Hi I have an application where I'm using a functiongenerator and a scope to do network analysis. The function generator is programmed at various sine frequencies and the scope captures an image per freq. and this image is download to the PC for analysis. For both A and B channel on the scope the magnitude and phase relationship is found and the gain is found by (A/B), the phase by A-B However I use a function to find the zero crossing point to get the phase and that is not so elegant. (I hopping around to locate a zero value) I was wondering about using FFT instead. So both waveforms (A and B) was run through a FFT analysis and the Gain/Phase result would be found by dividing and subtracting the FFT spectrum of the Gain and Phase respectively But due to speed concerns I was thinking about using a squarewave instead (today I sweep with about 4-5 frequencies per decade to get satisfiable accuracy). The squarewave has a fundamental and some harmonics (3rd, 5th and so on). But then I could measure a frequency decade with one frequency. The harmonics will be attenuated, but anyway I would do the FFT and get the results for 1xFreq, 3xFreq, 5xFreq.... But what about the phase - will that work on that too? Subtracting the FFT on the channel A waveform from the FFT on the channel B waveform by subtracting "1xFreq_A - 1xFreq_B" and "3xFreq_A - 3xFreq_B" and so on..... Thanks Klaus
FFT on a square wave
Started by ●January 18, 2004
Reply by ●January 19, 20042004-01-19
Hi!> But what about the phase - will that work on that too? Subtracting the FFT > on the channel A waveform from the FFT on the channel B waveform by > subtracting "1xFreq_A - 1xFreq_B" and "3xFreq_A - 3xFreq_B" and so on.....The phase will work to. But just the difference. The absolute would still be wrong. Regards! Atmapuri.
