> Okay - I think I will miss something to answer but I'll do my best.Read more of the datasheets and applicationnotes and you will get a clearer picture what really affects performance of the reader. It might be advisable to breadboard a U2270 from scratch http://www.embeddedFORTH.de/temp/marc4_4.pdf ( text german ) just to get a feel for it. There are books too. The one i can recommend: http://www.amazon.de/RFID-Handbuch-Klaus-Finkenzeller/dp/3446220712 has a translation by Wiley: http://www.amazon.com/RFID-Handbook-Fundamentals-Identification-Communication/dp/0470695064/ref=sr_1_1?ie=UTF8&qid=1286432749&sr=8-1> Sure, there are a bunch of ways to get rid of the carrier.Well again: suppose you scale down the signal by a resistor divider or a another coil that monitors the field. And the signal goes to a 12 bit flash-A/D that is triggered by some additional analog circuitry so it samples the 125kHz carrier at the peaks. 250k samples/sec now. Since the signal will probably be not symmetric one would process the positive and negative peaks, ( two 125k sample streams ) seperatly. The digital signal consists of the large DC-part ( "200V" ) and a small ripple that looks like the Manchester-coded signal. A highpass/bandpass-filter would remove the DC and the schmitt-trigger convert it binary. One can do that for both streams ( contain the same signal ) and combine the result. The A/D is obviously not needed: sample & hold will do. After filtering the 8 bit A/D of a slow 8 bit controller would do rest of the job. That would not be limited to a 1V signal like the si-diode but could handle the 0,25 signal too. But as already said: another approach is to get signal up to 1V by adjusting the frequency/coupling. MfG JRD
Synchronous AM demodulation (again...)
Started by ●October 6, 2010
Reply by ●October 7, 20102010-10-07
On 07-10-2010 @ 07:58:23 AlanWrench <stud.magraf@n_o_s_p_a_m.googlemail.com> wrote:> Doesn't make it better ... Everyone of use was in the situation to be the > newbeeI wasn't. At least I'd never tried to break the wall with my head. Insted I was looking for a hammer.> and no one would like a post like this ...I would like. It's very motivating information which I couldn't probably find by myself. -- Mikolaj
In article <C7KdnZdeHa1TpDDRnZ2dnUVZ_g6dnZ2d@giganews.com>, Vladimir Vassilevsky <nospam@nowhere.com> wrote:> AlanWrench wrote: > > > What would be a good signal conditioning before going into the ADC? > > We had some discussion today and we figured out two plans: > > > 1) I will wire a transformer just to see how the signal at the output > > looks > > like > > 2) When I have my stuff I will use the diode envelope detector and go > > after > > that into a ADC and from there to the DSP. If the whole thing is > > working > > with this and I have time I will see if the transformer version works > > or > > not > > > > I am still looking for something to read like a book about the analog thing > > (envelope detector, other solutions) ... anyone has a good idea for that? > > IdiotHey Vlad: Please turn back on your "Am I being a douchebag?" filter. Cheers, Ken Prager
On 10/06/2010 10:45 PM, AlanWrench wrote:>> >> >> AlanWrench wrote: >> >>> What would be a good signal conditioning before going into the ADC? >>> We had some discussion today and we figured out two plans: >> >>> 1) I will wire a transformer just to see how the signal at the output >>> looks >>> like >>> 2) When I have my stuff I will use the diode envelope detector and go >>> after >>> that into a ADC and from there to the DSP. If the whole thing is >>> working >>> with this and I have time I will see if the transformer version > works >>> or >>> not >>> >>> I am still looking for something to read like a book about the analog > thing >>> (envelope detector, other solutions) ... anyone has a good idea for > that? >> >> Idiot >> >> > > A very kind and smart way to greet new guys on the board ... Actually I > don't know why I should be a idiot or rather why you call me one. > Maybe because I use the time during waiting for my stuff to see why a > transformer is bad or I am a idiot 'cause I am looking for books to read > and inform myself (besides the ARRL Handbook and Understanding Digital > Signal Processing). > > But okay. It's your opinion though. > Cheers and thanks for helping me so far.Don't feel like you have to encourage him when he gets this way. Either he's forgotten what it's like to be a student, or he was really good at engineering and forgets all of the things that he was really bad at. Think of it as an opportunity to be noble. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
