Hi All, According to LTE frame structure every frame have primary synchronization signals.And for primary synchronization signal zadoff- chu sequence is used beacuse of its good periodic autocorrelation as well as periodic cross correlation properties. I thought of using noncoherent correlation in time domain.I tried this method in matlab and seems working for me. My problem is its taking lot of time to detect primary synchronization signal because in worst case we have to do 1 lag autocorrelation (5*14-1)*2048 times.And for 1 autocorrelation value 2048 multiplications and additions required.hence total number of multiplication required for worstcase may go upto (5*14-1)*2048*2048. for more clarification 5 is number of subframes(we are taking half of frame data to detect PSS) 14 is number of Ofdma sybols in 1 subframe My question is is there any fast method for autocorrelation for zadoff- chu type of sequence?or this is the only method . Thanks Anurag
detection of primary synchronization signal in LTE
Started by ●August 6, 2009
