Hello, Is it possible to intelligently smooth an experimentally gathered frequency response? I have input and output time history signals, to which I apply an in-house FFT/windowing/smoothing program to compute the gain, phase, and coherence. I then compare the results to an analytically generated response. On many of these runs, the higher end of the measured frequency response is very "noisy" in all 3 components. I was wondering if it is possible to sensibly "filter" the magnitude & phase curves to eliminate this noise. Is there some theoretical reason, for example, that the slope of the magnitude and phase curves is limited somehow? I know that (for non-minimum phase systems) that there is a certain relationship between the magnitude and phase curves, but I don't think I can use that fact since both curves are very noisy in the same frequency range Thanks Roy
"Smoothing" a Frequency Response
Started by ●February 21, 2009
Reply by ●February 21, 20092009-02-21
On Feb 21, 6:28�pm, Roy <brewer....@gmail.com> wrote:> Hello, > > Is it possible to intelligently smooth an experimentally gathered > frequency response? I have input and output time history signals, to > which I apply an in-house FFT/windowing/smoothing program to compute > the gain, phase, and coherence. I then compare the results to an > analytically generated response. On many of these runs, the higher end > of the measured frequency response is very "noisy" in all 3 > components. I was wondering if it is possible to sensibly �"filter" > the magnitude & phase curves to eliminate this noise. Is there some > theoretical reason, for example, that the slope of the magnitude and > phase curves is limited somehow? I know that (for non-minimum phase > systems) that there is a certain relationship between the magnitude > and phase curves, but I don't think I can use that fact since both > curves are very noisy in the same frequency range > > Thanks > RoyYou need to average the FFTs over successive runs. Hardy
Thanks. These signals are so "noisy" that I suspect it would take many runs to produce a "clean" signal. Is there a way to get the results without averaging multiple runs? I'd rather have my test team spend less time in the lab, if at all possible. - Roy On Feb 21, 1:13�am, HardySpicer <gyansor...@gmail.com> wrote:> > You need to average the FFTs over successive runs. > > Hardy
On Feb 21, 12:28�am, Roy <brewer....@gmail.com> wrote:> Hello, > > Is it possible to intelligently smooth an experimentally gathered > frequency response? I have input and output time history signals, to > which I apply an in-house FFT/windowing/smoothing program to compute > the gain, phase, and coherence. I then compare the results to an > analytically generated response. On many of these runs, the higher end > of the measured frequency response is very "noisy" in all 3 > components. I was wondering if it is possible to sensibly �"filter" > the magnitude & phase curves to eliminate this noise. Is there some > theoretical reason, for example, that the slope of the magnitude and > phase curves is limited somehow? I know that (for non-minimum phase > systems) that there is a certain relationship between the magnitude > and phase curves, but I don't think I can use that fact since both > curves are very noisy in the same frequency range > > Thanks > RoyThere's no theoretical reason for the slope of either curve to be limited. Think of the simple example of a pure bin-centered sinusoid, which will look like a Kronecker delta in the magnitude output. I believe you can get "smoother-looking" (yes, I know that's a qualitative conclusion) results using parametric PSD-estimation algorithms (e.g. linearly-constrained, minimum-variance or LCMV estimation); I don't have any references handy right now. Alternatively, the easiest way to decrease the variance in your PSD estimates is to average multiple FFTs. You can use Welch's method of overlapping FFTs and averaging them together to give you a nicer- looking estimate. Jason
>Hello, > >Is it possible to intelligently smooth an experimentally gathered >frequency response? I have input and output time history signals, to >which I apply an in-house FFT/windowing/smoothing program to compute >the gain, phase, and coherence. I then compare the results to an >analytically generated response. On many of these runs, the higher end >of the measured frequency response is very "noisy" in all 3 >components. I was wondering if it is possible to sensibly "filter" >the magnitude & phase curves to eliminate this noise. Is there some >theoretical reason, for example, that the slope of the magnitude and >phase curves is limited somehow? I know that (for non-minimum phase >systems) that there is a certain relationship between the magnitude >and phase curves, but I don't think I can use that fact since both >curves are very noisy in the same frequency range > >Thanks >RoyI am by no means an expert, or even very competent in dsp. That being said, I had a similar problem but with the lower frequencies. If the "noise" is confined to a frequency range, it sounds like it might be a background spectrum that you could remove. In my case, I was able to significantly clean my signal by averaging over many signals (as already suggested), and subtracting the background spectrum from any new incoming spectrum. I determined the background spectrum by taking a samples of just the background initially before I started my experiment.
The way you choose your windowing in the time domain may also have some significant influence on your computed frequency response...
Okay, I guess the message is to do more runs. Does anyone know of any good reference works for this? Or how to best window & average. Thanks for all your help. - Roy On Feb 21, 1:02�pm, Sebastian Doht <seb_d...@lycos.com> wrote:> The way you choose your windowing in the time domain may also have some > significant influence on your computed frequency response...
Reply by ●February 22, 20092009-02-22
Roy schrieb:> Okay, I guess the message is to do more runs. Does anyone know of any > good reference works for this? Or how to best window & average. > > Thanks for all your help. > > - Roy > > > On Feb 21, 1:02 pm, Sebastian Doht <seb_d...@lycos.com> wrote: >> The way you choose your windowing in the time domain may also have some >> significant influence on your computed frequency response... >Doing more runs is always a good idea, but I was refering to the effect of time windowing on non-periodic signals (or periodic signals without synchronization) in the frequency domain. So I do not know what your inhouse smoothing/windowing/fft does and you do not have to tell me, but if it is using only rectangular non-overlapping windows some of the mess you see might be the result from spectral leakage. But that was just a guess...
