Maybe somebody can help me think about this the right way. Ok, it is well known that there is an 'equivalence' in convolution in the time domain to multiplication in the frequncy domain, so consider this... Say we have a modulated bitstream of lets say 10 bits and knew what they were., then did a simple matched filter operation (on the modulated signal maybe perurbed by noise that corrupted exactly 1 bit), and compared the bits to the output of the matched filter... we should be able to recover the bits and see which one was in error. Now lets try this in the frequency domain... We take the transform of the 10 bitstream. Now since the matched filtering operation is really just convolution time reversed, we expect to be able to take the transform of the matched filter and multiply the phase by a -1, then do the multiplication F(k)(bits)*H(k)(matched filter negative phase). {please excuse my crude notation}. Now what? Will we never be able to find out which bit was in error?, The way im thinking about it.. I shouldnt have to take the inverse transform, to get my answer... the 'information' content cant change due to a linear transform assuming the basis functions are complete. Any thoughts?
Matched Filter In the Frequency Domain Question
Started by ●April 6, 2011
Reply by ●April 6, 20112011-04-06
On Apr 6, 9:08�am, "westocl" <cweston_@n_o_s_p_a_m.hotmail.com> wrote:> Maybe somebody can help me think about this the right way. � > > Ok, it is well known that there is an 'equivalence' in convolution in the > time domain to multiplication in the frequncy domain, so consider this... > > Say we have a modulated bitstream of lets say 10 bits and knew what they > were., then did a simple matched filter operation (on the modulated signal > maybe perurbed by noise that corrupted exactly 1 bit), and compared the > bits to the output of the matched filter... we should be able to recover > the bits and see which one was in error. > > Now lets try this in the frequency domain... We take the transform of the > 10 bitstream. Now since the matched filtering operation is really just > convolution time reversed, we expect to be able to take the transform of > the matched filter and multiply the phase by a -1, then do the > multiplication �F(k)(bits)*H(k)(matched filter negative phase). {please > excuse my crude notation}. > > Now what? Will we never be able to find out which bit was in error?, The > way im thinking about it.. I shouldnt have to take the inverse transform, > to get my answer... the 'information' content cant change due to a linear > transform assuming the basis functions are complete. > > Any thoughts?You are correct in that you can equivalently perform convolution in the frequency domain. I'm not sure why you think that an inverse transform shouldn't be needed in order to recover the time-domain information bits. There is no loss of information in translating between the two domains (with infinite precision). But that doesn't change the fact that it's easier to get at certain results in different domains; that's a large reason for analyzing signals in multiple contexts. There's no information loss in applying AES encryption with a known key to ASCII text; that doesn't mean that you should expect to be able to read a block of ciphertext and get the same utility that the plaintext gives you. Jason
On Apr 6, 8:08�am, "westocl" <cweston_@n_o_s_p_a_m.hotmail.com> wrote:> Maybe somebody can help me think about this the right way. � > > Ok, it is well known that there is an 'equivalence' in convolution in the > time domain to multiplication in the frequncy domain, so consider this... > > Say we have a modulated bitstream of lets say 10 bits and knew what they > were., then did a simple matched filter operation (on the modulated signal > maybe perurbed by noise that corrupted exactly 1 bit), and compared the > bits to the output of the matched filter... we should be able to recover > the bits and see which one was in error. > > Now lets try this in the frequency domain... We take the transform of the > 10 bitstream. Now since the matched filtering operation is really just > convolution time reversed, we expect to be able to take the transform of > the matched filter and multiply the phase by a -1, then do the > multiplication �F(k)(bits)*H(k)(matched filter negative phase). {please > excuse my crude notation}. > > Now what? Will we never be able to find out which bit was in error?, The > way im thinking about it.. I shouldnt have to take the inverse transform, > to get my answer... the 'information' content cant change due to a linear > transform assuming the basis functions are complete. > > Any thoughts?Add up all the Fourier Transform values. You should get a real number (the imaginary part should cancel out in the absence of noise but when noise is present, you may get a complex number whose imaginary component should be discarded). The real number that you would get in the absence of noise can take on any one of 2^10 equally spaced values corresponding to the values of the 10 bits. The real number you just got by the summation of Fourier Transform values will almost surely not be any of these 2^10 equally spaced values because of the presence of noise. Now, map the real number you just computed to the nearest of the 2^10 equally spaced values, and you will have made a decision as to what the 10 bits are. Warning: Do not try this at home. Even though I am a trained professional, I would leery of doing things this way, but since you asked.... Hope this helps Dilip Sarwate
On 04/06/2011 06:08 AM, westocl wrote:> Maybe somebody can help me think about this the right way. > > Ok, it is well known that there is an 'equivalence' in convolution in the > time domain to multiplication in the frequncy domain, so consider this... > > Say we have a modulated bitstream of lets say 10 bits and knew what they > were., then did a simple matched filter operation (on the modulated signal > maybe perurbed by noise that corrupted exactly 1 bit), and compared the > bits to the output of the matched filter... we should be able to recover > the bits and see which one was in error. > > Now lets try this in the frequency domain... We take the transform of the > 10 bitstream. Now since the matched filtering operation is really just > convolution time reversed, we expect to be able to take the transform of > the matched filter and multiply the phase by a -1, then do the > multiplication F(k)(bits)*H(k)(matched filter negative phase). {please > excuse my crude notation}. > > Now what? Will we never be able to find out which bit was in error?, The > way im thinking about it.. I shouldnt have to take the inverse