Hi all, I am having trouble identifying an input/output relationship in a communication system. In the course of my research, I encounter an input/output relationship of this type at time n: y_n = \sum_{l} \sum{l'} a_{n,l,l'} x_{n-l-l'} (The summations are over all l,l' which are finite. It is the result of a transmission through a doubly selective channel) I am not sure what it represents but it almost looks like a discrete time convolution. I am ultimately trying to put it in vector form. I need to know if this is some well known operation or a reference on this type of operation. It would be highly appreciated, as I cannot find anything on it.
Identifying this pseudo convolution operation
Started by ●May 13, 2010
Reply by ●May 14, 20102010-05-14
On May 13, 6:38�pm, "L13" <loic.cv@n_o_s_p_a_m.gmail.com> wrote:> Hi all, > > I am having trouble identifying an input/output relationship in a > communication system. > > In the course of my research, I encounter an input/output relationship of > this type at time n: > > y_n = \sum_{l} \sum{l'} a_{n,l,l'} x_{n-l-l'} > > (The summations are over all l,l' which are finite. > It is the result of a transmission through a doubly selective channel) > > I am not sure what it represents but it almost looks like a discrete time > convolution. I am ultimately trying to put it in vector form. > I need to know if this is some well known operation or a reference on this > type of operation. It would be highly appreciated, as I cannot find > anything on it.Looks like a 2-D cross correlation to me. But there are some inconsistancies in the notation. Your function a_{} has 3 arguments and x_{} has just one. Did you omit some commas? Clay
On May 14, 2:19=A0pm, Clay <c...@claysturner.com> wrote:> On May 13, 6:38=A0pm, "L13" <loic.cv@n_o_s_p_a_m.gmail.com> wrote: > > > > > > > Hi all, > > > I am having trouble identifying an input/output relationship in a > > communication system. > > > In the course of my research, I encounter an input/output relationship =of> > this type at time n: > > > y_n =3D \sum_{l} \sum{l'} a_{n,l,l'} x_{n-l-l'} > > > (The summations are over all l,l' which are finite. > > It is the result of a transmission through a doubly selective channel) > > > I am not sure what it represents but it almost looks like a discrete ti=me> > convolution. I am ultimately trying to put it in vector form. > > I need to know if this is some well known operation or a reference on t=his> > type of operation. It would be highly appreciated, as I cannot find > > anything on it. > > Looks like a 2-D cross correlation to me. But there are some > inconsistancies in the notation. Your function a_{} has 3 arguments > and x_{} has just one. Did you omit some commas? > > Clay- Hide quoted text - > > - Show quoted text -Clay, If that were the case (i.e.g, a_{n,I,I'} and x_{n,I,I'}), wouldn't this be a matrix multiplication yielding a vector? Where the matrices a and x vary with time, n? Which doesn't make sense to me. For example, let I =3D I' , with 1<=3D I <=3D3, then the sumations, for a particular n, would be a 3-dimensional column vector (I will drop the {} notation) a11*x11 + a12*x12 + a13*x13 a21*x21 + a22*x22 + a23*x23 a31*x31 + a32*x32 + a33*x33 this is the same as matrix multiplication _ _ _ _ | a11 a12 a13 | | x11 x21 x31 | | a21 a22 a23 | | x12 x22 x32 | | a31 a32 a33 | | x13 x23 x33 | -- -- -- -- (notice x elements are transposed) where only those elements are used where the row number for a is the same as the column number for x (a row 1 time x column 1, but not a row 1 time x column 2). In other words, A * X with a_{I,I'} * x_{I',I} =3D 0 for I not equal to I' (notice I switched I and I' for the x elements of X). So it seems that to make linear algebra operator one would A * X'; a_{I,I'} * x_{I',I} =3D 0 for I /=3D I' (X' means X transposed) As I said, makes no sense to me. Maurice Givens
Reply by ●May 15, 20102010-05-15
>On May 13, 6:38=A0pm, "L13" <loic.cv@n_o_s_p_a_m.gmail.com> wrote: >> Hi all, >> >> I am having trouble identifying an input/output relationship in a >> communication system. >> >> In the course of my research, I encounter an input/output relationshipof>> this type at time n: >> >> y_n =3D \sum_{l} \sum{l'} a_{n,l,l'} x_{n-l-l'} >> >> (The summations are over all l,l' which are finite. >> It is the result of a transmission through a doubly selective channel) >> >> I am not sure what it represents but it almost looks like a discretetime>> convolution. I am ultimately trying to put it in vector form. >> I need to know if this is some well known operation or a reference onthi=>s >> type of operation. It would be highly appreciated, as I cannot find >> anything on it. > >Looks like a 2-D cross correlation to me. But there are some >inconsistancies in the notation. Your function a_{} has 3 arguments >and x_{} has just one. Did you omit some commas? > >Clay >Hmm it almost seems like a 2-D cross correlation. x is an input vector, so it only has one dimension.
