Autocorrelation matrix of a long sequence
Started by sasuke April 16, 2009
Hi
I am using MATLAB to generate close to 10^8 samples of a Rayleigh fading
channel using Jakes method. Once I generate these samples, I have to then
create a 20 x 20 autocorrelation matrix. I am using MATLAB to do this.
MATLAB works perfectly for 10^6 samples, but once the number of samples
increases slightly above 50 * 10^6, MATLAB throws an "OUT of Memory" error.
I tried some techniques given in www.mathworks.com to overcome this
problem, but they dont seem to help once the number of samples goes above
10^7.
My question is, does anyone know of a technique to compute the
autocorrelation matrix for such a long sequence quickly and accurately. I
have heard that the autocorrelation can be computed using FFT. I tried to
lay my hands on "Fast Algorithms for Digital Signal Processing" book, but
could not. Can somebody guide me to any resources explaining this method or
any other method which will help me out through the above said problem.
Please let me know
Thanks
Aloknath
On Apr 16, 5:39&#4294967295;pm, "sasuke" <a.ssjg...@gmail.com> wrote:
> Hi > > I am using MATLAB to generate close to 10^8 samples of a Rayleigh fading > channel using Jakes method. Once I generate these samples, I have to then > create a 20 x 20 autocorrelation matrix. I am using MATLAB to do this. > MATLAB works perfectly for 10^6 samples, but once the number of samples > increases slightly above 50 * 10^6, MATLAB throws an "OUT of Memory" error. > I tried some techniques given inwww.mathworks.comto overcome this > problem, but they dont seem to help once the number of samples goes above > 10^7. > > My question is, does anyone know of a technique to compute the > autocorrelation matrix for such a long sequence quickly and accurately. I > have heard that the autocorrelation can be computed using FFT. I tried to > lay my hands on "Fast Algorithms for Digital Signal Processing" book, but > could not. Can somebody guide me to any resources explaining this method or > any other method which will help me out through the above said problem. > > Please let me know > > Thanks > Aloknath
Best to split the problem up into batches and then average the autocorrelation matrices. Hardy
For real-valued data, 1e7 samples take 8e7 bytes of memory. A 32-bit OS can accomodate at most 2^31 ~ 2e9 bytes of memory. With matlab running at the same kernel as the OS, a couple of dozens of other programs, and a little bit of bad luck with memory fragmentation, you quickly approach the memory limit with the amounts of data you have. As others already suggested, dividing the data up in chunks goes a long way to solve the problem.
The general procedure to compute the 'usual' biased estimate for the autocorrelation goes something along the lines of: 1) Allocate a 20-pt buffer for the end result, initialized with all zeros 2) Split the sequence up in manageable N-length frames. What is 'manageable' is determined by balancing speed against memory usage. Fewer frames is faster, but requires more memory. 3) Extract the next frame from the sequence and zero-pad to at least 2N-1 points 4) Compute the DFT of the zero-padded frame 5) Compute the periodogram as the squared magnitude of the spectrum coefficients 6) Compute the IDFT of the periodogram 7) *Add* the 20 first coefficients to the contents of the buffer allocated in step 1) 8) Handle scaling coefficients 9) Repeat from 3) until all frames have been processed 10) If desired, rearrange the 20 correlation values into a 20x20 Toeplitz matrix Rune
First mistake. Don't use MATLAB for serious computations. A plain C++ program runs ~10 times faster.
Second mistake. Trying to solve the problem by brute force, instead of thinking of the elegant approach.
Don't use MATLAB. It is a toy for stupidents and studiots.
> MATLAB works perfectly for 10^6 samples, but once the number of samples > increases slightly above 50 * 10^6, MATLAB throws an "OUT of Memory" error. > I tried some techniques given in www.mathworks.com to overcome this > problem, but they dont seem to help once the number of samples goes above > 10^7.
Yes, of course. What else do you expect.
Well. You apparently lack the basics, so there is no method which can help.
> Please let me know
I let you know.
> > Thanks > Aloknath >
VLV
On 16 Apr., 22:52, Vladimir Vassilevsky <antispam_bo...@hotmail.com>
wrote:
> sasuke wrote: > > Hi > > > I am using MATLAB to generate close to 10^8 samples > > First mistake. Don't use MATLAB for serious computations. A plain C++ > program runs ~10 times faster.
This statement is far too general. It's not easy to compare the performances on this level. The programming style is different. If you want your Matlab code to run fast you usually exploit all the built-in functions (which map to ATLAS, FFTW, ....) and operate on a matrix/ vector level as opposed to touching every scalar by hand. But this may also lead to higher memory requirements than what would be necessary in case of C or C++.
