I have pilots which are either +1 or -1, (bpsk modulated). I am using OFDM . After passing through rayleigh channel (used the function rayleighchan) and than adding noise, i am trying to estimate the channel. Simplest way is the least squared approach , do (Y/X) to get H_ls (least squared impulse response in freq domain). note : this is done after doing fft in ofdm. The problem is how do i know what the pilot was? Its either +1 or -1, but how do i know which one was actually sent. since the gains are complex, +1 sent could be received as -1 and -1 could be received as +1. OR, How do i simulate the least squared approach ? What should I take for X ?
Problem in Channel Estimation using Least Square Approach
Started by ●June 28, 2009
Reply by ●June 30, 20092009-06-30
shekar1989 <yogicyogesh@gmail.com> wrote:> The problem is how do i know what the pilot was?The point of a pilot is that you know what it is. "It's either +1 or -1"? That's true for any BPSK-modulated signal! Cheers, Clemens
On Jun 30, 4:33�pm, Clemens Buchacher <dri...@aon.at> wrote:> shekar1989 <yogicyog...@gmail.com> wrote: > > The problem is how do i know what the pilot was? > > The point of a pilot is that you know what it is. "It's either +1 or -1"? > That's true for any BPSK-modulated signal! > > Cheers, > ClemensI think the OP simply did not conceive that it is possible to detect f a pilot signal if it has been subjected to a random phase rotation ... Julius