transform, > to get my answer... the 'information' content cant change due to a linear > transform assuming the basis functions are complete.I think you are misapplying the concept of a matched filter. You know that a matched filter is one with an impulse response equal to the time-reversal of the signal that you're going to detect. That's good. But you seem to be missing two things: the matched filter is optimal when the signal that you're going to detect has no intersymbol interference, and when the signal is being corrupted by additive white Gaussian noise. You're not corrupting your signal with white Gaussian noise: you're choosing a 10-symbol two-value signal, and you're corrupting it by flipping the value of one of the symbols. That's neither Gaussian, nor white, nor additive. I _think_, without having had any caffeine yet this morning, that your signal could be one without intersymbol interference, but trying to make my brain spin that fast doesn't seem to be having much effect yet. So I think the answer is that if you already know what the data pattern is, if you want to use a matched filter to see if one bit is off you should use it as a paperweight while you look at each bit, and choose the one that doesn't match the pattern. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 4/6/2011 6:08 AM, westocl wrote:> Maybe somebody can help me think about this the right way. > > Ok, it is well known that there is an 'equivalence' in convolution in the > time domain to multiplication in the frequncy domain, so consider this... > > Say we have a modulated bitstream of lets say 10 bits and knew what they > were., then did a simple matched filter operation (on the modulated signal > maybe perurbed by noise that corrupted exactly 1 bit), and compared the > bits to the output of the matched filter... we should be able to recover > the bits and see which one was in error. > > Now lets try this in the frequency domain... We take the transform of the > 10 bitstream. Now since the matched filtering operation is really just > convolution time reversed, we expect to be able to take the transform of > the matched filter and multiply the phase by a -1, then do the > multiplication F(k)(bits)*H(k)(matched filter negative phase). {please > excuse my crude notation}. > > Now what? Will we never be able to find out which bit was in error?, The > way im thinking about it.. I shouldnt have to take the inverse transform, > to get my answer... the 'information' content cant change due to a linear > transform assuming the basis functions are complete. > > Any thoughts?If I understand what you'd propose in the time domain is a type of error detection. Is that right? As you do the convolution you're looking for a peak in order to detect the 10-bit sequence when the match is best. So, presumably you're matching over 10-bit sequences? That is, the convolution integral is over a 10-bit sequence? Consider this: Take the case where there is no noise and filter two sequences: - one that is an exact match. - one that is 1 bit off. What do you get? .. a difference in the peak value. So, a good question is: can you reasonably detect the difference in peak value? Usually the matched filter process is looking for temporal peaks and not so much for measuring peak amplitudes as such. Consider channel attenuation, etc. I guess one could filter using *every* 10-bit sequence with a single bit that's flipped - so that's 11 replicas if you include the correct one. Then you could compare the amplitudes of the same signal with different replicas. At least the amplitudes should have a relation and you might be able to tell *which* bit is off this way. Otherwise with only one replica you'd only be able to tell that there was 1 bit off but not where... well, as above, maybe you could do that. So, I'm a bit skeptical that the example is a well posed approach to what you want to do. OK, with that as a starting point, take the FFT of the replica(s) and multiply by the signal. I think you can imagine the answer to your question about "information content". - First of all, as above, the information you seek is tenuous at best. - Second, the Fourier Transform changes narrow things into wide things and vice versa. You're looking for a narrow thing in time so it's going to be wide in frequency. So, the "result" will be spread over a number of spectral samples and I'd worry a lot about SNR - which I don't see improving by doing the FT in the first place. The FT is very often used to find narrow things in frequency and you're looking for a narrow thing in time. Fred
On Wed, 06 Apr 2011 08:08:40 -0500, "westocl" <cweston_@n_o_s_p_a_m.hotmail.com> wrote:>Now lets try this in the frequency domain...<...>>Now what? Will we never be able to find out which bit was in error?, The >way im thinking about it.. I shouldnt have to take the inverse transform, >to get my answer... the 'information' content cant change due to a linear >transform assuming the basis functions are complete.As others have mentioned, matched-filter convolution is probably NOT the best way to accomplish your goal, that goal being the detection -- in the frequency domain -- of which bit has been corrupted. But there is a way. Assume that your 10-bit uncorrupted sequence consists of N "1" bits and (10-N) "0" bits. Now assume that your 10-bit uncorrupted sequence is the sum of N sequences, each of which has exactly one "1" bit and exactly nine "0" bits, with no overlap between the "1" bits. That is to say, if one of the sequences contains a "1" in position "k", then none of the other sequences contains a "1" in position "k". Now compute the DFT of each of those N unique sequences. You will find that a sequence consisting of a "1" followed by nine "0" bits will have a DFT consisting of a constant real part and a zero imaginary part. A sequence consisting of a "0" followed by a "1" followed by eight "0" bits will have a DFT consisting of one cycle of a cosine wave in the real part, and one cycle of a sine wave in the imaginary part. And so on ... a sequence consisting of M "0" bits followed by a "1" bit followed by (9-M) "0" bits will have a DFT consisting of M cycles of a cosine in the real part and M cycles of a sine in the imaginary part. Now compute the DFT of your complete uncorrupted sequence as the sum of the DFTs of the individual sequences computed above (or just compute the DFT of the original sequence). Now compute the DFT of your CORRUPTED sequence, and subtract that from the DFT of your UNcorrupted sequence. Compare the difference that you just computed with the individual DFTs of the unique sequences. Whichever one matches is the bit that has been corrupted. Greg
