Does a modulation with q different symbol states absolutely require a code over X^n, where X = {a_1, a_2, ..., a_q}? Or can you use a symbol set (X) with a different order (count)? A slightly different question: is this *typically* done (q symbol states ==> order q symbol set)? I.e., although it's not required, is it typically done this way? As a simple example, could a binary (7,4) Hamming code be applied to 16 QAM, such that 4/7 codewords fit into one symbol? -- Randy Yates % "She tells me that she likes me very much, Digital Signal Labs % but when I try to touch, she makes it mailto://yates@ieee.org % all too clear." http://www.digitalsignallabs.com % 'Yours Truly, 2095', *Time*, ELO
Coding/Modulation Question
Started by ●August 19, 2009
Reply by ●August 19, 20092009-08-19
Randy Yates wrote:> Does a modulation with q different symbol states absolutely require a > code over X^n, where X = {a_1, a_2, ..., a_q}? Or can you use a > symbol set (X) with a different order (count)? > A slightly different question: is this *typically* done (q symbol states > ==> order q symbol set)? I.e., although it's not required, is it > typically done this way?Ideally you want coding to be matched to the modulation, so the Hamming distance corresponds to the Euclidean distance.> As a simple example, could a binary (7,4) Hamming code be applied to 16 > QAM, such that 4/7 codewords fit into one symbol?The result is likely to be worse then the uncoded QAM. Proakis Chapter 8 is exactly about your questions. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Randy Yates wrote:> Does a modulation with q different symbol states absolutely require a > code over X^n, where X = {a_1, a_2, ..., a_q}? Or can you use a > symbol set (X) with a different order (count)? > > A slightly different question: is this *typically* done (q symbol states > ==> order q symbol set)? I.e., although it's not required, is it > typically done this way? >I *believe* ( but could easily be wrong ) that the map from symbol states to symbol order sets is opportunistic, and based on which sorts of maps empirically behave the best. Mathematically, any function could work. And whether or not the function is bijective/symmetrical seems irrelevant, long as you don't need the symmetry for computational reasons. ObDisclosure: I'm not a coding theory guy at all, but I've worked with several on instrumentation.> As a simple example, could a binary (7,4) Hamming code be applied to 16 > QAM, such that 4/7 codewords fit into one symbol?I don't see why not - isn't the choice of 16 QAM largely independent of what's being modulated over it? Once you have conditions necessary to describe one bit in 16QAM... it's a bit. It is, form a dataflow perspective, just a by-16 PSK stream.... once you get it into baseband... 16 & 7 modularize together in an interesting, 56-bit sort of way, too.... -- Les Cargill
Reply by ●August 20, 20092009-08-20
Vladimir Vassilevsky <nospam@nowhere.com> writes:> Randy Yates wrote: >> Does a modulation with q different symbol states absolutely require a >> code over X^n, where X = {a_1, a_2, ..., a_q}? Or can you use a >> symbol set (X) with a different order (count)? >> A slightly different question: is this *typically* done (q symbol states >> ==> order q symbol set)? I.e., although it's not required, is it >> typically done this way? > > Ideally you want coding to be matched to the modulation, so the > Hamming distance corresponds to the Euclidean distance.Euclidean distance as in the correlation metrics when you're doing soft-decision decoding?>> As a simple example, could a binary (7,4) Hamming code be applied to 16 >> QAM, such that 4/7 codewords fit into one symbol? > > The result is likely to be worse then the uncoded QAM. Proakis Chapter > 8 is exactly about your questions.That narrows it down to 120 pages or so. Thanks... -- Randy Yates % "And all you had to say Digital Signal Labs % was that you were mailto://yates@ieee.org % gonna stay." http://www.digitalsignallabs.com % Getting To The Point', *Balance of Power*, ELO
On Aug 19, 7:47�pm, Randy Yates <ya...@ieee.org> asked:> Does a modulation with q different symbol states absolutely require a > code over X^n, where X = {a_1, a_2, ..., a_q}? �Or can you use a > symbol set (X) with a different order (count)?This kind of stuff is routine. Consider, for example, using a Reed-Solomon code (say (255,223) code over GF(256)) on the binary symmetric (or additive white Gaussian noise) channel. As another example, one of the first implementations of a (2,1) convolutional code was for a QPSK modem in which the two coded bits were the I and Q inputs to the modem, and the channel rate in bauds was the same as the input data rate in bits.>As a simple example, could a binary (7,4) Hamming code >be applied to 16-QAM, such that 4/7 codewords fit into one >symbol?Yes, though the implementation as well as any analysis would be messy. The first codeword would have its bits in the first and second QAM symbols transmitted, but the *second* codeword would have one bit in the second QAM symbol transmitted, the next four bits in the third QAM symbol, and two bits in the fourth QAM symbol. The 7 bits of the third codeword would have .... ; the whole cycle repeating after 7 QAM symbols (i.e. 4 codewords). Whether the increased complexity is worth the benefits reaped remains to be seen in 120 or so pages. Or the answer exists in some unpublished master's thesis since negative results tend not to get published: the number of papers saying "Our scheme works" is far outweighed by the number of papers saying "We tried this scheme and it did not work." --Dilip Sarwate
dvsarwate@yahoo.com <dvsarwate@gmail.com> wrote:>On Aug 19, 7:47�pm, Randy Yates <ya...@ieee.org> asked:>>As a simple example, could a binary (7,4) Hamming code >>be applied to 16-QAM, such that 4/7 codewords fit into one >>symbol?>Yes, though the implementation as well as any analysis would >be messy. The first codeword would have its bits in the first >and second QAM symbols transmitted, but the *second* >codeword would have one bit in the second QAM symbol >transmitted, the next four bits in the third QAM symbol, and >two bits in the fourth QAM symbol. The 7 bits of the third >codeword would have .... ; the whole cycle repeating >after 7 QAM symbols (i.e. 4 codewords). Whether the >increased complexity is worth the benefits reaped remains >to be seen in 120 or so pages.I would expect the Hamming code thus applied to exhibit slightly less normalized coding gain than the same code applied to a BPSK-modulated system. There are two things that make the hit you're taking from this mismatch smaller than one might think: in AWGN, the noise vectors on the I and Q dibits are independent; and if those dibits are grey-coded, as they typically are, the bit errors within a dibit move closer to looking independent of each other. Still it would be worth placing an interleaver between the code and the channel. Steve
