On 12/25/2009 10:38 AM, Jerry Avins wrote:> Muzaffer Kal wrote: >> On Thu, 24 Dec 2009 14:43:58 -0500, Jerry Avins <jya@ieee.org> wrote: >>> AM is rarely used with digital modulation. It is primarily an analog >>> medium. >> >> This maybe true for carrier based (and/or wireless) systems but for >> base-band systems almost all modulation is AM. Best examples are 1GbE >> (PAM5) and 10GbE (over 100m copper) which is 16 PAM.There are lots more, like the 8-VSB used in the ATSC broadcast standard, OOK in most optical systems, etc., etc.> I should clarify. By AM, I meant the system in which a carrier is varied > in amplitude to create an envelope that follows the modulating signal, > and can as a result be demodulated with an envelope detector. Variations > that require taking phase into account lie outside the scope of my > statement. > > JerryI knew what you meant, but also knew that it was ambiguous enough that people would point out QAM, etc. The OOK used in optical systems is maybe the closest comparison for a digital modulation, but optical and RF power modulation systems are hardly comparable in that sense. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
modulation: audio DC offset
Started by ●December 23, 2009
Reply by ●December 25, 20092009-12-25
