Hey there I am the new one and I am from Germany. Currently I am in the USA writing my Bachelor Thesis. I have the following issue: I have an AM modulated signal with a carrier voltage about 100V to 500V and a message voltage of about 250mV. This signal is out of a coil which is part of an RFID reader (more MCID - magnetic coupling... that's why the voltage is so high). The carrier has a frequency of 134.4khz and the message 4khz. My job is it to demodulate the signal digitally (if possible) and do some work with it to get the information out. My idea to get this signal into a DSP was just to take a transformer to put the voltage down to 5V which makes the message really small. Therefore I thought on taking a 16bit DSP and do some oversampling (I thought on 1 to 2MHz concerning the carrier frequency to improve the resolution and noise ratio). I read a ton of articles in this forum and the internet and it's a bit like looking for a needle in a haystack. I think the best way to do this is this http://www.dspguru.com/dsp/tricks/magnitude-estimator way, isn't it?. I am using a C5515 from TI so PLL would be possible. But I don't know if I need PLL because I am producing the signal for the coil with the dsp (a 134.4khz rectangular signal works fine). So I know the frequency and I can produce a internal signal with this timer, too. And a correct knowledge about the carrier is a good thing I think. Therefore I am looking for books to reference which are explaining this... Otherwise I would have to invent it new... I cannot just use something out of the internet without saying why and profing it with a source (book). I hope someone can help me :) Greetings
Synchronous AM demodulation (again...)
Started by ●October 6, 2010
Reply by ●October 6, 20102010-10-06
> I am from Germany.de.sci.electronics would be an alternative.> demodulate the signal digitally (if possible) > ... get the information out.Have look at the datasheet of the old Telefunken / Atmel U2270B reader IC.> take a transformer to put the voltage down to 5VDue to the high voltage a simple diode is easier, its demodulated then. A 4pole Butterworth / Bessel LP-filter follows. Then a schmitt-trigger to get it digital. The manchester decoder is done in the 8 bit microcontroller. MfG JRD
AlanWrench wrote:> Hey there > > I am the new one and I am from Germany. Currently I am in the USA writing > my Bachelor Thesis. > > I have the following issue: > I have an AM modulated signal with a carrier voltage about 100V to 500V and > a message voltage of about 250mV. This signal is out of a coil which is > part of an RFID reader (more MCID - magnetic coupling... that's why the > voltage is so high). The carrier has a frequency of 134.4khz and the > message 4khz. > My job is it to demodulate the signal digitally (if possible) and do some > work with it to get the information out. > My idea to get this signal into a DSP was just to take a transformer to put[...helpless bleat skipped...] Microchip has a bunch of good appnotes on RFID system design. Start from there. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
>> I am from Germany. >de.sci.electronics would be an alternative. > >> demodulate the signal digitally (if possible) >> ... get the information out. > >Have look at the datasheet of the old >Telefunken / Atmel U2270B reader IC.I had a look at this IC. The U2270B could redundantize the DSP and everything. But this is not what my requirements list is telling me for my thesis. Therefore I don't think that I can use this IC. But I have an eye on this. Why not digitally? It seems that you will tell me that it will not work to demodulate the signal inside a DSP 'cause you write nothing about it. If so, tell me why not.> >> take a transformer to put the voltage down to 5V >Due to the high voltage a simple diode is easier, >its demodulated then. A 4pole Butterworth >/ Bessel LP-filter follows. Then a schmitt-trigger >to get it digital. The manchester decoder is >done in the 8 bit microcontroller. > >MfG JRD >Yep, it is possible. Actually this is the actual version of the RFID reader. But it should be digital with a DSP therefore I can not use a 8bit microcontroller or a didoe envelope detector. By the way: it is biphase coded. And I can not see any problems with a transformer and 100V to 500V. At least there are transformers for higher voltages. I could imagine a problem with the small message signal, though.
