m26k9 wrote:>> The first F in FFT, the part that makes it fast, is building >> up larger transforms from smaller ones. Once you understand >> that, the answer to your question is obvious. >> >> What I am still interested in seeing is 150000000 sample >> FFT's, such as a whole CD. At that size, you have to be >> a little careful with memory usage. >> >> -- glen >> >> > > Thanks a lot Glen. > > I honestly have no clear understanding as to how FFT is doing the DFT. > I will look in to that. > > I am actually working on OFDM systems. So the transmitter is doing a the > DFT on its N-point data by feeding these N-samples to the FFT module. My > concern is, if the transmitter is equipped with a FFT module that takes in > N samples (designed to take N-samples) at a time, if there is an efficient > method to perform a 2N FFT operation with that N-point FFT module. > > Maybe I am understanding this all wrong. My idea of an N-point FFT module > is that of a DSP, with N inputs an I feed my N-points these inputs in > parallel and I get a N outputs. I know in scalable-OFDM I can have > different values of N(512,1024, etc.), but is there a 'maximum' number of > inputs to an FFT module? > > Thank you again. I think I will look into the internal of a FFT.The inputs to a Fourier transform are individual samples taken at regular intervals in time. They are acquired as a serial stream. If fed to a digital-to-analog converter, they would reproduce the original signal. (Provided that the proper filters are used before the analog-to-digital converter and after the digital-to-analog converter.) You probably also want to read earlier chapters about sampling. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Any method to FFT/DFT a long sequence
Started by ●November 27, 2008
Reply by ●November 28, 20082008-11-28
Glen Herrmannsfeldt wrote:>What I am still interested in seeing is 150000000 sample >FFT's, such as a whole CD. At that size, you have to be >a little careful with memory usage.Glen - three of the following might do it: http://www.dilloneng.com/fft_ip/ulfft/ultralong-fft-ip-core-for-xilinx-fpgas With a radix3 front end, you'd split the data into three streams and then you could do a 64M FFT on each using three of the above. (PS: I have no commercial interest or connection with the above company, and have never used any of their products). As for m26k9, of course you can combine smaller transforms into larger ones, but I agree with Jerry that you need to do a lot more reading. One of my favorites was an old textbook: L. R. Rabiner, B. Gold, Theory and Application of Digital Signal Processing. Englewood Cliffs, NJ, Prentice-Hall, 1975. Sure, it's dated with regard to some things, but it's got several good sections on FFT (often available at a local university library, or used copies at amazon.com). Kevin
Thanks a lot guys. Seems the number of FFT points are not a limitation since they can be fed serially. I will have to read about FFT first before going any further. Thanks for links Kevin. Didnt know such a 'huge' number of FFTs can be supported. Appreciate the help guys.
Reply by ●December 7, 20082008-12-07
On Fri, 28 Nov 2008 02:29:31 -0600, "m26k9" <maduranga.liyanage@gmail.com> wrote:> > >Thanks a lot guys. > >Seems the number of FFT points are not a limitation since they can be fed >serially. I will have to read about FFT first before going any further. > >Thanks for links Kevin. Didnt know such a 'huge' number of FFTs can be >supported. > >Appreciate the help guys.Hi, You might have a look at: http://www.dsprelated.com/showarticle/63.php Good Luck, [-Rick-]
