>>>>On Nov 2, 2:57=A0pm, HardySpicer <gyansor...@gmail.com> wrote: >>>>> On Nov 3, 6:40=A0am, "pacman101" <janpac01@n_o_s_p_a_m.yahoo.com> >>>wrote: >>>>> >>>>> > Hello, >>>>> >>>>> > I would just like to clarify what people mean when they say a >signal >>>is >>>>> > colored? =A0 >>>>> >>>>> > My assumption is it means white gaussian noise is added to the >>signal, >>>= >>>>but >>>>> > I just want this to be clarified. >>>>> >>>>> > Thank you. >>>>> >>>>> It means they have spent coloured wrongly. >>>>> >>>>> Hardy >>>> >>>>Irony? :) >>>> >>>>To address the OP, white is used to describe signals with a flat power >>>>spectral density throughout the frequency range of interest. The term >>>>white of course comes from our understanding (somewhat of a >>>>misconception) of visible light, where perfectly white light is a >>>>superposition of all visible light frequencies with equal weighting >>>>(that is equal amplitude not necessarily phase). Of course in reality, >>>>while what I just said is true, we only need to have the three >>>>different types of cones in our eyes stimulated equally to see white >>>>light, so there are theoretically infinite number of combinations of >>>>frequencies that can produce white light. But I digress... >>>> >>>>Colored, in the sense of "colored noise" or a "coloring filter" is >>>>anything that does not have a flat power spectral density, or a filter >>>>that takes a white signal in, and produces a non-white output. This >>>>distortion would be considered "coloring" the signal. >>>>> >>Yes. Usually when applied to a comms channel, and the flatness of the >>signal spectral across that channel. >> >>If you have been reading about LMS and NLMS you should have alreadyfound>>why a reasonably flat spectrum around the adaption loop matters. >> >>Steve >> >> >>Steve >> > >So would it be better if I go with Affine Projection? How about >Gradient-adaptive learning algorithms? I haven't thoroughly studiedthese>more complex algorithms yet.If you haven't studied them, why would you pre-suppose they offer an improvement in this particular area? How about applying a little science and engineering, instead of picking up on the spiel from the marketing dept. Steve
What does colored signal mean?
Started by ●November 2, 2010
Reply by ●November 3, 20102010-11-03
>>>>>On Nov 2, 2:57=A0pm, HardySpicer <gyansor...@gmail.com> wrote: >>>>>> On Nov 3, 6:40=A0am, "pacman101" <janpac01@n_o_s_p_a_m.yahoo.com> >>>>wrote: >>>>>> >>>>>> > Hello, >>>>>> >>>>>> > I would just like to clarify what people mean when they say a >>signal >>>>is >>>>>> > colored? =A0 >>>>>> >>>>>> > My assumption is it means white gaussian noise is added to the >>>signal, >>>>= >>>>>but >>>>>> > I just want this to be clarified. >>>>>> >>>>>> > Thank you. >>>>>> >>>>>> It means they have spent coloured wrongly. >>>>>> >>>>>> Hardy >>>>> >>>>>Irony? :) >>>>> >>>>>To address the OP, white is used to describe signals with a flatpower>>>>>spectral density throughout the frequency range of interest. The term >>>>>white of course comes from our understanding (somewhat of a >>>>>misconception) of visible light, where perfectly white light is a >>>>>superposition of all visible light frequencies with equal weighting >>>>>(that is equal amplitude not necessarily phase). Of course inreality,>>>>>while what I just said is true, we only need to have the three >>>>>different types of cones in our eyes stimulated equally to see white >>>>>light, so there are theoretically infinite number of combinations of >>>>>frequencies that can produce white light. But I digress... >>>>> >>>>>Colored, in the sense of "colored noise" or a "coloring filter" is >>>>>anything that does not have a flat power spectral density, or afilter>>>>>that takes a white signal in, and produces a non-white output. This >>>>>distortion would be considered "coloring" the signal. >>>>>> >>>Yes. Usually when applied to a comms channel, and the flatness of the >>>signal spectral across that channel. >>> >>>If you have been reading about LMS and NLMS you should have already >found >>>why a reasonably flat spectrum around the adaption loop matters. >>> >>>Steve >>> >>> >>>Steve >>> >> >>So would it be better if I go with Affine Projection? How about >>Gradient-adaptive learning algorithms? I haven't thoroughly studied >these >>more complex algorithms yet. > >If you haven't studied them, why would you pre-suppose they offer an >improvement in this particular area? How about applying a little science >and engineering, instead of picking up on the spiel from the marketing >dept. > >Steve > >Steve, There is only so much time in the world and not to mention we all have to meet deadlines. Unfortunately I am no subject matter expert and in order to save some time asking questions can alleviate some of the confusion. Science and engineering takes quite a bit of precious hours, and sometimes asking a question where there are subject matter experts can ease some of the pressure. Believe me I do my homework, but when I can't understand something I just gotta ask. Thanks for all the helpful information you've given thus far. They all have been very helpful.
