generate white noise in assembly
Started by hbarcellos ●October 9, 2008
>>>>> "glen" == glen herrmannsfeldt <gah@ugcs.caltech.edu> writes:
glen> Raymond Toy wrote: glen> (snip, I wrote) glen> This is true if m is a power of two. I believe it isn't necessarily glen> true if m is not a power of two. It is very common, though, for m glen> to be a power of two. Otherwise, if I need random low bits I divide glen> by a prime number sort of near sqrt(m) before using it. >> Do you take the remainder as the random number? If so, this has a >> bias, so the result isn't quite uniform. May or may not matter. glen> Divide by some fairly large prime, then mod the (small) number Divide meaning an integer divide, and using the quotient, ignoring the remainder? Yeah, that probably works well. But this being a DSP group, maybe the bias would go away if you take, say the top 8 or 16 bits, pretend it's a fraction (Q8 or Q16) and multiply by 6, and take the integer part. I think that has no bias, except whatever is introduced by the original random number generator. Ray
