On Dec 29, 11:52�am, charanchar <charanc...@gmail.com> wrote:> have u got any solution for getting gaussian noise(100 samples) with > exactly zero mean and variance=1 in matlab?If you have 100 samples of actual Gaussian noise, you can easily force the mean and variance of the 100 samples to be exactly 0 and 1 respectively. It is a trivial problem. Dirk
gaussian noise
Started by ●December 29, 2008
Reply by ●December 29, 20082008-12-29
Reply by ●December 30, 20082008-12-30
On Dec 29, 12:59�pm, charanchar <charanc...@gmail.com> wrote:> On Dec 29, 10:43�pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote: > > > > > charanchar wrote: > > > On Dec 29, 10:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: > > >> charanchar wrote: > > >>> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> > > >>> wrote: > > >>>>> have u got any solution for getting gaussian noise(100 samples) with > > >>>>> exactly zero mean and variance=1 in matlab? > > >>>> help randn > > >>> it will not give the random noise with mean=0 and var=1. mean and var > > >>> will change as seed value changes. they are not fixed > > >> I think you are confusing a random process with a sample thereof. > > > >> If you take a Gaussian random process with mean = 0 and variance = 1, > > >> and take 100 samples, you will _not_ get sample sets with mean = 0 and > > >> variance = 1. �What you'll get is samples whose means and variances are > > >> themselves random variables, with _expected_ values of 0 and 1, > > >> respectively. > > > >> A Gaussian process that is guaranteed to generate a mean = 0 and > > >> variance = 1 for every 100 sample set would not be i.i.r., if it were > > >> even possible in general. > > > >> -- > > > >> Tim Wescott > > >> Wescott Design Serviceshttp://www.wescottdesign.com > > > >> Do you need to implement control loops in software? > > >> "Applied Control Theory for Embedded Systems" gives you just what it says. > > >> See details athttp://www.wescottdesign.com/actfes/actfes.html > > > thank u Tim, that is if we run the process several times, then the > > > average of all means will be zero and var will be 1. am i correct? > > > No. �You can only guarantee a particular mean and variance by generating > > an infinite number of samples. > > > However, given a set of 100 samples, you can normalise them to have zero > > sample-mean and unit sample-variance. > > > -- > > Oli > > yes that is correct. > my problem is for phase noise correction algorithm in ofdm system, i > want to introduce phase noise as wiener process. for example if we set > variance(using randn in matlab) as .1 that var is changing from symbol > to symbol by + or - .02. this small change will affect the estimation > badly. becoz the ofdm is more sensitive to phase noiseHave you seen this site which provides Matlab code? http://www.engineering.ucsb.edu/~moehlis/APC591/tutorials/tutorial7/node2.html John