> > I am using MATLAB to do this. > > Don't use MATLAB. It is a toy for stupidents and studiots.
Man, improve your social skills. It may be of no great use to you. That doesn't mean it's not useful. You're basically insulting every Matlab user for no good reason. Matlab/Octave is nice for quickly testing things / prototyping / plotting 2D- and 3D- graphs. You can quickly import data and manipulate it. It has a nice collection of tools for all sorts of things and an interactive shell ... etc etc etc. C++ is nice. But it certainly isn't the best language for every job and you know it. SG
On 16 Apr, 23:27, SG <s.gesem...@gmail.com> wrote:
> On 16 Apr., 22:52, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote: > > > sasuke wrote: > > > Hi > > > > I am using MATLAB to generate close to 10^8 samples > > > First mistake. Don't use MATLAB for serious computations. A plain C++ > > program runs ~10 times faster. > > This statement is far too general.
Unless you have stripped the operations down to the core BLAS/LAPACK level, Vladimir is right. There is the interpreter overhead as well as the call-by-value function call overhead, which take a lot more time than people realize. More below.
> It's not easy to compare the > performances on this level. The programming style is different. If you > want your Matlab code to run fast you usually exploit all the built-in > functions (which map to ATLAS, FFTW, ....) and operate on a matrix/ > vector level as opposed to touching every scalar by hand.
And you have to throw every good programming practice down the drains. One aspect of matlab is that variables are passed between functions by copy, not by reference, which means that local copies of variables are found all over the place. This first of all consumes memory but also consumes lots of time copying variables back and forth, where one would use pointers or references in C or C++. The solution is to avoid using functions, thus forefeiting testing habits, code reusability and source code managment.
> But this may > also lead to higher memory requirements than what would be necessary > in case of C or C++.
Nope. It *might* not spend more memory. It *certainly* makes the program blow up and grab all the memory it can get. Rune
> 4) &#4294967295;Compute the DFT of the zero-padded frame > 5) &#4294967295;Compute the periodogram as the squared magnitude > &#4294967295; &#4294967295; of the spectrum coefficients > 6) &#4294967295;Compute the IDFT of the periodogram
> > Rune
A little bit off-topic: Since multiplication in frequency domain is the same as (circular) convolving in the time domain, shouldn't one of the segments be time- reversed before zero-padding and DFTing? in that way the auto- correlation is re-written as a convolution, and then it is ok to compute it in the freq domain. Am I right?
On 17 Apr., 09:45, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 16 Apr, 23:27, SG <s.gesem...@gmail.com> wrote: > > This statement is far too general. > > Unless you have stripped the operations down to the core > BLAS/LAPACK level, Vladimir is right.
That's what I've been saying. Matlab comes with lots of built-in functions that operate on vectors and matrices (find, min, max, mldivide, +, -, *, .....) which is why I said "different programming style" and "not easy to compare". No point in arguming here.
> There is the interpreter > overhead as well as the call-by-value function call overhead, > which take a lot more time than people realize. > [...] > And you have to throw every good programming practice > down the drains. One aspect of matlab is that variables > are passed between functions by copy, not by reference, > which means that local copies of variables are found > all over the place.
Pass-by-value semantics doesn't exclude the possibility of "copy-on- write" optimizations. It's perfectly possible to write x = somefunc(x); and let somefunc modify its local "copy" without any actual copying being involved. Now, whether Matlab does this behind the scenes is beyond me. Anyhow, I wasn't saying Matlab is better than anything else in every situation! Obviously it isn't. And it might not be the best tool for the original poster except for testing some quickly-written prototype algorithms on "toy problems". But Vladimir's response was too general and too one-sided which deserved some correcting, IMHO. Cheers! SG
On 17 Apr, 09:54, itakatz <itak...@gmail.com> wrote:
> > 4) &#4294967295;Compute the DFT of the zero-padded frame > > 5) &#4294967295;Compute the periodogram as the squared magnitude > > &#4294967295; &#4294967295; of the spectrum coefficients > > 6) &#4294967295;Compute the IDFT of the periodogram > > > Rune > > A little bit off-topic: > > Since multiplication in frequency domain is the same as (circular) > convolving in the time domain,
Convolution by DFT is circular, which is why you need to zero-pad before computing the DFT. The convolution of two N-length sequences gives as result a sequence with at most 2N-1 non-zero elements. Zero-padding to at least 2N-1 total length allocates the space needed to avoid wrap-around effects. Depending on what implementation of the FFT you have available, you might zero-pad further, to the next power of 2.
