftwf_complex) * (sizeFFT / 2 + 1)); pSynthParams->pFfftOut = fftwf_malloc(sizeof(float) * sizeFFT); pSynthParams->fftPlan = fftwf_plan_dft_c2r_1d( sizeFFT, pSynthParams->pCfftIn, pSynthParams->pFfftOut, FFTW_ESTIMATE); /*debugging realft */ pSynthParams->realftOut = (float *) calloc((sizeFFT<<1)+1, sizeof(float)); return(1); } /* synthesis of one frame of the deterministic component using the IFFT */ static int SineSynthIFFT (SMS_DATA *pSmsData, float *pFBuffer, SYNTH_PARAMS *pSynthParams) { long sizeFft = pSynthParams->sizeHop << 1; long iHalfSamplingRate = pSynthParams->iSamplingRate >> 1; long sizeMag = pSynthParams->sizeHop; long nBins = 8; long nTraj = pSmsData->nTraj; long iFirstBin, k, i, l, b; float fMag=0, fFreq=0, fPhase=0, fLoc, fSin, fCos, fBinRemainder, fTmp, fNewMag, fIndex; // pFFftBuffer = (float *) calloc(sizeFft+1, sizeof(float)); memset (pSynthParams->realftOut, 0, (sizeFft +1) * sizeof(float)); for (i = 0; i < nTraj; i++) { if (((fMag = pSmsData->pFMagTraj[i]) > 0) && ((fFreq = pSmsData->pFFreqTraj[i]) < iHalfSamplingRate)) { if (pSynthParams->previousFrame.pFMagTraj[i] <= 0) pSynthParams->previousFrame.pFPhaTraj[i] = TWO_PI * ((random() - HALF_MAX) / HALF_MAX); // can fMag here be stored as magnitude instead of DB within smsData? fMag = TO_MAG (fMag); fTmp = pSynthParams->previousFrame.pFPhaTraj[i] + (TWO_PI * fFreq / pSynthParams->iSamplingRate) * sizeMag; fPhase = fTmp - floor(fTmp / TWO_PI) * TWO_PI; fLoc = sizeFft * fFreq / pSynthParams->iSamplingRate; iFirstBin = (int) fLoc - 3; fBinRemainder = fLoc - floor (fLoc); fSin = SinTab (fPhase); fCos = SinTab (fPhase + PI_2); for (k = 1, l = iFirstBin; k <= nBins; k++, l++) { fIndex = (k - fBinRemainder); if (fIndex > 7.999) fIndex = 0; fNewMag = fMag * SincTab (fIndex); if (l > 0 && l < sizeMag) { pSynthParams->realftOut[l*2+1] += fNewMag * fCos; pSynthParams->realftOut[l*2] += fNewMag * fSin; } else if (l == 0) { pSynthParams->realftOut[0] += 2 * fNewMag * fSin; } else if (l < 0) { b = abs(l); pSynthParams->realftOut[b*2+1] -= fNewMag * fCos; pSynthParams->realftOut[b*2] += fNewMag * fSin; } else if (l > sizeMag) { b = sizeMag - (l - sizeMag); pSynthParams->realftOut[b*2+1] -= fNewMag * fCos; pSynthParams->realftOut[b*2] += fNewMag * fSin; } else if (l == sizeMag) { pSynthParams->realftOut[1] += 2 * fNewMag * fSin; } } } pSynthParams->previousFrame.pFMagTraj[i] = fMag; pSynthParams->previousFrame.pFPhaTraj[i] = fPhase; pSynthParams->previousFrame.pFFreqTraj[i] = fFreq; } // fill complex fftw buffer: // pSynthParams->realftOut[i*2] is complex (sin), while fftw_complex[i][0] is real. // so they have to be switched -- I think this is backwards, actually... ARG // shouldn't change anything that drastically in amplitude though for(i = 0; i < (sizeMag/2 +1); i++) { pSynthParams->pCfftIn[i][0] = pSynthParams->realftOut[i*2]; pSynthParams->pCfftIn[i][1] = pSynthParams->realftOut[i*2+1]; } // both versions of fft are done for now for testing fftwf_execute(pSynthParams->fftPlan); realft (pSynthParams->realftOut-1, sizeMag, -1); #ifdef FFTW//not right yet... { //realft needs to be multiplied by 2/n, which is apparently done elsewhere. //... so does this need to be mulitplied by 0.5 because fftw has gain of 1/n ? // well since it is about 300x too big in amp, it isn't the basis of the problem for(i = 0, k = sizeMag; i < sizeMag; i++, k++) pFBuffer[i] += pSynthParams->pFfftOut[k] * pSynthParams->pFDetWindow[i]; for(i= sizeMag, k = 0; i < sizeFft; i++, k++) pFBuffer[i] += pSynthParams->pFfftOut[k] * pSynthParams->pFDetWindow[i]; } #else { for(i = 0, k = sizeMag; i < sizeMag; i++, k++) pFBuffer[i] += pSynthParams->realftOut[k] * pSynthParams->pFDetWindow[i]; for(i= sizeMag, k = 0; i < sizeFft; i++, k++) pFBuffer[i] += pSynthParams->realftOut[k] * pSynthParams->pFDetWindow[i]; } #endif return (1); } ------------------------------------------------------------------ This is my first time using FFTW3, so I wasn't expecting everything to go smoothly. But I am a little stuck... thanks to anyone who can help! regards, rich
swapping realft() for fftw, need help
Started by ●May 29, 2008