AlanWrench wrote:>>Have look at the datasheet of the old >>Telefunken / Atmel U2270B reader IC. > > > I had a look at this IC. The U2270B could redundantize the DSP and > everything. > Why not digitally?What is the point? Digital is going to be about 100 times more expensive and 10 times more complex.> It seems that you will tell me that it will not work to > demodulate the signal inside a DSP 'cause you write nothing about it. If > so, tell me why not.Sure you can make a right-angled toothbrush to clean teath from behind a corner. It could work but for some reason they don't make curved toothbrushes.> And I can not see any problems with a transformer and 100V to 500V. At > least there are transformers for higher voltages. I could imagine a problem > with the small message signal, though.You didn't try to accomplish anything yet; that's why you don't see any problems. VLV
> > >AlanWrench wrote: > > >>>Have look at the datasheet of the old >>>Telefunken / Atmel U2270B reader IC. >> >> >> I had a look at this IC. The U2270B could redundantize the DSP and >> everything. >> Why not digitally? > >What is the point? Digital is going to be about 100 times more expensive >and 10 times more complex.True. But to be honest it wasn't my idea, I just choose the project.>> And I can not see any problems with a transformer and 100V to 500V. At >> least there are transformers for higher voltages. I could imagine aproblem>> with the small message signal, though.>You didn't try to accomplish anything yet; that's why you don't see any >problems.Yep I didn't. Unfortunately I don't have the time to test several ways. The transformer would have been one thing but because of that I wrote in this forum to get this idea ... kind of accomplished or destroyed ;) I am looking at the microchip site and see if I can find something helpfull. I also will see if I can use this IC or not. Anyhow: Can someone tell me a book about the demodulation with complex numbers? And can someone explain me the problem with the transformer? Cheers
On 10/06/2010 07:37 AM, AlanWrench wrote:>>> I am from Germany. >> de.sci.electronics would be an alternative. >> >>> demodulate the signal digitally (if possible) >>> ... get the information out. >> >> Have look at the datasheet of the old >> Telefunken / Atmel U2270B reader IC. > > > I had a look at this IC. The U2270B could redundantize the DSP and > everything. But this is not what my requirements list is telling me for my > thesis. Therefore I don't think that I can use this IC. But I have an eye > on this.If you have a solution that's well established in the analog world and you want to implement it in the DSP world, it is smart to fully understand the analog implementation of the solution. With luck just simulating the analog implementation in DSP will be a pretty good solution, but even if that doesn't get you there, when you do the mathematical analysis of the analog solution you may find your "DSP answer" staring you in the face. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 10/06/2010 08:04 AM, Vladimir Vassilevsky wrote:> > > AlanWrench wrote: > > >>> Have look at the datasheet of the old >>> Telefunken / Atmel U2270B reader IC. >> >> >> I had a look at this IC. The U2270B could redundantize the DSP and >> everything. >> Why not digitally? > > What is the point? Digital is going to be about 100 times more expensive > and 10 times more complex.If the prof wants it done with a DSP then that's the "right" solution, regardless of how it may survive in the commercial world. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 10/06/2010 04:19 AM, AlanWrench wrote:> Hey there > > I am the new one and I am from Germany. Currently I am in the USA writing > my Bachelor Thesis. > > I have the following issue: > I have an AM modulated signal with a carrier voltage about 100V to 500V and > a message voltage of about 250mV. This signal is out of a coil which is > part of an RFID reader (more MCID - magnetic coupling... that's why the > voltage is so high). The carrier has a frequency of 134.4khz and the > message 4khz. > > My job is it to demodulate the signal digitally (if possible) and do some > work with it to get the information out. > > My idea to get this signal into a DSP was just to take a transformer to put > the voltage down to 5V which makes the message really small. Therefore I > thought on taking a 16bit DSP and do some oversampling (I thought on 1 to > 2MHz concerning the carrier frequency to improve the resolution and noise > ratio). > > I read a ton of articles in this forum and the internet and it's a bit like > looking for a needle in a haystack. > I think the best way to do this is this > http://www.dspguru.com/dsp/tricks/magnitude-estimator way, isn't it?. > I am using a C5515 from TI so PLL would be possible. But I don't know if I > need PLL because I am producing the signal for the coil with the dsp (a > 134.4khz rectangular signal works fine). So I know the frequency and I can > produce a internal signal with this timer, too. And a correct knowledge > about the carrier is a good thing I think. > > Therefore I am looking for books to reference which are explaining this... > Otherwise I would have to invent it new... I cannot just use something out > of the internet without saying why and profing it with a source (book). > I hope someone can help me :)Have you googled "synchronous AM"? Have you read up on synchronous AM demodulation in the ARRL handbook (that's always the go-to place for any communications technology that may intersect with amateur radio)? Monolithic ADCs often get noisier as their maximum sampling rate goes up -- do you gain anything using a really fast ADC sampled at 1MHz vs. a slower ADC sampled at 100kHz? Your signal is, indeed, teeny compared to your carrier. Is there any way that you can subtract out your carrier before the ADC step, or is that "not digital enough" for your prof? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
> By the way: it is biphase coded. Manchester goes by many names ...> The U2270B could redundantize the DSP and everything.Thats a version were the U2270 is replaced by standard components: http://www.embeddedFORTH.de/temp/r.pdf ( text is in german ) The MC68HC908 8 bit controller generates the 125kHz via timer. And samples the analog signal via 8 bit A/D. The schmitt trigger and some ALC-typ adjusting of switching thesholds is done in software. The filter is analog, the MC68HC908 was not fast enough for that. Could be software, but probably not a reason to switch to DSP, rather another faster controller.> But this is not what my requirements list is telling me for my > thesis.In theory a fancy demodulator could be useful to extend the range of the reader by detecting very weak signals. But these RFIDs are powered by the reader. If they do not get enough energy they will not send a weak signal but will be unable to send any signal. Adjusting the frequency to the LC-component tolerance of the RFID can be usefull to improve the strengh of the signal, but isn?t related to demodulation directly.> And I can not see any problems with a transformer and 100V to 500V. At > least there are transformers for higher voltages. I could imagine a problem > with the small message signal, though.A 200V signal with 1V load modulation is easily handled by the si-diode circuit. 0,25V not so. Schottky isn?t that usefull at high voltages, so 0,5V would be hard too. So you could scale the signal down and feed it via A/D-converter to a DSP. 8 bit would not be enough, probably 12 bit or more. Samplerate 2x125kHz = 250kHz, some analog circuit that makes sure it samples at the peaks would be usefull. Remains only the real world problem: would a marginaly improved performance be relevant relative to the more complex circuit ? MfG JRD
