On Dec 14, 7:36�pm, buleg...@columbus.rr.com wrote:> On Dec 14, 9:12�am, communications_engin...@yahoo.com wrote: > > > > > BUT do negative frequency means the orientation of the sinusoid (for > > e.g) right? Correct me if I'm wrong ... Also what is the practical > > significance of using an imaginary component when we are dealing with > > a quadrature composite signal. If I may also ask does 'j' represent > > orthonormal signals ?- Hide quoted text - > > > - Show quoted text - > > Negative frequency is really only relevent in the complex domain. �A > sinusoidal signal is comprised of two phasors: A negative frequency > phasor, and a positive frequency phasor. �Thes two complex > exponentials add up to make a real sinusoid. > > I have built some flash programs that illustrate how phasors add up to > make sinusoids: > > http://www.fourier-series.com/fourierseries2/complex_tutorial.html > > You want to work with complex numbers because you don;t really > understand how sinusoidal motion (as a solution to a differential > equation) makes sense, until you can see the complex exponentials.Yup, I visited your site, the flash programs are very informative.
confused about complex signal
Started by ●December 7, 2008
Reply by ●December 15, 20082008-12-15
