relationship between time/frequency offset compensation and channel equalization
Started by minnows November 18, 2008
Hi, All
   i am really confused of these two concept.
   time/frequency offset will cause signal distortion but this distortion
can be recoverd by channel equalization.
   what's the difference between time/frequency offset compensation and
channel equalization?
   Thank you!
On Nov 18, 3:58&#2013266080;am, "minnows" <minn...@tom.com> wrote:
> Hi, All > &#2013266080; &#2013266080;i am really confused of these two concept. > &#2013266080; &#2013266080;time/frequency offset will cause signal distortion but this distortion > can be recoverd by channel equalization. > &#2013266080; &#2013266080;what's the difference between time/frequency offset compensation and > channel equalization? > &#2013266080; &#2013266080;Thank you!
One difference is channel equalization usually accounts for and corrects dispersion and multipath distortion and frequency offset is just that. You figure out the freq error and mix it out. IHTH, Clay
may be the range that you wanna compensate would be differ.. last time, i use some pll and agc algorithms time/ frequency offset compensation of ADC and mixer's time and frequency offset. they fluctuate within relatively small error.. thus need some simple algorithms... rather than higher order algorithms...
