Hi, I have a simple matlab question: I have a baseband signal with a 2MHz bandwidth (wideband), sampled at 100MHz. I would like to use this signal to modulate a 5Ghz carrier. What is the simplest way to proceed? I was thinking using the ammod function, but in that case I would need to resample my signal to a higher sampling rate (which may add some distortion). Is there a more elegant way to go about it? Thanks
Modulation with a baseband signal in Matlab
Started by ●November 22, 2009
Reply by ●November 22, 20092009-11-22
Nitram wrote:> Hi, > > I have a simple matlab question: I have a baseband signal with a 2MHz > bandwidth (wideband), sampled at 100MHz. I would like to use this signal to > modulate a 5Ghz carrier. What is the simplest way to proceed?The simplest way to proceed is do everything in the baseband. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●November 23, 20092009-11-23
>The simplest way to proceed is do everything in the baseband. >My aim is to test out a frequency search algorithm where the receiver does not know the carrier frequency of the transmitted signal. Therefore, I need to go to RF in order to verify my search algorithm (unless there is a better way). Thanks
Nitram wrote:>>The simplest way to proceed is do everything in the baseband. >> > > > My aim is to test out a frequency search algorithm where the receiver does > not know the carrier frequency of the transmitted signal.If your goal is frequency search algorithm, why bother with low level details in time domain? Therefore, I need> to go to RF in order to verify my search algorithm (unless there is a > better way).Split your problem into a set of different problems at different scales and do everything in the baseband. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On 11/23/2009 8:26 AM, Nitram wrote:>> The simplest way to proceed is do everything in the baseband. >> > > My aim is to test out a frequency search algorithm where the receiver does > not know the carrier frequency of the transmitted signal. Therefore, I need > to go to RF in order to verify my search algorithm (unless there is a > better way). > > ThanksIs the algorithm going to be applied at baseband or at RF? If it will be applied to the baseband signal, why not test it there? Frequency offset at RF = frequency offset at baseband. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
> >If your goal is frequency search algorithm, why bother with low level >details in time domain?I guess I should explain myself in more details: Actually I want to extract synchronization information of an OFDM signal. I am planning to use cyclic prefix correlation to get the timing information and then wideband filtering plus a correlation of a known sequence in frequency domain to get the frequency correlation. Therefore, I have to introduce a timing and frequency offset (which I was hoping could be anywhere from 0 to 50MHz). I was planning to introduce the frequency offset by upconverting the signal to RF and downconverting it with a slighthly different LO, creating a frequency offset.>> Therefore, I need >> to go to RF in order to verify my search algorithm (unless there is a >> better way). > >Split your problem into a set of different problems at different scales >and do everything in the baseband.I am not sure if I understand correctly what are the different scales you are thinking of. Would it be possible to elaborate? I really appreciate your help.
>Is the algorithm going to be applied at baseband or at RF? If it will >be applied to the baseband signal, why not test it there? Frequency >offset at RF = frequency offset at baseband.True, but I would need to simulate pretty large frequency offset e.g. cases where half the bandwidth of the baseband signal is filtered out by the RF front-end filter. What would be a simple way to achive this in baseband? Thanks
On 11/23/2009 9:25 AM, Nitram wrote:>> Is the algorithm going to be applied at baseband or at RF? If it will >> be applied to the baseband signal, why not test it there? Frequency >> offset at RF = frequency offset at baseband. > > True, but I would need to simulate pretty large frequency offset e.g. > cases where half the bandwidth of the baseband signal is filtered out by > the RF front-end filter. What would be a simple way to achive this in > baseband? > > ThanksWhy not model the RF filter effect at baseband? Is there an asymmetric distortion that you need to model? -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
>Why not model the RF filter effect at baseband? Is there an asymmetric >distortion that you need to model?What I would need to do is shift my baseband signal by a certain frequency offset, pass it through a lowpass filter to emulate a receiver RF filter(in the graph the lowpass filter is represented by a brickwall filter) and then attempt to find the frequency of the random shift on the receiver. ^ ^ | |_________ |______ | _____|<--low pass filter | \ | | |\ | \ --> | | | \<--shifted signal |________\_________>f |___|_____|__\______>f <--------> <--------> BW The shift would be a simple complex multiplication and I guess the only thing I need to be careful about is not to shift my signal too far so that I get aliasing before my lowpass filter (either this or do successive shift/lowpass procedures). What do you think? Thanks.
On 11/23/2009 1:28 PM, Nitram wrote:>> Why not model the RF filter effect at baseband? Is there an asymmetric >> distortion that you need to model? > > What I would need to do is shift my baseband signal by a certain frequency > offset, pass it through a lowpass filter to emulate a receiver RF filter(in > the graph the lowpass filter is represented by a brickwall filter) and then > attempt to find the frequency of the random shift on the receiver. ^ > ^ > | |_________ > |______ | _____|<--low pass filter > | \ | | |\ > | \ --> | | | \<--shifted signal > |________\_________>f |___|_____|__\______>f > <--------> <--------> > BW > The shift would be a simple complex multiplication and I guess the only > thing I need to be careful about is not to shift my signal too far so that > I get aliasing before my lowpass filter (either this or do successive > shift/lowpass procedures). > > What do you think? > > Thanks. >If you're trying to simulate the effects of a frequency offset and how it would be affected by the frequency selectivity of the RF or IF filter, that looks appropriate to me. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