Reply by ●November 4, 20102010-11-04
>>>>>>On Nov 2, 2:57=A0pm, HardySpicer <gyansor...@gmail.com> wrote: >>>>>>> On Nov 3, 6:40=A0am, "pacman101" <janpac01@n_o_s_p_a_m.yahoo.com> >>>>>wrote: >>>>>>> >>>>>>> > Hello, >>>>>>> >>>>>>> > I would just like to clarify what people mean when they say a >>>signal >>>>>is >>>>>>> > colored? =A0 >>>>>>> >>>>>>> > My assumption is it means white gaussian noise is added to the >>>>signal, >>>>>= >>>>>>but >>>>>>> > I just want this to be clarified. >>>>>>> >>>>>>> > Thank you. >>>>>>> >>>>>>> It means they have spent coloured wrongly. >>>>>>> >>>>>>> Hardy >>>>>> >>>>>>Irony? :) >>>>>> >>>>>>To address the OP, white is used to describe signals with a flat >power >>>>>>spectral density throughout the frequency range of interest. Theterm>>>>>>white of course comes from our understanding (somewhat of a >>>>>>misconception) of visible light, where perfectly white light is a >>>>>>superposition of all visible light frequencies with equal weighting >>>>>>(that is equal amplitude not necessarily phase). Of course in >reality, >>>>>>while what I just said is true, we only need to have the three >>>>>>different types of cones in our eyes stimulated equally to see white >>>>>>light, so there are theoretically infinite number of combinations of >>>>>>frequencies that can produce white light. But I digress... >>>>>> >>>>>>Colored, in the sense of "colored noise" or a "coloring filter" is >>>>>>anything that does not have a flat power spectral density, or a >filter >>>>>>that takes a white signal in, and produces a non-white output. This >>>>>>distortion would be considered "coloring" the signal. >>>>>>> >>>>Yes. Usually when applied to a comms channel, and the flatness of the >>>>signal spectral across that channel. >>>> >>>>If you have been reading about LMS and NLMS you should have already >>found >>>>why a reasonably flat spectrum around the adaption loop matters. >>>> >>>>Steve >>>> >>>> >>>>Steve >>>> >>> >>>So would it be better if I go with Affine Projection? How about >>>Gradient-adaptive learning algorithms? I haven't thoroughly studied >>these >>>more complex algorithms yet. >> >>If you haven't studied them, why would you pre-suppose they offer an >>improvement in this particular area? How about applying a little science >>and engineering, instead of picking up on the spiel from the marketing >>dept. >> >>Steve >> >> > >Steve, > >There is only so much time in the world and not to mention we all have to >meet deadlines. Unfortunately I am no subject matter expert and in order >to save some time asking questions can alleviate some of the confusion. >Science and engineering takes quite a bit of precious hours, andsometimes>asking a question where there are subject matter experts can ease some of >the pressure. Believe me I do my homework, but when I can't understand >something I just gotta ask. Thanks for all the helpful informationyou've>given thus far. They all have been very helpful.If you want to use algorithms without understanding their strengths, weaknesses, and obscure quirks just make sure those deadlines don't include "field proven" as a criterion. All you should expect from a forum like this is a few pointers in appropriate directions. Steve
In the sound engineering / recording world, we say a signal is 'coloured' if the system leans toward an undesirable response of any sort - i.e. a nasty freq / phase response, e.g. the effect of a dry solder joint or a cheap microphone. It's analogous to a purple lens filter, so a Neumann U89 is like one of those big gluey gorgeous looking Leica lenses : )
