I have given a audio file (sine wave)800 Hz as an input to my FFT algorithm.I have got 8192 power spectrum samples in a array .What is the best and easy way to check whether my output is right or wrong.If i give a silent audio file. The out out is zero for all samples.In a sine wav the o/p increases from 20 (0th sample )to 26059811(743 sample) and decreases gradually to 40.Any ideas will be more helpful.If i get an idea of the output range then i can prove technically that FFT is working or not.Any ideas will be more helpful. Refer http://stackoverflow.com/questions/4040918/how-to-check-the-fft-results-in-iphone for any technical doubts
How to check the FFT results of a sine wave?
Started by ●October 28, 2010
