Hi, Its known that Haar filter is the only FIR filter achieves the perfect reconstruction when used in QMF filter. Then why is it not used? Why do people go for longer length filters and pseudo QMF? What are the disadvantages of Haar filter that it cannot be used in QMF filter? Thanks in advance.
Haar Filter for QMF
Started by ●July 5, 2008
Reply by ●July 6, 20082008-07-06
vasindagi wrote:> > Hi, > Its known that Haar filter is the only FIR filter achieves the perfect > reconstruction when used in QMF filter. Then why is it not used? Why do > people go for longer length filters and pseudo QMF? What are the > disadvantages of Haar filter that it cannot be used in QMF filter?The reason the Haar filters work is because the aliasing which is considerable cancels out in the end. So if all you were doing was separating the signal into to channels followed by reconstruction that is the best way to do it. But if you modify the channels before reconstructing the signal then the aliases will no longer cancel and you get noise. For instance if you quantize the high band you get more noise than just the quantization in the high band. You also get noise in the low band from aliases that are no longer canceled. If you could construct a pair of mirror filters with a perfect brick wall frequency response you would also get perfect reconstruction. That is when the frequency responses were squared and summed it would add to a flat response. That would also mean you wouldn't be relying on the aliases to cancel for perfect reconstruction. You can't make perfect filters but you can try to get close. -jim> > Thanks in advance.----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= - Total Privacy via Encryption =---
