Hi all, In a technical report, they use the following technique which I do not fully understand: The objective is to implement function y=f(x) using LUT. x is a 4 bit positive integer (range from 0 to 2^4-1). (The actual number in the report is much larger but let's take 4 bits for the sake of simplicity). x=0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15. Due to the hardware difficulty, they use only a LUT with 2^3 entries (i.e. each entry has a 3-bit address). The basic idea of their implementation is to subsample f(x), and then take the linear interpolation. And from the report, I see they use right-shift operator for subsampling. For example for an integer x, to determine its lower bound entry in the 3-bit-add LUT they use x>>1. What I am confused is that what samples will be picked up to populate the 3-bit-add LUT? They are likely f(0), f(2), f(4), f(6), f(8), f (10), f(12), f(14). But if so, how to interpolate to get the value of f(15)? I am really confused. Assume you need to do this task, f(x) where x is from 0 to 15. And you have only 3 bit add LUT? what should you do? Thanks a lot.
Question about down-sample using right shift, and then interpolation?
Started by ●January 31, 2009
Reply by ●January 31, 20092009-01-31
A.E lover <aelover11@gmail.com> wrote:>I am really confused. Assume you need to do this task, f(x) where x is >from 0 to 15. And you have only 3 bit add LUT? what should you do?y = x == 15 ? f(15) : x & 1 ? (g(y>>1) + g((y>>1)+1))/2 : g(y>>1); Where g() is the decimated lookup table with 8 entries. Not so traumatic, I don't think. s.
Thanks Steve, but sorry, I do not understand your "pseudo-codes". Would any one can inteprate Steve's codes in plain text for me? Thank you. Regards, On Jan 31, 5:01�pm, spop...@speedymail.org (Steve Pope) wrote:> A.E lover <aelove...@gmail.com> wrote: > >I am really confused. Assume you need to do this task, f(x) where x is > >from 0 to 15. And you have only 3 bit add LUT? what should you do? > > y = x == 15 ? f(15) : x & 1 ? (g(y>>1) + g((y>>1)+1))/2 : g(y>>1); > > Where g() is the decimated lookup table with 8 entries. > > Not so traumatic, I don't think. > > s.
OK I see Steve. I did not recognize that you use inline function in C to describe your work. Now I understand your idea. But maybe you meant g(x>>1)... in your codes. However even that, you still need some type of memory to store f(15), don't you? That is not acceptable in the technical report I am refering to. Moreover, what if now OUT is 2 bit (i.e. they have only 2- bit- address LUT ). The original range is x=0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15. I guess after down sampling, the sampled x (denoted as x_s) will be: x_s=0 4 8 12. And the 2-bit LUT will store f(x_s). If so how to obtain the rest: f(13), f(14) and f(15)? Do I need to store f(15) too so that I can take the interpolation. If so the LUT now will need 3 bit for addressing f(15) and waste some address numbers pointing to nothing. I am very confused. Or you guys have another way to down sample f(x). Please help me, hardware people. Thanks. On Jan 31, 2:01�pm, spop...@speedymail.org (Steve Pope) wrote:> A.E lover <aelove...@gmail.com> wrote: > >I am really confused. Assume you need to do this task, f(x) where x is > >from 0 to 15. And you have only 3 bit add LUT? what should you do? > > y = x == 15 ? f(15) : x & 1 ? (g(y>>1) + g((y>>1)+1))/2 : g(y>>1); > > Where g() is the decimated lookup table with 8 entries. > > Not so traumatic, I don't think. > > s.
Reply by ●February 1, 20092009-02-01
A.E lover <aelover11@gmail.com> wrote:>OK I see Steve. I did not recognize that you use inline function in C >to describe your work. Now I understand your idea. But maybe you meant >g(x>>1)... in your codes.Yes, sorry, that was a typo, the y's on the right hand side should be x's.>However even that, you still need some type of memory to store f(15), >don't you?f(15) is a scalar constant. There is almost no hardware cost to a scalar constant. Steve
