Hello, I'm very new to the implementation of the biquad filter. It would really help if someone could post links where I can learn how to implement a biquad filter as well as cascaded biquad filter in octave or matlab. I'd appreciate if someone could point me as to how do I decide the filter co-efficient and test them with respect to the desired frequency response. Thank you.
implement biquad filter in octave or matlab
Started by ●March 24, 2010
Reply by ●March 24, 20102010-03-24
Partial code is printed. This I had done two years back in Octave. In case if you need full listing get in touch on bharat at arithos dot com. Regards Bharat Pathak //============================================================= function [w1 w2 w3 yout smin smax] = biquad_3stage(sos, xin) % This function implements 3 biquads in time domain. % Basically by means of difference equation. % This program can be used to 3 reasons. % 1. perform fractional bits analysis. % 2. find overflow at critical adder nodes. % 3. fixing of limit cycle oscillations. fb_sel1 = 1; % 0 means floor, 1 means round and 2 means fix fb_sel2 = 1; % 0 means floor, 1 means round and 2 means fix fb_sel3 = 2; % 0 means floor, 1 means round and 2 means fix b0c = sos(3,1); b1c = sos(3,2); b2c = sos(3,3); a1c = sos(3,5); a2c = sos(3,6); for i = 1 : length(xin) %------------------ first stage -------------------------- sum1 = b0a*xin(i) + b1a*xp + b2a*xpp - a1a*w1p - a2a*w1pp; if(sum1 < s1min) s1min = sum1; elseif(sum1 > s1max) s1max = sum1; else end %------------------ second stage -------------------------- sum2 = b0b*w1(i) + b1b*w1p + b2b*w1pp - a1b*w2p - a2b*w2pp; if(sum2 < s2min) s2min = sum2; elseif(sum2 > s2max) s2max = sum2; else end %------------------ third stage -------------------------- if(fb_sel3 == 0) w3(i) = floor(sum3 * k)/k; elseif(fb_sel3 == 1) w3(i) = round(sum3 * k)/k; else w3(i) = fix(sum3 * k)/k; end xpp = xp; xp = xin(i); w1pp = w1p; w1p = w1(i); yout(i) = round(sum3 * k1)/k1; end smin = [s1min s2min s3min]; smax = [s1max s2max s3max]; endfunction
