On Tue, 15 Dec 2009 15:46:22 +0000, Philip Pemberton wrote:> Do I need to apply any additional processing to the input data? What > about the "1/n factor"?OK, I've answered my own question... To turn that FFT routine into an inverse-FFT routine: - You don't need to change the input data in any way. - If you want an iFFT, then flip the sign on PI, else leave it alone. - When the core of the iFFT completes, divide each data element in the output array by N. And here's the code: #include <iostream> #include <complex> #include <cmath> #include <iterator> using namespace std; unsigned int bitReverse(unsigned int x, int log2n) { int n = 0; int mask = 0x1; for (int i=0; i < log2n; i++) { n <<= 1; n |= (x & 1); x >>= 1; } return n; } const double PI = 3.1415926536; /** * @param a FFT input * @param b FFT output * @param log2n Log^2(N) where N=the number of input elements. N must be a power of 2. * @param invert True for an Inverse-FFT, False otherwise. */ template<class Iter_T> void fft(Iter_T a, Iter_T b, int log2n, bool invert) { typedef typename iterator_traits<Iter_T>::value_type complex; const complex J(0, 1); int n = 1 << log2n; for (unsigned int i=0; i < n; ++i) { b[bitReverse(i, log2n)] = a[i]; } for (int s = 1; s <= log2n; ++s) { int m = 1 << s; int m2 = m >> 1; complex w(1, 0); complex wm = exp(-J * ((invert ? -PI : PI) / m2)); for (int j=0; j < m2; ++j) { for (int k=j; k < n; k += m) { complex t = w * b[k + m2]; complex u = b[k]; b[k] = u + t; b[k + m2] = u - t; } w *= wm; } } if (invert) { for (unsigned int i=0; i<n; i++) { b[i] /= n; } } } int main() { typedef complex<double> cx; cx a[] = { cx(0,0), cx(1,1), cx(3,3), cx(4,4), cx(4, 4), cx(3, 3), cx(1,1), cx(0,0) }; cx b[8]; cx c[8]; fft(a, b, 3, false); fft(b, c, 3, true); cout << "FFT input:\n"; for (int i=0; i<8; ++i) cout << "\t" << a[i] << "\n"; cout << "\nFFT output:\n"; for (int i=0; i<8; ++i) cout << "\t" << b[i] << "\n"; cout << "\niFFT output:\n"; for (int i=0; i<8; ++i) cout << "\t" << c[i] << "\n"; } Thanks, -- Phil. usenet09@philpem.me.uk http://www.philpem.me.uk/ If mail bounces, replace "09" with the last two digits of the current year.
Converting FFT to inverse-FFT
Started by ●December 15, 2009
Reply by ●December 15, 20092009-12-15
See the Smith book online. They give a real nice example in ch. 12 p. 239 table 12-6 The book has code written in basic. However, their explanation is pretty straightforward, and as a coder, you should not have difficulty as long as you work only with the code interfaces, and know what data is going in, and what is going out. You should pay attention to whether the Oreilly code is for the "real" or "complex" FFT.... the difference is in how you feed input data ( only the RE array, or both RE and IM array) and read the output data. The Smith book demonstrates the difference very nicely. Walt......>On 15 Des, 16:46, Philip Pemberton <usene...@philpem.me.uk> wrote: > >> Do I need to apply any additional processing to the input data? > >No. > >> What about the "1/n factor"? > >It's there to ensure that the round-trip y = ifft(fft(x)); >returns the same data as the input (to within numerical >precision). The theory is that Parseval's identity hold, >that the DFT'd data should have the same norm as the input >data: > >sum(x[n]^2) == sum(|X[k]|^2) > >where X = dft(x). In practice, this would mean that one >needs a 1/sqrt(N) scaling factor both in the DFT and IDFT. >To save some computations the convention is to drop the >scaling factor in the forward DFT and instead compensate >with an 1/N scaling factor in the IDFT. The downside >of all this is that Parseval's identity does *not* hold >with the FFT, one needs to include the missing scaling >factors. > >Rune >
On 15 Des, 17:34, Philip Pemberton <usene...@philpem.me.uk> wrote:> On Tue, 15 Dec 2009 15:46:22 +0000, Philip Pemberton wrote:> - If you want an iFFT, then flip the sign on PI, else leave it alone.Technically speaking - yes. However, people would have to think a bit in order to understand what you were talking about, if you were to state it like that. Instead, I'd say 'conjugate the input data', as that's more in line with the lingo of the established theory. You could also use the FFT routine as is, just with the data conjugation and scaling steps as pre-processing. Rune
On Dec 16, 3:22�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> Philip Pemberton wrote: > > > How would I go about converting this from an FFT to an inverse-FFT? > > Scale by factor 1/N and use -sin(x) instead of sin(x). > > > Sorry if this seems like a stupid question, it just seems a little too > > easy...! > > Stupid question indeed. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comIn fact the ordinary FFT should have a 1/N, not the inverse. Makes more sense. For example for DC you need to divide by N ie the average. Hardy
On 12/15/2009 2:50 PM, HardySpicer wrote:> On Dec 16, 3:22 am, Vladimir Vassilevsky<nos...@nowhere.com> wrote: >> Philip Pemberton wrote: >> >>> How would I go about converting this from an FFT to an inverse-FFT? >> Scale by factor 1/N and use -sin(x) instead of sin(x). >> >>> Sorry if this seems like a stupid question, it just seems a little too >>> easy...! >> Stupid question indeed. >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > In fact the ordinary FFT should have a 1/N, not the inverse. Makes > more sense. For example for DC you need to divide by N ie the average. > > > HardyIt's just convention. In the old days we put 1/sqrt(N) in front of each. There are some advantages to that, and some disadvantages. As long as one keeps track, it comes out in the wash. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
HardySpicer wrote:> On Dec 16, 3:22 am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>Philip Pemberton wrote: >> >> >>>How would I go about converting this from an FFT to an inverse-FFT? >> >>Scale by factor 1/N and use -sin(x) instead of sin(x). >> >> > > In fact the ordinary FFT should have a 1/N, not the inverse. Makes > more sense. For example for DC you need to divide by N ie the average.I agree. Interpretation and comparison of FFT results with different scaling is very common source of mistakes. VLV
Eric wrote:>It's just convention. In the old days we put 1/sqrt(N) in front of >each. There are some advantages to that, and some disadvantages. As >long as one keeps track, it comes out in the wash.Mathematica parameterizes various conventions for the Fourier transform (granted, not an FFT/DFT, so slightly OT, but I find it interesting, and one could probably write something analogous) in terms of two constants, and they give examples of which fields usually use which convention: http://reference.wolfram.com/mathematica/ref/FourierTransform.html Expand "More Information" right after the yellow-background area at the top, and look at the large display-style equation under the fourth bullet.
On Tue, 15 Dec 2009 13:50:53 -0800 (PST), HardySpicer <gyansorova@gmail.com> wrote:>In fact the ordinary FFT should have a 1/N, not the inverse. Makes >more sense. For example for DC you need to divide by N ie the average.And yet, for non-DC terms, you need 2/N for the bin magnitude to equal the sinewave amplitude. Using 1/N is more mathematically consistent, though, because a real sine wave of amplitude "A" will produce two spectral components, each of magnitude "A/2". Greg
