> Yes, I didn't explain it very well. It is usual in CD players > to use digital filters to generate a signal with a much higher > sampling rate, and use analog filters on the result. > Described in terms of the original sample rate, fs, the > filter cutoff will be much higher. I don't know what the > current state-of-the-art is for CD players, though. > > -- glenIn 1985 silicon was expensive so the state of the art was to take the 16 bit signal, oversample it 4x with a 120 tap symmetrical filter using 12 bit quantification of the coefficients, a 16x12 multiplier, a 16 bit accumulator, violently truncate the LSBs, and feed that without dithering to a 16-bit DAC. Some people tended to prefer Vinyl. Nowadays silicon is much cheaper but the budget constraints on the filter implementation still live (ie. get it as cheap as you can) so you can find all the spectrum between "getting it right" and "getting it cheap". => some chips still use 16 bit undithered arithmetic (rare) see philips CD723 and I can tell you it's easy to hear => some die hard fanatics will use DSPs or FPGAs to have high precision math and low rounding errors => the vast majority of the chips are 24 bits and sigma delta with digital processing on-chip. They take 16 or 24 bits as input, oversample with a digital polyphase FIR , usually built with a cascade of 2x interpolators, to be able to easily take various input sample rates (48k,96k,192k etc), then massively oversample to generally about 2-6 MHz, run the thing through a sigma-delta noise shaper, and output it on an assortment of low-bit DACs. Implementation depends on cost, brand, etc, and not all details are mentioned in the datasheet. Usually the datasheets mention : number of taps, number of cascaded oversampling steps, number of bits in the output dacs (between 1 bit for really cheap and multiple 5 bit dacs for high end), number of output dacs (usually 2 since in balanced configuration), output symbol frequency, dynamic element matching, etc. Usually the following are not mentioned : bits of quantization in the tap coefficients, accumulator bits, rounding strategy, and lots of details that inquiring minds would want to know...
cutoff and sampling frequency
Started by ●June 1, 2008
Reply by ●June 6, 20082008-06-06
glen herrmannsfeldt wrote:> John Monro wrote: > (snip) > >>> For a digital filter, it is only the ratio of the filter frequencies >>> to the sample rate that matters. For analog filters, the filter >>> complexity (order) depends on the ratio of the cutoff rate to the >>> frequency. Since most CD players use oversampling and digital >>> filters, it is more likely 16fc and 8fs. (Or whatever the >>> current numbers are.) > >> Glen,I can't grasp the point you are making here. It appears that you >> are saying that the filter order is 16fc and 8fs, which is clearly not >> correct. > > Yes, I didn't explain it very well. It is usual in CD players > to use digital filters to generate a signal with a much higher > sampling rate, and use analog filters on the result. > Described in terms of the original sample rate, fs, the > filter cutoff will be much higher. I don't know what the > current state-of-the-art is for CD players, though.Is there an A-to-D in the loop somewhere? How can one use an analog filter on the signal with the much higher sampling rate? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
glen herrmannsfeldt wrote:> John Monro wrote: > (snip) > >>> For a digital filter, it is only the ratio of the filter frequencies >>> to the sample rate that matters. For analog filters, the filter >>> complexity (order) depends on the ratio of the cutoff rate to the >>> frequency. Since most CD players use oversampling and digital >>> filters, it is more likely 16fc and 8fs. (Or whatever the >>> current numbers are.) > >> Glen,I can't grasp the point you are making here. It appears that you >> are saying that the filter order is 16fc and 8fs, which is clearly not >> correct. > > Yes, I didn't explain it very well. It is usual in CD players > to use digital filters to generate a signal with a much higher > sampling rate, and use analog filters on the result. > Described in terms of the original sample rate, fs, the > filter cutoff will be much higher. I don't know what the > current state-of-the-art is for CD players, though. > > -- glen >In my first posting I was pointing out a typo in Ron's posting, in which he referred to a 'gap' (attenuation) between 2fc and fs. I was pretty sure he meant to say "fc and fs/2." Up to that point the discussion seemed to be around systems in which the sampling rate was only somewhat above the max. signal frequency, and not to oversampled systems. However, you have referred to CD systems where the output to the D/A is oversampled. I don't think you are correct when you say: "Described in terms of the original sample rate, fs, the filter cutoff will be much higher." Having a very high output sample rate certainly eases the restrictions on the anti-alias filter, and one of the things a designer will do is to raise the cut-off frequency, as this allows a simpler anti-alias filter is to be used for a given amount of ripple in the audible pass-band. There is no point though in making the cut-off frequency very much higher than the highest-frequency component in the audio signal, and certainly there is no point in making the cut-off frequency "much higher" than the original sample rate. Regards, John
Reply by ●June 7, 20082008-06-07
