Hello, http://www.autex.ru/dspa/dspa2008/09.pdf At the page 27 of this presentation have found: --- Available algorithms (factory mask-programmed) ‹ PCM ‹ Dolby Digital*, Dolby Digital EX2*, Dolby Pro Logic IIx* ‹ DTS 5.1*, DTS ES*, DTS Neo:6*, DTS 96/24* ‹ SRS Focus* ‹ MPEG2 AAC LC ‹ MP3 ‹ Graphic Equalizer, Balance/Fader, Bass Management, Delay Management Requirements: ‹ License agreement required from IP* holders prior to receipt of silicon samples ‹ No minimum quantity ‹ No NRE costs --- I need encoder and decoder, so what is the price for 10 pcs qty ? Maybe you know other solutions of my problem ? Kind regards Roman Rumian
MPEG Audio layer 2 for SHARC processors
Started by ●November 24, 2009
Reply by ●November 24, 20092009-11-24
rr <rr@agh.edu.pl> wrote in news:hehmvu$2tf$1@news.agh.edu.pl:> Hello, > > http://www.autex.ru/dspa/dspa2008/09.pdf > > At the page 27 of this presentation have found: > --- > Available algorithms (factory mask-programmed) > ‹ PCM > ‹ Dolby Digital*, Dolby Digital EX2*, Dolby Pro Logic IIx* > ‹ DTS 5.1*, DTS ES*, DTS Neo:6*, DTS 96/24* > ‹ SRS Focus* > ‹ MPEG2 AAC LC > ‹ MP3 > ‹ Graphic Equalizer, Balance/Fader, Bass Management, Delay Management > Requirements: > ‹ License agreement required from IP* holders prior to receipt of > silicon samples > ‹ No minimum quantity > ‹ No NRE costs > --- > I need encoder and decoder, so what is the price for 10 pcs qty ? > > Maybe you know other solutions of my problem ? > > Kind regards > > Roman Rumian > >Hi Roman, Dolby and DTS licensing is expensive.You need DTS and Dolby licenses to buy the parts. You are not going to be able purchase the ROM SHARC parts for just MP3. An MP3 decoder and encoder may be available that does not require the ROM version of the SHARC. You may still need to resolve licensing issues. We have a ADSP-21469 SHARC based high performance audio system (Danville dspMusik 2/8) that can support this kind of application. One of our customers is using it with Dolby Decoders. I suggest you contact Paul Beckmann of DSP Concepts (www.dspconcepts.com). He may have a solution. Al Clark www.danvillesignal.com
Reply by ●November 25, 20092009-11-25
Hi Roman, If you are not tied to the specific DSP family you can consider software modules for Blackfin. The full list is here: http://www.analog.com/en/embedded-processing-dsp/blackfin/content/blackfin_software_modules/fca.html I read somewhere that some of these modules are available in the object code format (with no source code provided) at no cost. Consult ADI about licensing terms for MPEG codecs. -- Alexander
Al Clark pisze: (...)> Hi Roman, > > Dolby and DTS licensing is expensive.You need DTS and Dolby licenses to buy > the parts. You are not going to be able purchase the ROM SHARC parts for > just MP3. > > An MP3 decoder and encoder may be available that does not require the ROM > version of the SHARC. You may still need to resolve licensing issues. > > We have a ADSP-21469 SHARC based high performance audio system (Danville > dspMusik 2/8) that can support this kind of application. One of our > customers is using it with Dolby Decoders. I suggest you contact Paul > Beckmann of DSP Concepts (www.dspconcepts.com). He may have a solution. > > Al Clark > www.danvillesignal.comThank you Al ! :-) With regards Roman Rumian
Alexander Sotnikov pisze:> Hi Roman, > > If you are not tied to the specific DSP family you can consider software > modules for Blackfin. The full list is here: > http://www.analog.com/en/embedded-processing-dsp/blackfin/content/blackfin_software_modules/fca.html > > I read somewhere that some of these modules are available in the object > code format (with no source code provided) at no cost. Consult ADI about > licensing terms for MPEG codecs.Thank you, Alexander. :-) This is interesting options, but we want SHARC and 24-bits audio, because have another project for SHARC. We probably shall port LAME C code , but it would be better to save time ... Kind regards Roman Rumian
Roman Rumian wrote:> Alexander Sotnikov pisze: > >> Hi Roman, >> >> If you are not tied to the specific DSP family you can consider software >> modules for Blackfin. The full list is here: >> http://www.analog.com/en/embedded-processing-dsp/blackfin/content/blackfin_software_modules/fca.html >> >> >> I read somewhere that some of these modules are available in the object >> code format (with no source code provided) at no cost. Consult ADI about >> licensing terms for MPEG codecs. > > > Thank you, Alexander. :-) > This is interesting options, but we want SHARC and 24-bits audio, > because have another project for SHARC. We probably shall port LAME C > code , but it would be better to save time ...You know about STA015, do you? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●November 26, 20092009-11-26