>> Okay - I think I will miss something to answer but I'll do my best. > >Read more of the datasheets and applicationnotes and you will >get a clearer picture what really affects performance of the reader. >It might be advisable to breadboard a U2270 from scratch >http://www.embeddedFORTH.de/temp/marc4_4.pdf ( text german ) >just to get a feel for it. >There are books too. The one i can recommend: >http://www.amazon.de/RFID-Handbuch-Klaus-Finkenzeller/dp/3446220712 >has a translation by Wiley: >http://www.amazon.com/RFID-Handbook-Fundamentals-Identification-Communication/dp/0470695064/ref=sr_1_1?ie=UTF8&qid=1286432749&sr=8-1 > >> Sure, there are a bunch of ways to get rid of the carrier. > >Well again: suppose you scale down the signal by a resistor divider >or a another coil that monitors the field. And the signal >goes to a 12 bit flash-A/D that is triggered by some additional >analog circuitry so it samples the 125kHz carrier at the peaks. >250k samples/sec now. Since the signal will probably be not >symmetric one would process the positive and negative peaks, >( two 125k sample streams ) seperatly. The digital signal >consists of the large DC-part ( "200V" ) and a small ripple that >looks like the Manchester-coded signal. A highpass/bandpass-filter >would remove the DC and the schmitt-trigger convert it binary. >One can do that for both streams ( contain the same signal ) >and combine the result. >The A/D is obviously not needed: sample & hold will do. >After filtering the 8 bit A/D of a slow 8 bit controller >would do rest of the job. >That would not be limited to a 1V signal like the si-diode but >could handle the 0,25 signal too. >But as already said: another approach is to get signal up >to 1V by adjusting the frequency/coupling. > >MfG JRD > >I know it sounds dumb but I have to ask if I got this right: Do you mean that I should take/need 2 ADCs to monitor the signal? I added something to my original plan: A analog circuit for peak detection after the diode envelope detector to get the peaks. But I have to do some research on this, never heart/used something like this before but it sounds like that it makes sense ;)
> Do you mean that I should take/need 2 ADCs to monitor the signal?No, you have only one signal so one A/D with 250kHz samplerate will do for the 125kHz carrier if you hit the peaks. Thats a fairly typical industrial synchronous demodulator: http://www.seekic.com/uploadfile/ic-circuit/200972452849422.gif It uses a zero-crossing detector ( much easier then a peak-detector ) to generate a digital signal that controls the switch. In this implementation the amplifier is switched inverting/ noninverting. The following RC-lowpass smooths the rectified sinewave to DC. But depending of the way the carrier is generated i would not take it for granted that the sinewave is symmetric/clean. Therefore combining both peaks like in the synchronous demodulator may be counterproductive. MfG JRD
>> Do you mean that I should take/need 2 ADCs to monitor the signal? >No, you have only one signal so one A/D with 250kHz samplerate will >do for the 125kHz carrier if you hit the peaks. > >Thats a fairly typical industrial synchronous demodulator: >http://www.seekic.com/uploadfile/ic-circuit/200972452849422.gif >It uses a zero-crossing detector ( much easier then a peak-detector ) >to generate a digital signal that controls the switch. >In this implementation the amplifier is switched inverting/ >noninverting. The following RC-lowpass smooths the rectified >sinewave to DC. > >But depending of the way the carrier is generated i would not >take it for granted that the sinewave is symmetric/clean. >Therefore combining both peaks like in the synchronous demodulator >may be counterproductive. > >MfG JRD >Not directly an answer for my question but interesting to see how a demodulator analog works. Why the switched capacitor? And is the idea to digitalize after the envelope detector and a lowpassfilter inside the dsp dump or not? I'm not sure right now 'cause I need something like a Schmitt-Trigger after the filter to have clear 1 and 0 values ... Therefore I could just use a microcontroller ... Dump requirements -.-
Reply by ●October 8, 20102010-10-08
>> Thats a fairly typical industrial synchronous demodulator> Not directly an answer for my questionIf your problem is "can?t use a diode because 1V signal is needed and the spec says 0,25V is available" then the obvious next step is a synchronous demodulator that replaces the diode by an analog switch.> Why the switched capacitor?There is no switched capacitor. Its a switched amplifier gain +1 or -1. Works as a full-wave rectifier. The advantage of analog circuits is that they have standard symbols and are easier to grasp then flowcharts for software. Implementation is most often possible analog or digital.> Therefore I could just use a microcontroller ... Dump > requirements -.-If this is your Bachelor Thesis what do you intend to do afterwards ? If you go into industry the obvious step would be to join a company that builds this type of circuits. But then it should better work, be technically reasonable. If on the other hand you go for academia a DSP will not do, thats old 80ies technology. You will have to throw in at least a FPGA and a Kalman filter. MfG JRD
