Hello, We're using CCS 3.3 and the Signum JET-C2000 JTAG solution. I'm having trouble connecting consistently to the F2809. I can connect to a working F2809 the first time, flash it using the flash tool inside CCS, and run the code. However, from that point on I can't stop the emulator, and once disconnected I can't reconnect. For example, this is a message I get when I attempt to reconnect: Error connecting to the target: Error 0x80000200/-1031 Fatal Error during: OCS, Device driver: Problem with the Emulation Controller. It is recommended to RESET EMULATOR. This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target. I/O Port = 240 Board Name: F2809 JTAGjet Emulator Cpu Name: TMS320F2809_0 Abort: Close Code Composer Studio. Retry: Try to connect to the target again. Cancel: Remain disconnected from the target Diagnostic: Run diagnostic utility. This has happened on two different boards now. I am suspecting the problem is in TI's security mode / CSM, but as far as I know I did NOT lock the chip with a password. Is it possible that rogue code can write all zeros to the password section (which would disable all future debug)? I am grasping at straws since I don't know this specific processor very well. If anyone recognizes this problem, I sure would appreciate a pointer or some information on it. I've already searched TI's E2E forum, and while it seems others have had similar problems recently (December 2010), I didn't see a solution. --Randy Yaets
Emulation Problems with the TMS320F2809
Started by ●February 14, 2011
Reply by ●February 15, 20112011-02-15
On Feb 14, 5:57�pm, Randy Yates <ya...@ieee.org> wrote:> Hello, > > We're using CCS 3.3 and the Signum JET-C2000 JTAG solution. > > I'm having trouble connecting consistently to the F2809. I can connect > to a working F2809 the first time, flash it using the flash tool > inside CCS, and run the code. However, from that point on I can't stop > the emulator, and once disconnected I can't reconnect. For example, > this is a message I get when I attempt to reconnect: > > � Error connecting to the target: > � Error 0x80000200/-1031 > � Fatal Error during: OCS, > � Device driver: Problem with the Emulation Controller. > � It is recommended to RESET EMULATOR. �This will disconnect each > � target from the emulator. �The targets should then be power cycled > � or hard reset followed by an emureset and reconnect to each target. > > � I/O Port = 240 > > � Board Name: F2809 JTAGjet Emulator > � Cpu Name: TMS320F2809_0 > > � Abort: � � � � � � � �Close Code Composer Studio. > � Retry: � � � � � � � �Try to connect to the target again. > � Cancel: � � � � � � � Remain disconnected from the target > � Diagnostic: � Run diagnostic utility. > > This has happened on two different boards now. I am suspecting the > problem is in TI's security mode / CSM, but as far as I know I did NOT > lock the chip with a password. Is it possible that rogue code can > write all zeros to the password section (which would disable all > future debug)? > > I am grasping at straws since I don't know this specific processor > very well. If anyone recognizes this problem, I sure would appreciate > a pointer or some information on it. I've already searched TI's E2E > forum, and while it seems others have had similar problems recently > (December 2010), I didn't see a solution. > > --Randy YaetsHi Randy, Have you checked 2809 errata. I know (and have personal experience) that one revision has some difficulties how the CPU clock is generated. I don't recall the details, but the symptoms were similar. Mitja
On 02/15/2011 02:30 AM, Mitja Nemec wrote:> On Feb 14, 5:57 pm, Randy Yates<ya...@ieee.org> wrote: >> Hello, >> >> We're using CCS 3.3 and the Signum JET-C2000 JTAG solution. >> >> I'm having trouble connecting consistently to the F2809. I can connect >> to a working F2809 the first time, flash it using the flash tool >> inside CCS, and run the code. However, from that point on I can't stop >> the emulator, and once disconnected I can't reconnect. For example, >> this is a message I get when I attempt to reconnect: >> >> Error connecting to the target: >> Error 0x80000200/-1031 >> Fatal Error during: OCS, >> Device driver: Problem with the Emulation Controller. >> It is recommended to RESET EMULATOR. This will disconnect each >> target from the emulator. The targets should then be power cycled >> or hard reset followed by an emureset and reconnect to each target. >> >> I/O Port = 240 >> >> Board Name: F2809 JTAGjet Emulator >> Cpu Name: TMS320F2809_0 >> >> Abort: Close Code Composer Studio. >> Retry: Try to connect to the target again. >> Cancel: Remain disconnected from the target >> Diagnostic: Run diagnostic utility. >> >> This has happened on two different boards now. I am suspecting the >> problem is in TI's security mode / CSM, but as far as I know I did NOT >> lock the chip with a password. Is it possible that rogue code can >> write all zeros to the password section (which would disable all >> future debug)? >> >> I am grasping at straws since I don't know this specific processor >> very well. If anyone recognizes this problem, I sure would appreciate >> a pointer or some information on it. I've already searched TI's E2E >> forum, and while it seems others have had similar problems recently >> (December 2010), I didn't see a solution. >> >> --Randy Yaets > > Hi Randy, > > Have you checked 2809 errata. I know (and have personal experience) > that one revision has some difficulties how the CPU clock is > generated. I don't recall the details, but the symptoms were similar.Hi Mitja, Thank you for the lead. We were also told that, e.g., if the clock were not initialized correctly this problem may occur. Alas, CLKOUT is a nice 100 MHz. --Randy -- Randy Yates Digital Signal Labs 919-577-9882 http://www.digitalsignallabs.com yates@digitalsignallabs.com