> shouldn't one of the segments be time- > reversed before zero-padding and DFTing?
Time-reversing in time domain is not sufficient to handle wrap-around effects from circular convolution, since you don't change the length of the input sequence. With pen and paper your trick might work, but in the computer you need to allocate memory and find a map from the 'true' index space k = -N,...,N to the RAM address space, BaseAddress + {0,1,...2N}. Essentially, you need to do some book-keeping to find out if the rxx[0] coefficient turns out in the index 0 position of the buffer, or in the index N position.
> in that way the auto- > correlation is re-written as a convolution, and then it is ok to > compute it in the freq domain. Am I right?
In time domain, reversing the direction of a sequence x[n] is written as x[-n]. It's a standard excercise in most DSP books to show that if x[n] <-> X[k] is a DFT pair, then x[-n] <-> X'[k] where X' is the complex conjugate of X, is also a DFT pair. Well, this is correct at least when x[n] is real-valued, it might not be for complex-valued x[n]. Anyway, convolving x[n] by x[-n] in time domain, which is a common estimator for the autocorrelation function (save some scaling coefficients), can alternatively be computed in frequency domain as a product of the DFTs: Sxx[k] = X[k]X'[k] = |X[k]|^2. Hence my algorithm works, once the relevant scaling coefficients have been accounted for. Rune
On 17 Apr, 10:21, SG <s.gesem...@gmail.com> wrote:
> On 17 Apr., 09:45, Rune Allnor <all...@tele.ntnu.no> wrote: > > > On 16 Apr, 23:27, SG <s.gesem...@gmail.com> wrote: > > > This statement is far too general. > > > Unless you have stripped the operations down to the core > > BLAS/LAPACK level, Vladimir is right. > > That's what I've been saying. Matlab comes with lots of built-in > functions that operate on vectors and matrices (find, min, max, > mldivide, +, -, *, .....) which is why I said "different programming > style" and "not easy to compare". No point in arguming here.
At least C++ (I don't know 'bout C) have a few libraries that provide data structures like trees, lists, queues etc, that allow for far more efficient algorithms than matlab can, which is locked into the 'straightjacket' posed by the ND array data structure. Here is a teaser I wrote some time ago on comp.soft-sys.matlab, about these very issues: http://groups.google.no/group/comp.soft-sys.matlab/msg/0b6492cb37b5d7fd?hl=no The main discussion was about some semantic detail about how to make matlab run fast. As you can see from the quoted profiler report, my 'naive' matlab alternative beat the 'elegant' matlab alternative by almost a factor 2. Then I did the same job with C++, the only difference being that I exploited the available data structures. This naive C++ code, with the algorith tailored to the problem but not optimized by me in any other way[*], ran almost 10x faster than the fastest matlab alternative. As I said, unless you work with core BLAS/LAPACK types of problems, leave matlab out if run-time is a concern.
> > There is the interpreter > > overhead as well as the call-by-value function call overhead, > > which take a lot more time than people realize. > > [...] > > And you have to throw every good programming practice > > down the drains. One aspect of matlab is that variables > > are passed between functions by copy, not by reference, > > which means that local copies of variables are found > > all over the place. > > Pass-by-value semantics doesn't exclude the possibility of "copy-on- > write" optimizations. It's perfectly possible to write > > &#4294967295; &#4294967295;x = somefunc(x); > > and let somefunc modify its local "copy" without any actual copying > being involved. Now, whether Matlab does this behind the scenes is > beyond me.
I am pretty sure it does. While not as bad as worst-case, it still represents a significant overhead compared to C or C++.
> Anyhow, I wasn't saying Matlab is better than anything else in every > situation! Obviously it isn't. And it might not be the best tool for > the original poster except for testing some quickly-written prototype > algorithms on "toy problems".
That's exactly what matlab was designed to do. Despite appearances, that's all matlab is useful for.
> But Vladimir's response was too general > and too one-sided which deserved some correcting, IMHO.
Vladimir made two very concise statements: 1) "Don't use MATLAB for serious computations." 2) "A plain C++ program runs ~10 times faster." The first I fully support, since matlab is a beast both what 'serious' programming/development and run-time resource demands are concerned. If you try and make anything beyond prototypes or toy programs, you will have to work your butt off in return for less than mediocre performance. As demonstrated in the post quoted above. Vladimir's second statementis factually correct for just about anything but core BLAS/LAPACK applications. Rune [*] I compiled the C++ code as a MEX routine to be called from within matlab. Whatever optimizing compiler directives were invoked from the MEX compilation setupwe, were standardized and not modified by me.
