Hai, I am new to DSP.I have to do upscaling and downscaling of a image and implemented in FPGA.I referred resources and understood the bilinear method with FIR filter used for this.. I knew about the basic FIR filter.I want to know the following: 1.Any standard method or algorithms which can do upscaling and downscaling the image..Pls suggest the link and the method and its equation.. 2.And also suggest do i need to use cascaded version of FIR filter or 2D FIR filter or polyphase FIR filter...Which one is most recommended as per the standard method. 3.Can i use a 2D -FIR filter for both upscaling and downscaling a image without zero padding? Pls share u r views with to proceed further.. regards, raj
standard algorithm
Started by ●October 15, 2008
Reply by ●October 16, 20082008-10-16
On Oct 15, 5:07�am, raj <rajesh.o...@gmail.com> wrote:> Hai, > > I am new to DSP.I have to do upscaling and downscaling of a image and > implemented in FPGA.I referred resources and understood the bilinear > method with FIR filter used for this.. > > I knew about the basic FIR filter.I want to know the following: > > 1.Any standard method or algorithms which can do upscaling and > downscaling the image..Pls suggest the link and the method and its > equation.. > > 2.And also suggest do i need to use cascaded version of FIR filter or > 2D FIR filter or polyphase FIR filter...Which one is most recommended > as per the standard method. > > 3.Can i use a 2D -FIR filter for both upscaling and downscaling a > image without zero padding? > > Pls share u r views with to proceed further.. > > regards, > rajThe solution to your problem is to study or hire someone who did. Dirk
On Oct 15, 5:07�am, raj <rajesh.o...@gmail.com> wrote:> Hai, > > I am new to DSP.I have to do upscaling and downscaling of a image and > implemented in FPGA.I referred resources and understood the bilinear > method with FIR filter used for this.. > > I knew about the basic FIR filter.I want to know the following: > > 1.Any standard method or algorithms which can do upscaling and > downscaling the image..Pls suggest the link and the method and its > equation.. > > 2.And also suggest do i need to use cascaded version of FIR filter or > 2D FIR filter or polyphase FIR filter...Which one is most recommended > as per the standard method. > > 3.Can i use a 2D -FIR filter for both upscaling and downscaling a > image without zero padding? > > Pls share u r views with to proceed further.. > > regards, > rajThere are a myriad ways to resample an image. Common approaches use bilinear or bicubic interpolation. An old but coarse way is to use the nearest neighbor. You can even use a sin(x)/x interpolation. There are a host of computer graphics books that cover these common algorithms. Try a visit to your university library and look up image processing. Clay
Reply by ●October 17, 20082008-10-17
> 1.Any standard method or algorithms which can do upscaling and > downscaling the image..Pls suggest the link and the method and its > equation..It should be somewhat like the conventional signal processing for 1-D signal, upsampling then filtering off some images; anti-alias filtering then downsampling. And 2D filters should be used in filtering process.> 2.And also suggest do i need to use cascaded version of FIR filter or > 2D FIR filter or polyphase FIR filter...Which one is most recommended > as per the standard method. > > 3.Can i use a 2D -FIR filter for both upscaling and downscaling a > image without zero padding?> Pls share u r views with to proceed further.. > > regards, > raj