John Monro wrote: (snip)> Having a very high output sample rate certainly eases the restrictions > on the anti-alias filter, and one of the things a designer will do is to > raise the cut-off frequency, as this allows a simpler anti-alias filter > is to be used for a given amount of ripple in the audible pass-band. > There is no point though in making the cut-off frequency very much > higher than the highest-frequency component in the audio signal, and > certainly there is no point in making the cut-off frequency "much > higher" than the original sample rate.Someone else posted more details about current CD players than I knew. I won't argue about how much higher it has to be to be "very much higher" or "much higher." It also depends on your reference. With Fs/2 at 22.05kHz, compared to a cutoff that might be 20kHz without oversampling I might say that 30kHz is much higher. Others will disagree. -- glen
>> Having a very high output sample rate certainly eases the restrictions >> on the anti-alias filter, and one of the things a designer will do is >> to raise the cut-off frequency, as this allows a simpler anti-alias >> filter is to be used for a given amount of ripple in the audible >> pass-band. There is no point though in making the cut-off frequency >> very much higher than the highest-frequency component in the audio >> signal, and certainly there is no point in making the cut-off frequency >> "much higher" than the original sample rate.Certainly. You'd want to minimize the frequency response drop close to the cutoff, so some margin would be necessary, but not anything like 100K... perhaps 30-40K or something. Also you want to keep the same analog filter for playing 24-192 and marketing wants to put "50 kHz bandwidth" on the brochure so why not.> Someone else posted more details about current CD players > than I knew. I won't argue about how much higher it has > to be to be "very much higher" or "much higher." It also > depends on your reference. > > With Fs/2 at 22.05kHz, compared to a cutoff that might be > 20kHz without oversampling I might say that 30kHz is > much higher. Others will disagree. > > -- glen >Well say you take good old 16/44 and you want to reconstruct it according to the Nyquist classics (ie pseudo brickwall with sin x/x impulse response), if you don't oversample at all you are going to need an extremely complicated analog filter with expensive, precision components. The first CD players used such filters, 9th order elliptic or something (I read an article about this recently). This is because the first image you want to eliminate is really close to the end of your band of interest... So your analog filter has to : - pass the signal up to 20k while being flat - attenuate sufficiently the first image which starts a 22k ! Easy in DSP, but in analog... yikes ! Also your analog filter has to compensate the sinx/x frequency character of the non-oversampled DAC output. -> lots of opamps -> lots of precision capacitors -> you can't put that in an IC -> very very expensive -> noise and other signal quality problems If you oversample, you might as well go all the way and at least oversample 8x, it will cost you the same as 2x, just a few cents in logic, but your analog filter will be much simpler since the requirements for the analog filter are : - pass the signal up to 20k - attenuate sufficiently the first image which is at 300 kHz Needless to say you can use something simple like a second order Bessel which is nearly free since you were going to need those opamps anyway. And it will sound better (provided you dont do anything stupid in the digital filter like skimp on the bits or forget to dither !) Multibit Sigma Deltas have other requirements, they output a high frequency (2-6 MHz) stream of low (1-6) bit samples and the quantization noise is shaped out of the audio band so the job of the analog filter is more to remove this quantization noise than to complete the job of the digital filter. This is important since there is more noise than signal at the output of a sigma delta converter unless you run it at full scale. Still, the analog filters are simple because they don't need to be super high order. The noise to remove is in high frequencies and, if the delta-sigma is well designed (which means multibit), this noise is UNCORRELATED with the signal unlike the images. The output of any modern current-output sigma delta DAC is essentially high frequency noise whose spectrum extends far past the 2-6 MHz symbol frequency. It is, in reality, not different from what you would find at the output of a 6 Msps DAC since that is exactly what it is. Then you use an opamp as a current-to-voltage converter. If there is on this list someone designing audio equipment, I will take the opportunity to mention an often neglected fact : Consider the classical opamp wired as a current to voltage converter with the - input as a virtual ground connected to the dac's current output. Since the opamp used in those is generally some variant of NE5532 with a low slew rate and GBW, a settling time that is about as fast as grass growing, and an output impedance that quickly becomes uncontrolled above the audio band, there is much more "virtual" than "ground" here so basically the input stage of the opamp, and perhaps the output stage of the DAC, spend some of their time in various unspecified nonlinear states which of course manifests itself as really sucky sound. If you are lucky you get muffled sound with a lack of detail, if you are not lucky you get a strident, harsh signature. The cure is simple, use a much faster opamp that will digest the high frequency noise and essentially design the stuff as if it was connected to a 10 Msps DAC (which it is). Google Hawksford. This should set you back $2 per channel. If you're really on a tight budget you can use plan B which is a common base transistor followed by a RC lowpass and then the opamp filters. Oops, wandered off topic ;)
