On Oct 13, 6:45�pm, "mnentwig" <markus.nentwig@n_o_s_p_a_m.renesasmobile.com> set down a program and remarked about its output:> Looks gaussian enough to me.I know just enough programming to make some sense of what he wrote, so I am going to put down what I think the program does and then make some additional comments based on my understanding> sig = randn(1, n);Fills the array sig with the values returned by n = 10^6 calls to a standard Gaussian random variable generator randn. The histogram of 10^6 values will look like a standard Gaussian pdf> sig = fft(sig);Compute in-place DFT of the vector sig of length 10^6> sig (1+n2:end-n2+1) = 0;Zero out the middle 50,000 bin, effectively passing sig through a brick-wall filter> sig = ifft(sig);Compute in-place iDFT of filtered signal> sig = real(sig); % chop off roundoff errorDiscard imaginary components since filtered output should be a real-valued signal> hist(sig, 100); hold on; > x = -3:0.01:3; > plot(x, 36000*exp(-(2.2*x) .^ 2), 'r');Show the histogram of sig and overlay a Gaussian pdf curve over it to show that the histogram pretty much follows the same shape. ==================================== So what's the big deal? It is known that a Gaussian random process passing through a linear filter emerges as a Gaussian process, and so the histogram of values of sig *should* look Gaussian, and by golly it does. So what? As Jerry Avins has already pointed out, a lot of work has been done for little effect; sig began as a Gaussian vector anyway. Oh, you mean that sig is now a low-pass Gaussian process as opposed to the broadband Gaussian process that you began with? Well, why didn't you say so? But please note also that>sig = fft(sig) is also a Gaussian vector, soyou could equally well have started by filling sig with 475,000 Gaussian random variables at one end, their complex conjugates at the other end, leaving 50,000 zeroes in the middle and taken the iDFT or ifft. And I won't bring up the problems that Tim Wescott and Glenn Herrmansfeldt have already noted with this brick-wall filter business. Dilip Sarwate
Band limited Gaussian White noise generation
Started by ●October 12, 2011
Reply by ●October 14, 20112011-10-14
Reply by ●October 15, 20112011-10-15
Hello,>So what's the big deal? It is known that a >Gaussian random process passing through >a linear filter emerges as a Gaussian process, >and so the histogram of values of sig *should* >look Gaussian, and by golly it does. ...Thanks, that's exactly what I meant.> so >you could equally well have started by filling >sig with 475,000 Gaussian random variables >at one end, their complex conjugates at the >other end, leaving 50,000 zeroes in the middle >and taken the iDFT or ifft.I agree. In one way, I'd explain it intuitively as "filtering" (=> remove energy beyond a cutoff frequency), in the other way as sample rate conversion. The outcome is the same.>> And I won't bring up >the problems that Tim Wescott and Glenn >Herrmansfeldt have already noted with this >brick-wall filter business.There is not necessarily a problem, if used in the OP's context (driving a vibration exciter). I've been using this method for years in the lab with IQ modulation signals for RF signal generators. Those signals have to be periodic anyway, since the memory size on the instruments used to be limited. Therefore, FFT is a perfect tool IMHO: Any time domain transients of the processing simply wrap around into the future / past cycle. If I set a brick-wall spectrum on the generated signal, I see _exactly_ a brick wall spectrum on spectrum analyzer or on the downconverted and sampled signal back in Matlab. Just what I'd expect. What I don't understand are some of the responses to the OP's question in general. What on earth is wrong with using FFT - I need 10 lines of code, do we expect a more elegant solution still? The accuracy of the frequency response is perfect, that's hard to beat. The only catch is, I get a line spectrum, from the periodicity of the signal. But the measurement duration is finite in any case => increase the size as needed. What's the problem with generating Gaussian noise in the frequency domain using a Gaussian amplitude and uniform [0..2pi[ phase per frequency bin? This will work just fine (use conj() on negative frequencies, as was said earlier, to get a real-valued signal in the time domain). -Markus
PS: To clarify, referring to Tim's first post: The key is: "Any time domain transients of the processing simply wrap around into the future / past cycle." As long as I don't care about time domain information, this is not a problem at all (as said, tested and tried in the lab, accurate to instrument precision). A noise signal does NOT contain any timing information or the like, so we're on the safe side. Now If I'd try the same method with a _modulated_ signal, I need to be aware that the infinitely long impulse response simply wraps around. I observe one cycle of a periodic signal, with the decaying transients of all past cycles and the rising transients of all future cycles overlapping. The result is correct (time-domain convolution of a periodic signal with an infinite impulse response). Whether it's what I want is another question, but I can easily modify the frequency response (raised-cosine, for example, comes to mind).
