Osculating/Hermite Interpolation on sampled data
Started by Jon Harris ●January 21, 2004
>you might refer to Olli Niemitalo's paper on polynomial interpolation at > >http://www.biochem.oulu.fi/~oniemita/dsp/deip.pdf
Well, yes I've read that one too. But I'm actually just referring to the general case of regular cubic splines. Cubic splines are second order osculating (both position, first- and second derivatives are matched at the knots that connect the piecewise polynomials). It is in this case quite clear to say that, the interpolation is C2-continuous. If we do not express constraints on the second derivative when creating the spline (for example for cubic Hermites), then the interpolation is C1-continuous. But which degree of continuity is reached using when using the sinc interpolator? Ideally it is fully continous I guess, since the sinc has the properties you described. But in practice? Doesn't it depend on whether it is truncated or windowed? And at which zero crossing this is done? Just because the interpolation kernel (or impulse response, in this case the sinc) is fully continous, does that imply that the resulting interpolation is fully continous too? This is confusing. Thanks. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
