I am using simulink model I am importing an image 256*256 from workspace, then to Block processing box, to compress it , o/p of block is 128*128 image , then convert it from 2-d to 1-d using the conversion box then o/p is [16384*1] ,then to frame conversion box,then to RS Encoder . i used 64 for message and 74 for code word length when i connect o/p of RS Encoder to the i/p of RS Decoder , then to conversion box again frm 1-d to 2-d using reshape box [128*128], then to processing box again to uncompress the image it always gives me Block ERROR at Integer input RS ENCODER block "Input must be integer values" and i always got this error , so can any when help??
Error in input of integer RS encoder
Started by ●September 11, 2008
Reply by ●September 11, 20082008-09-11
In article <w7WdnSNxgotZmVTVnZ2dnUVZ_q7inZ2d@giganews.com>, khalloud70 <khalloud70@gmail.com> wrote:>I am using simulink model > >I am importing an image 256*256 from workspace, then to Block processing >box, to compress it , o/p of block is 128*128 image >, then convert it from 2-d to 1-d using the conversion box >then o/p is [16384*1] ,then to frame conversion box,then to RS Encoder . >i used 64 for message and 74 for code word length >when i connect o/p of RS Encoder to the i/p of RS Decoder , then to >conversion box again frm 1-d to 2-d using reshape box [128*128], >then to processing box again to uncompress the image > >it always gives me Block ERROR at Integer input RS ENCODER block >"Input must be integer values" > >and i always got this error , so can any when help?? > >It means exactly what it says: the values you are feeding the RS encoder function must be integers in a certain range, yet you are feeding it a floating point number which is not an integer. You need to fix this. Steve
