On Jun 5, 1:06 pm, John Hadstate <jh113...@hotmail.com> wrote:> On Jun 5, 11:40 am, Giulio Petrucci <sis...@nonono.boh> wrote: > > > John Hadstate ha scritto: > > > > I'm trying exactly the same combination and running into the same > > > problems with regard to documentation and learning curve. > > > Add that AFAIK you should also run ipython... and it can be a problem > > under WinXP (or may be not... anyway to install ipython you have to > > install a lot of other stuff...). > > Are you sure? Maybe I'm missing something, but I thought that the > latest distribution of NumPy eliminated the need to install all that > stuff as individual pieces. My CD has Python 2.5.1, NumPy 1.0.4, > SciPy 0.6, PyWin32 2.10, and a PDF file called scipy_tutorial.pdf by > Travis Oliphant. > > You can find the tutorial on-line athttp://www.tau.ac.il/~kineret/amit/scipy_tutorial/ > I believe it's pretty close to the PDF and the dates are both in > October, 2004. > > You can find more of the latest stuff athttp://www.scipy.org/DownloadYou may also want to look at MATPlotlib - which provides matlab type plotting functions. One thing I found was that the libraries are kind of spread around. Most are in scipy, but I found spline 1d interpolation in MATPlotlib. There are a couple of gotchas which you have to watch when switching from Matlab to Python 1- Most of the time the matrices are created by passing along references, rather than actually copying the data. You have to explicitly tell it to create a copy. E.g. in matlab you could have A=B(2:10), and A is a seperate copy, but in scipy A point to element 2:10 in B, so if you change A you change B. 2 - The default matrix multiply is not what you think. If I recall directly the multiply is an element wise multiplication. And the other multiply tends to give you Kronecker products - There is a way to change this, so it gives the standard matlab type matrix multiply - I believe that is done by importing a different interface than the normal scipy or numpy (It is already defined in one of those libraries). Indexing starts from 0 and something I like is that you can use negative indexes as well i.e. -1 gives the end of a vector. I think the basic signal processing functions are there, but not things like a polyphase interpolation i.e. upfirdn() Hope that helps. Cheers, David
SciPy and DSP
Started by ●June 5, 2008
Reply by ●June 6, 20082008-06-06
> 2 - The default matrix multiply is not what you think. If I recall > directly the multiply is an element wise multiplication. And the other > multiply tends to give you Kronecker products - There is a way to > change this, so it gives the standard matlab type matrix multiply - I > believe that is done by importing a different interface than the > normal scipy or numpy (It is already defined in one of those > libraries).When you say the default multiply is element wise, this is correct if you use things like arange or convert a list to an array. Numpy uses a more generic object "array" and the base type. If you have a "Matrix" type the Matrix multiplications will be the same as Matlab. I personally have found this very useful.
Reply by ●June 9, 20082008-06-09
Hi Dave, Dave ha scritto:> You may also want to look at MATPlotlib - which provides matlab type > plotting functions.I know.> One thing I found was that the libraries are kind of spread around. > Most are in scipy, but I found spline 1d interpolation in MATPlotlib.Yes, I noticed it too...> There are a couple of gotchas which you have to watch when switching > from Matlab to Python[cut] I know... moreover I know python and I'm quite a newbie to MatLab\SciLab\GNU Octave...> Indexing starts from 0 and something I like is that you can use > negative indexes as well i.e. -1 gives the end of a vector.I know and what I most hate in MatLab\SciLab\GNU OCtave is indexing starting from 1... Thanks! Ciao, Giulio -- OnAir: http://www.giuliopetrucci.it http://www.fujikomonamour.com
Steve Underwood wrote:> Vladimir Vassilevsky wrote: > > > I try to be a novelist, and do something that's at least a little bit > novel in everything I do. :-)Returning to the sorrowful and miserable discussion of QPSK, Costas and Gardner, the greatness of Eric and the reinventing of the wheels: obviously there is a relation of BER vs carrier sync bandwidth vs symbol sync bandwidth vs Eb/No. It would be convenient to know that if the QPSK Eb/No is, say, 4dB and if we want the losses due to the imperfect sync to be below 1dB, then the carrier PLL bandwidth should be X and the symbol sync bandwidth should be Y, so the impact of X is equal to the impact of Y. The numbers are easy to derive at Eb/No > 10dB, when everything is linear, but it is not so simple at low SNR. It is not too difficult to get it by simulation however I am pretty sure somebody had already done that. Do you know of a book/article where the results are represented in this form? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Mon, 09 Jun 2008 09:10:57 -0500, Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote:> > >Steve Underwood wrote: >> Vladimir Vassilevsky wrote: >> >> >> I try to be a novelist, and do something that's at least a little bit >> novel in everything I do. :-) > > >Returning to the sorrowful and miserable discussion of QPSK, Costas and >Gardner, the greatness of Eric and the reinventing of the wheels:lol Funny thread for it, tho...>obviously there is a relation of BER vs carrier sync bandwidth vs symbol >sync bandwidth vs Eb/No. It would be convenient to know that if the >QPSK Eb/No is, say, 4dB and if we want the losses due to the imperfect >sync to be below 1dB, then the carrier PLL bandwidth should be X and the >symbol sync bandwidth should be Y, so the impact of X is equal to the >impact of Y. The numbers are easy to derive at Eb/No > 10dB, when >everything is linear, but it is not so simple at low SNR. It is not too >difficult to get it by simulation however I am pretty sure somebody had >already done that. Do you know of a book/article where the results are >represented in this form?I think I know what you mean and I've never seen a book/article treatment on the subject. It's not a hard simulation task, as it is just a loop BW vs BER experiment at various SNRs. I'm guessing it's the sort of thing where a paper would be very appropriate but the reviewers would say something like "this is not new research" and therefore reject it from publication, regardless of how useful it might be. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
