BT denotes the product of the 3 dB bandwidth of the shaping pulse in an FSK system and the symbol time. My question has to do with the conventional definition of B. My first thought was to use the 3 dB bandwidth of a bandpass function obtained by translating the baseband pulse up to the FSK center frequency; or equivalently, twice the bandwidth (from 0 Hz to the 3 dB point) of the pulse viewed as a lowpass function at baseband. However, doing it this way results in a curve that disagrees with some published shaping curves; it appears people (in at least some cases) leave the factor of two out, and just look at the bandwidth of the lowpass function, from 0 Hz to the positive 3 dB point. What is the convention here? Thanks, Steve
Definition of BT in an FSK system
Started by ●July 15, 2010
Reply by ●July 15, 20102010-07-15
Steve Pope wrote:> BT denotes the product of the 3 dB bandwidth of the shaping > pulse in an FSK system and the symbol time. > > My question has to do with the conventional definition of B.BT has to do with the real pulse and real bandwidth. That is lowpass function. VLV
On 7/15/2010 11:30 AM, Steve Pope wrote:> BT denotes the product of the 3 dB bandwidth of the shaping > pulse in an FSK system and the symbol time. > > My question has to do with the conventional definition of B. >I do not know about FSK. But I checked my class notes now, and it says that BT (band width) is the transmission bandwidth, while B is the baseband bandwidth. For example, for normal AM, BT=2*B, for AM, Single sided, BT=B. --Nasser
Vladimir Vassilevsky <nospam@nowhere.com> wrote:>Steve Pope wrote:>> BT denotes the product of the 3 dB bandwidth of the shaping >> pulse in an FSK system and the symbol time.>> My question has to do with the conventional definition of B.>BT has to do with the real pulse and real bandwidth. That is lowpass >function.Thanks. Steve
