hi, can anyone tell me how to perform 2d fft? what i understood for 2d fft is that for each rows we perform individual fft's and place the result on the respective rows and similarly for the columns. what i mean is suppose i have an array of 2d data as: 0000 0110 0110 0000 now what i am trying to do is calculate fft (4 point fft instead of 16 point fft) of the first row (0000) and place the result in first row, calculate the fft for the second row (0110) and place the result in second row and so on. similarly for column calculate the fft for first column (0000) and place the result in the first column and so on. so will this work and will i get the same result as of 16 point fft? thanks
fft question
Started by ●July 31, 2010
Reply by ●July 31, 20102010-07-31
On 7/31/2010 11:15 AM, devil6601 wrote:> hi, > > can anyone tell me how to perform 2d fft? what i understood for 2d fft is > that for each rows we perform individual fft's and place the result on the > respective rows and similarly for the columns. what i mean is suppose i > have an array of 2d data as: > > 0000 > 0110 > 0110 > 0000 > > now what i am trying to do is calculate fft (4 point fft instead of 16 > point fft) of the first row (0000) and place the result in first row, > calculate the fft for the second row (0110) and place the result in second > row and so on. similarly for column calculate the fft for first column > (0000) and place the result in the first column and so on. so will this > work and will i get the same result as of 16 point fft? > > thanks >Have I seen this before, or did I have a prescient dream? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 31.7.10 6:21 , Jerry Avins wrote:> On 7/31/2010 11:15 AM, devil6601 wrote: >> hi, >> >> can anyone tell me how to perform 2d fft? what i understood for 2d fft is >> that for each rows we perform individual fft's and place the result on >> the >> respective rows and similarly for the columns. what i mean is suppose i >> have an array of 2d data as: >> >> 0000 >> 0110 >> 0110 >> 0000 >> >> now what i am trying to do is calculate fft (4 point fft instead of 16 >> point fft) of the first row (0000) and place the result in first row, >> calculate the fft for the second row (0110) and place the result in >> second >> row and so on. similarly for column calculate the fft for first column >> (0000) and place the result in the first column and so on. so will this >> work and will i get the same result as of 16 point fft? >> >> thanks >> > > Have I seen this before, or did I have a prescient dream? > > JerryYou're right. The only thing that changed was the sender's name. Both are from an Indian IP (BSNL Internet, no reverse). Maybe he's not happy with the response and the deadline for the homework is pressing. -- Tauno Voipio
Reply by ●August 3, 20102010-08-03
Tauno Voipio wrote:> On 31.7.10 6:21 , Jerry Avins wrote: >> On 7/31/2010 11:15 AM, devil6601 wrote: >>> hi, >>> >>> can anyone tell me how to perform 2d fft? what i understood for 2d >>> fft is> http://www.cs.unm.edu/~brayer/vision/fourier.html> http://fourier.eng.hmc.edu/e101/lectures/Image_Processing/node6.htmlFred
