Its known that PSNR (peak signal to noise ratio) is used to compare image quality after compression. Can it also be used for audio quality?
A Fixed-Point Introduction by Example
Handling Spectral Inversion in Baseband Processing
Understanding the Phasing Method of Single Sideband Modulation
An Interesting Fourier Transform 1/f Noise
Before you can participate to the *related sites forums, you need to login or create an account.
