Hello! When I was trying to produce a BIOS configure file in text mode, I was always getting this ERROR: can't find import file 'ti.platforms.generic'. I've tried many times and have checked my source code with the manual to find if their is anything I forgot, but I failed to find any. Would please help me out? The following is the source code I used: /* * Text configuration file (tcf) for tokliBIOS */ /* loading the generic platform */ var params = new Object(); params.clockRate = 192.000000; params.deviceName = "1510"; params.catalogName = "ti.catalog.c5500"; utils.loadPlatform("ti.platforms.generic", params); /* * DSP/BIOS configurations */ /* Disable RTDX */ bios.RTDX.ENABLERTDX = false; /* Disable RTA */ bios.GBL.ENABLEINST = false; /* Disalbe DSP/BIOS trace */ bios.GBL.ENABLEALLTRC = false; bios.GBL.MEMORYMODEL = "LARGE"; bios.MEM.ENABLELOADADDR = false; /* * MEM */ bios.MEM.ARGSSIZE = 0x8; bios.MEM.NOMEMORYHEAPS = false; /* bios.PDROM.destroy(); */ bios.DARAM.base = 0x80; bios.DARAM.len = 0x7f80; bios.DARAM.createHeap = true; bios.DARAM.heapSize = 0x3f80; bios.SARAM.base = 0x8000; bios.SARAM.len = 0xc000; /* FIXME */ bios.SARAM.createHeap = true; bios.SARAM.heapSize = 0x8; // minimum, dummy bios.VECT.base = 0x7fff80; /* bios.VECT.len = 0x80; */ bios.MEM.MALLOCSEG = prog.get("DARAM"); bios.MEM.BIOSOBJSEG = prog.get("DARAM"); /* * CLK */ /* don't use hi-resolution timer */ bios.CLK.HIRESTIME = false; bios.CLK.MICROSECONDS = 10000.0000; /* bios.PRD_clock.order = 1; */ bios.PRD0 = bios.PRD.create("PRD0"); bios.PRD0.period = 1; bios.PRD0.fxn = prog.extern("prd_10ms"); bios.PRD1 = bios.PRD.create("PRD1"); bios.PRD1.period = 100; bios.PRD1.fxn = prog.extern("prd_1s"); /* * HWI */ bios.HWI.STACKMODE = "USE_RETA"; bios.HWI_INT5.fxn = prog.extern("mailbox_interrupt"); bios.HWI_INT5.useDispatcher = 1; bios.HWI_INT13.fxn = prog.extern("wdt_handle"); bios.HWI_INT13.useDispatcher = 1; /* * SWI */ bios.SWI_newmsg = bios.SWI.create("SWI_newmsg"); bios.SWI_newmsg.fxn = prog.extern("mbx_newmsg"); bios.SWI_newmsg.arg0 = 0; bios.SWI_newmsg.arg1 = 0; bios.SWI_newmsg.priority = 1; bios.SWI_newmsg.mailbox = 0; /* * TSK */ bios.TSK.ENABLETSK = true; bios.TSK.STACKSEG = prog.get("DARAM"); bios.TSK.CALLSWITCHFXN = 1; bios.TSK.SWITCHFXN = prog.extern("tok_TSK_switch"); bios.TSK.CALLREADYFXN = 1; bios.TSK.READYFXN = prog.extern("tok_TSK_ready"); bios.TSK_sleep = bios.TSK.create("TSK_sleep"); bios.TSK_sleep.fxn = prog.extern("sleep_dsp"); bios.TSK_sleep.priority = 1; bios.TSK_sleep.exitFlag = 0; bios.TSK_sleep.allocateTaskName = 1; bios.TSK_super = bios.TSK.create("TSK_super"); bios.TSK_super.fxn = prog.extern("supertask"); bios.TSK_super.priority = 15; bios.TSK_super.exitFlag = 0; bios.TSK_super.allocateTaskName = 1; /* * SEM */ bios.SEM_super = bios.SEM.create("SEM_super"); bios.SEM_super.count = 0; bios.SEM_ipbuf_sys_da = bios.SEM.create("SEM_ipbuf_sys_da"); bios.SEM_ipbuf_sys_da.count = 1; bios.SEM_fb = bios.SEM.create("SEM_fb"); bios.SEM_fb.count = 1; /* * HST */ bios.HST.HOSTLINKTYPE = "NONE"; if (config.hasReportedError == false) { prog.gen("tokliBIOS.cdb"); }
can't load platform defination 'ti.platforms.generic'
Started by ●June 10, 2008
