Which book to follow for learning c6713
Started by commengr April 13, 2009
Hello, I want to learn to use Texas Instruments DSP c6713 and I have heard
that Dr. Rulph Chassaing's book on it is best (DSP with applications to
c6713 & c6416)
Now, my question is that, there ar two editions of the book
First one is written by Dr. Chassaing himself
Second edition is written by another author after Dr. Chassaing's death,
using excerpts from the first edition.
The author claims that the second edition is more narrative than the
first. So I ask to tell me about their experience on using the books as I
can only buy one
So advise
commengr wrote:
> Hello, I want to learn to use Texas Instruments DSP c6713 and I have heard > that Dr. Rulph Chassaing's book on it is best (DSP with applications to > c6713 & c6416) > > Now, my question is that, there ar two editions of the book > > First one is written by Dr. Chassaing himself > > Second edition is written by another author after Dr. Chassaing's death, > using excerpts from the first edition. > > The author claims that the second edition is more narrative than the > first. So I ask to tell me about their experience on using the books as I > can only buy one > > So advise
All that you need to program the 6713 are the original 6713 manuals and datasheets downloadable from TI web site. Somebody's interpretations of the original documents only create a mess and confusion. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Apr 13, 7:23&#2013266080;am, "commengr" <communications_engin...@yahoo.com>
The main aim of "Digital Signal Processing and Applications with the TMS320C6713 and TMS320C6416 DSK" is to teach/illustrate digital signal processing concepts using practical, hands-on, real-time example programs in order to process analogue audio frequency signals (the C6713 and C6416 DSKs have audio codecs by way of analogue i/o.) Most of the example programs are written in C and therefore much of the code in a particular example is not specific to a particular processor. Having said that, the architectures of the C6713 and C6416 are described and some assembly language example programs are included in the book. The second edition of the book contains quite a few more example programs than the first edition and is expanded particularly with respect to analogue i/o, IIR filters, FFT, adaptive filters, and the use of DSP/BIOS. Where errors were found in example programs in the first edition of the book, these have been corrected. The project files provided with the second edition, and the detailed instructions on how to install and run the example programs, are compatible with version 3 of Code Composer. That is not the case with the first edition, although I've seen the steps/modifications necessary to use the first edition with version 3 of Code Composer discussed on the internet (or I could advise.) Hope this helps.
>On Apr 13, 7:23=A0am, "commengr" <communications_engin...@yahoo.com> >wrote: >> Hello, I want to learn to use Texas Instruments DSP c6713 and I have
hear=
>d >> that Dr. Rulph Chassaing's book on it is best (DSP with applications
to
>> c6713 & c6416) >> >> Now, my question is that, there ar two editions of the book >> >> First one is written by Dr. Chassaing himself >> >> Second edition is written by another author after Dr. Chassaing's
death,
>> using excerpts from the first edition. >> >> The author claims that the second edition is more narrative than the >> first. So I ask to tell me about their experience on using the books as
I
>> can only buy one >> >> So advise > >The main aim of "Digital Signal Processing and Applications with the >TMS320C6713 and TMS320C6416 DSK" is to teach/illustrate digital signal >processing concepts using practical, hands-on, real-time example >programs in order to process analogue audio frequency signals (the >C6713 and C6416 DSKs have audio codecs by way of analogue i/o.) Most >of the example programs are written in C and therefore much of the >code in a particular example is not specific to a particular >processor. Having said that, the architectures of the C6713 and C6416 >are described and some assembly language example programs are included >in the book. > >The second edition of the book contains quite a few more example >programs than the first edition and is expanded particularly with >respect to analogue i/o, IIR filters, FFT, adaptive filters, and the >use of DSP/BIOS. Where errors were found in example programs in the >first edition of the book, these have been corrected. > >The project files provided with the second edition, and the detailed >instructions on how to install and run the example programs, are >compatible with version 3 of Code Composer. That is not the case with >the first edition, although I've seen the steps/modifications >necessary to use the first edition with version 3 of Code Composer >discussed on the internet (or I could advise.) > >Hope this helps. >
Thanks to all
On Apr 18, 3:09&#2013266080;pm, "Syed Shah Sindhi" <shah_z...@yahoo.com> wrote:
> >On Apr 13, 7:23=A0am, "commengr" <communications_engin...@yahoo.com> > >wrote: > >> Hello, I want to learn to use Texas Instruments DSP c6713 and I have > hear= > >d > >> that Dr. Rulph Chassaing's book on it is best (DSP with applications > to > >> c6713 & c6416) > > >> Now, my question is that, there ar two editions of the book > > >> First one is written by Dr. Chassaing himself > > >> Second edition is written by another author after Dr. Chassaing's > death, > >> using excerpts from the first edition. > > >> The author claims that the second edition is more narrative than the > >> first. So I ask to tell me about their experience on using the books as > I > >> can only buy one > > >> So advise > > >The main aim of "Digital Signal Processing and Applications with the > >TMS320C6713 and TMS320C6416 DSK" is to teach/illustrate digital signal > >processing concepts using practical, hands-on, real-time example > >programs in order to process analogue audio frequency signals (the > >C6713 and C6416 DSKs have audio codecs by way of analogue i/o.) Most > >of the example programs are written in C and therefore much of the > >code in a particular example is not specific to a particular > >processor. Having said that, the architectures of the C6713 and C6416 > >are described and some assembly language example programs are included > >in the book. > > >The second edition of the book contains quite a few more example > >programs than the first edition and is expanded particularly with > >respect to analogue i/o, IIR filters, FFT, adaptive filters, and the > >use of DSP/BIOS. Where errors were found in example programs in the > >first edition of the book, these have been corrected. > > >The project files provided with the second edition, and the detailed > >instructions on how to install and run the example programs, are > >compatible with version 3 of Code Composer. That is not the case with > >the first edition, although I've seen the steps/modifications > >necessary to use the first edition with version 3 of Code Composer > >discussed on the internet (or I could advise.) > > >Hope this helps. > > Thanks to all
yeah thanks