>> in the frequency domain using a Gaussian amplitude and uniform [0..2pi[phase per frequency bin?7 better: ... uniform [0..pi[ phase, since the Gaussian amplitude can be negative. -Markus
On Oct 15, 3:21�am, "mnentwig" <markus.nentwig@n_o_s_p_a_m.renesasmobile.com> wrote: <<<material snipped>>>> > What's the problem with generating Gaussian noise in the frequency domain > using a Gaussian amplitude and uniform [0..2pi[ phase per frequency bin? > This will work just fine (use conj() on negative frequencies, as was said > earlier, to get a real-valued signal in the time domain).If you use a Gaussian AMPLITUDE and uniform phase in the frequency domain and taking the iDFT, then you are relying on the central limit theorem to give you Gaussian noise in the time domain. (The AMPLITUDE should be Rayleigh distributed). What you should be doing is putting in complex Gaussian noise in each bin (zero-mean equal-variance independent Gaussian RVs in real and imaginary parts, conjugates in the negative frequencies). This is not too hard in general. The Box-Mulller method that is commonly used returns TWO independent standard Gaussian random variables on each call, exactly what is needed except for a scaling factor. Dilip Sarwate
Reply by ●October 16, 20112011-10-16
On 10/15/2011 3:21 AM, mnentwig wrote:> Hello,...> What I don't understand are some of the responses to the OP's question in > general. > What on earth is wrong with using FFT - I need 10 lines of code, do we > expect a more elegant solution still?I tend to think in terms of machine cycles rather than lines of code. After all, with the right stuff behind the curtain, the code can be boiled down to run(f,a) or some such.> The accuracy of the frequency response is perfect, that's hard to beat. The > only catch is, I get a line spectrum, from the periodicity of the signal. > But the measurement duration is finite in any case => increase the size as > needed.Prtfection is overkill.> What's the problem with generating Gaussian noise in the frequency domain > using a Gaussian amplitude and uniform [0..2pi[ phase per frequency bin? > This will work just fine (use conj() on negative frequencies, as was said > earlier, to get a real-valued signal in the time domain).The problem? too many chances to go wrong. A good general rule: If the code is for something mechanical, you can almost always do the job with an 8-bit processor running at less than 10 MHz. Before I get swamped, remember that I wrote 'can', not 'should'. Jerry -- Engineering is the art of making what you want from things you can get.
>> A good general rule:.. Engineering time is very expensive those days. CPU time comes for free in small amounts. A 10M elements FFT occupies one of the four cores in my desktop PC for ~500 ms. If you see any valid reasons to use more engineering time to improve on that number, fine. I don't. If it were about selling 100 million gadgets that implement the algorithm, we could talk about it. But here, it's about getting the job done in the lab, I suppose. Besides, if I get too clever in my implementation, it becomes inflexible. Why should I create my own maintenance nightmare, when I can keep it simple.
On 10/16/2011 5:33 PM, mnentwig wrote:>>> A good general rule: > .. > > Engineering time is very expensive those days. CPU time comes for free in > small amounts. > A 10M elements FFT occupies one of the four cores in my desktop PC for ~500 > ms. > If you see any valid reasons to use more engineering time to improve on > that number, fine. > I don't. > > If it were about selling 100 million gadgets that implement the algorithm, > we could talk about it. But here, it's about getting the job done in the > lab, I suppose. > > Besides, if I get too clever in my implementation, it becomes inflexible. > Why should I create my own maintenance nightmare, when I can keep it > simple.No argument. I was just telling you how I think. I spent too many years doing tasks with an 1802 that "experts" claimed required at least an 80186. Jerry -- Engineering is the art of making what you want from things you can get.
