Hi Friends, I am a new bee in embedded systems. My task is to test a filter(low pass) with audio in and out connections of hardware board. I have developed a low pass filter in C and tested it using goldwave(signal processing tool) and need guidance on how to test the same filter with audio in and out connections of hardware. Thanks in advance. Aamer
filter on hardware
Started by ●August 24, 2009
Reply by ●August 24, 20092009-08-24
On Mon, 24 Aug 2009 08:55:30 -0500, aamer wrote:> Hi Friends, > > I am a new bee in embedded systems. My task is to test a filter(low > pass) with audio in and out connections of hardware board. I have > developed a low > pass filter in C and tested it using goldwave(signal processing tool) > and need guidance on how to test the same filter with audio in and out > connections of hardware. > > Thanks in advance. > AamerHi friend. You must be new to USENET. Please do a quick web search on "cross posting", and find an article that explains the difference between cross posting and multiple posting. Then please don't multiple post any more. -- www.wescottdesign.com
Reply by ●August 25, 20092009-08-25
On Aug 24, 2:55�pm, "aamer" <raqeeb...@yahoo.com> wrote:> Hi Friends, > > I am a new bee in embedded systems. My task is to test a filter(low pass) > with audio in and out connections of hardware board. I have developed a > low > pass filter in C and tested it using goldwave(signal processing tool) and > need guidance on how to test the same filter with audio in and out > connections of hardware. > > Thanks in advance. > AamerYou may test in two ways: 1) apply steady state pure sine waves (from a generator) at different frequencies and measure input versus output - plot the attenuation against frequency and you have a direct plot of frequency response. 2) apply a short stimulus whose shape you know (eg an impulse, chirp or MLS) and capture the response. Calculate the FT of each and plot the difference. Both cases give you the frequency spectrum. Chris ====================== Chris Bore BORES Signal Processing www.bores.com
