Hello, I was hoping that someone might know how to compute an error covariance matrix for an H infinity filter when the noise terms are known to be uncorrelated white and Gaussian. I suspect that P (defined below) is the error covariance matrix since it becomes that when configured to be equivalent to a Kalman filter. However, based on my understanding of H infinity theory P is not an error covariance matrix... P(k+1) = F(k) P(k)[ I - theta S(k) P(k) + H'(k)R(k)^(-1)H(k)P(k)]^(-1)F (k)' + Q(k) Thanks, - Peter
H infinity error covariance matrix
Started by ●January 26, 2009
Reply by ●January 29, 20092009-01-29
On Jan 27, 12:37�pm, dihydro...@gmail.com wrote:> Hello, > > I was hoping that someone might know how to compute an error > covariance matrix for an H infinity filter when the noise terms are > known to be uncorrelated white and Gaussian. � I suspect that P > (defined below) is the error covariance matrix since it becomes that > when configured to be equivalent to a Kalman filter. �However, based > on my understanding of H infinity theory P is not an error covariance > matrix... > > P(k+1) = F(k) P(k)[ I - theta S(k) P(k) + H'(k)R(k)^(-1)H(k)P(k)]^(-1)F > (k)' + Q(k) > > Thanks, > - PeterDoesn't mean much without explaining the symbols. For H infinity you have a lambda term somewhere from teh cost function and the noise covariance matrices don't come into it. Hardy
Reply by ●February 26, 20092009-02-26
On Jan 29, 4:21�am, HardySpicer <gyansor...@gmail.com> wrote:> On Jan 27, 12:37�pm, dihydro...@gmail.com wrote: > > > Hello, > > > I was hoping that someone might know how to compute an error > > covariance matrix for anHinfinityfilter when the noise terms are > > known to be uncorrelated white and Gaussian. � I suspect that P > > (defined below) is the error covariance matrix since it becomes that > > when configured to be equivalent to a Kalman filter. �However, based > > on my understanding ofHinfinitytheory P is not an error covariance > > matrix... > > > P(k+1) = F(k) P(k)[ I - theta S(k) P(k) +H'(k)R(k)^(-1)H(k)P(k)]^(-1)F > > (k)' + Q(k) > > > Thanks, > > - Peter > > Doesn't mean much without explaining the symbols. For H infinity you > have a lambda term somewhere from teh cost function and the noise > covariance matrices don't come into it. > > HardyJust noticed that someone had replied. Here is a more detailed explanation: System equations: x(k+1) = F(k) x(k) + w(k) y(k) = H(k) x(k) + v(k) z(k) = L(k) x(k) In this specific case w(k) and v(k) are independent white Gaussian processes, which is not true for h infinity filters in general. The cost function is the following: J_1 = sum[k=0...N-1 , ||z(k)-\hat{z}(k)||^2_{S(k)} ] -------------------------------------------------------------------------------------------------- ||x(0) - \hat{x}(0)||^2 _(P(0)^{-1}) + sum[k=0...N-1 , (||w(k)|| ^2_{Q(k)^-1} + ||v(k)||^2_{R(k)^-1})] and J_1 < 1 / theta The notation ||a||^2_{B} = a'Ba. In this cost function the noise terms do come into play. In my situation L and S(k) are set to identity matrices and the noise terms are all assumed to be Gaussian. I'm wondering if anyone has already shown that P(k+1), defined in the first message, is an error covariance matrix in this situation. If in addition theta is set to zero, then it becomes equivalent to a Kalman filter and P(k+1) is an error covariance matrix. Thanks, - Peter
