On Apr 23, 11:41�am, Dirk Bell <bellda2...@cox.net> wrote:> On Apr 23, 11:17�am, Clay <c...@claysturner.com> wrote: > > > > > > > On Apr 22, 6:27�pm, Dirk Bell <bellda2...@cox.net> wrote: > > > > On Apr 22, 5:42�pm, Jerry Avins <j...@ieee.org> wrote: > > > > > On 4/22/2010 2:26 PM, Dirk Bell wrote: > > > > > > On Apr 16, 1:26 am, Jerry Avins<j...@ieee.org> �wrote: > > > > >> On 4/16/2010 12:43 AM, cfy30 wrote: > > > > > >>> Hi all, > > > > > >>> I am a newbie to Hilbert transform. I found the follow definition from > > > > >>> textbook > > > > > >>> H(f) = -j or -90degree, f>0 > > > > >>> H(f) = �j or +90degree, f<0 > > > > >>> H(f) = �0, f=0 > > > > > >>> But when I plot the phase out in Matlab, I saw that the phase is not > > > > >>> constant at -90 or +90degree across frequency. The code I have is as > > > > >>> follow > > > > > >>> b = firpm(10,[.1 .9],[1 1],'Hilbert') > > > > >>> w = linspace(-pi, pi, 2^12); > > > > >>> h = freqz(b, 1, w); > > > > >>> plot(w, angle(h)*180/pi); > > > > > >>> What do I miss? > > > > > >> The phase is 90 degrees only over a limited band. All bets are off at > > > > >> Fs/2, and you can't include enough taps to get 90 degrees of delay at > > > > >> DC. What's more, there will be some amplitude ripple in the passband. > > > > > Jerry, > > > > > > The phase is not really 90 degrees only over a "limited" band. �Try a > > > > > 100K point FFT on the OP's filter (remove delay) and the only 2 values > > > > > that are not +-pi/2 with error magnitude<4*10^-13 radians are at 0 > > > > > and pi radians where they are zero. �The phase is essentially correct > > > > > over the whole band. �The amplitude is another story. > > > > > Dirk, > > > > > Of course you're right. Antisymmetry assures that the phase be perfect > > > > even with a balanced differentiator, [-1, 0, +1]. I had in mind the > > > > implementation with parallel filters whose difference approximates 90 > > > > degrees over the bans of interest. Bad form! > > > > > Jerry > > > > -- > > > > "It does me no injury for my neighbor to say there are 20 gods, or no > > > > God. It neither picks my pocket nor breaks my leg." > > > > � � � � � Thomas Jefferson to the Virginia House of Delegates in 1776.- Hide quoted text - > > > > > - Show quoted text - > > > > Hi Jerry, > > > > I took my post down because I looked at later posts and thought it was > > > basically covered. �However antisymmetry by itself is not enough to > > > guarantee perfect phase. �For example [1 � � 0 � �-1 � � 0 � � 1 > > > 0 � �-1] does not work. > > > > I was curious about another comment somone here made. �What is the > > > best way to design a 45 degree phase shifter? > > > > Dirk- Hide quoted text - > > > > - Show quoted text - > > > I don't know if it is the best way, but it is a simple way. �See: > > >http://www.claysturner.com/dsp/ASG.pdf > > > Clay- Hide quoted text - > > > - Show quoted text - > > Thanks Clay. > > Dirk- Hide quoted text - > > - Show quoted text -You are welcome.
Hilbert Transform Phase
Started by ●April 16, 2010
Reply by ●April 23, 20102010-04-23
On 4/23/2010 8:17 AM, Clay wrote:>> [snip]> > I don't know if it is the best way, but it is a simple way. See: > > http://www.claysturner.com/dsp/ASG.pdf > > > Clay >Clay, I'm holding you personally responsible for the fact that I'm sitting here trying to get my head around this paper instead of doing my actual, entirely un-Hilbert-transform-related, job. -- Rob Gaddi, Highland Technology Email address is currently out of order
On Apr 23, 12:12�pm, Rob Gaddi <rga...@technologyhighland.com> wrote:> On 4/23/2010 8:17 AM, Clay wrote: > > > > �> [snip] > > > I don't know if it is the best way, but it is a simple way. �See: > > >http://www.claysturner.com/dsp/ASG.pdf > > > Clay > > Clay, I'm holding you personally responsible for the fact that I'm > sitting here trying to get my head around this paper instead of doing my > actual, entirely un-Hilbert-transform-related, job. > > -- > Rob Gaddi, Highland Technology > Email address is currently out of orderSorry about the destraction ;-) It should get you to think about vectors and rotations. You know how much I like matrices ;-) Clay
